Samsung ue324h5000w no backlight
    SAMSUNG UE324H5000W NO BACKLIGHT
    SAMSUNG UE324H5000WWZF VER N° :02
    MAIN BN41-01795A
    PSU BN44-00493B
    pwm IC 2S110
    INVERTER PFFF may be SLK2012M
    SCREEN LTJ320HN07-V
    T-CON BN41-01797A
    CNM803 VOLTAGES
    B5 ---------- 5 .2V
    B13---------13V
    PS_ON ----3.5V
    A5V---------5V
    P_DIM------0.2V
    BLU_ON ---0V
    CNKL802 VOLTAGES
    TOP1+ --------0V
    TOP1- ---------0V
    MA IN CAPACITOR CM 801 802 292V
    CM806 15V
    If i deconnect the main from psu no back light
    If i deconnect leds connector cnlM02 no voltages in
    So any ideas
    Re: Samsung ue324h5000w no backlight
    You have the power on signal PS_ON but not the backlight on BLU_ON signal.
    Disconnect the mainboard and connect a 1K resistor between 5V and BLU_ON and another 1K from 5V to PS_ON and the backlights should come on.
    Edit
    +1 I agree with dskall that the main capacitor voltage does appear to be too low.
      Main cap voltage looks about 100v low
        i think main cap is norm because there is no PFC
        PS ON LOOK IN NORM THERE IS IMAGE BUT NO BACKLIGHT
          Do you have a schematic?
          What DC voltage do you have between pins 1 and 8 of the 2S110
            No i havent a schematic for this psu and google too
              How does OP measure the Voltage on the main cap, between the two legs or using chassis as the GND ref. for the meter?
                Fair point, should have asked that.
                  with unit t multimeter ut-61b
                  vcc 1-->8 ---------------15 V
                  1---7-----------------
                  1---6-----------------
                  1---5-----------------
                  1---4----------------285V
                  1---2----------------1.2 V
                    What is you incoming AC line Voltage?
                      BTW, since the main board is getting correct Voltage then the BL-ON should be present.
                        now 213v 50 hz so 220V line
                          213V x 1.414 = so the DCV between the two legs of the cap should be around 300VDC.
                          If you disconnect the cable from power supply board to the main board, what DCV do you have on those pins of CNM803?
                            B5 ---------- 5 .2V
                            B13---------13V
                            PS_ON ----3.5V
                            A5V---------5V
                            P_DIM------0.2V
                            BLU_ON ---0V
                            CNKL802 VOLTAGES
                            TOP1+ --------0V
                            TOP1- ---------1,4V
                            main cap 284 volts
                            so no changes in voltages only top1- with main connectd or disconnected is above 1v ~1.4 V
                              The 15V for VCC looks OK.
                                B5 ---------- 5 .2V
                                B13---------13V
                                PS_ON ----3.5V
                                A5V---------5V
                                P_DIM------0.2V
                                BLU_ON ---0V
                                CNKL802 VOLTAGES
                                TOP1+ --------0V
                                TOP1- ---------1,4V
                                main cap 284 volts
                                O, I just want to verify if the BL-ON pin has pull-up resistor for self test or not
                                So you need to use 500~1K resistor between A5V and the BL-ON pin then run the board by itself to see if the backlights will come on, you may need another resistor between P-Dim and A5V if the backlights do not come on.
                                Pictures provided by shopjimmy.
                                  hi everyone on this model whichi have done over 30 sonce 8 months please check you leds you will find odd 1 short circuit,and led protection coming into force, hope it helps
                                    Shorted LED or the wiring/LED board/connection shorted?
                                      With resistors in blu-àn and/or pdim there is no backlight
                                        the 4 led strips are verified and ok
