Samsung ue324h5000w no backlight
  • LE GRAND
    • Jul 2014
    • 34
    • TUNISIA
    SAMSUNG UE324H5000W NO BACKLIGHT
    SAMSUNG UE324H5000WWZF VER N° :02
    MAIN BN41-01795A
    PSU BN44-00493B
    pwm IC 2S110
    INVERTER PFFF may be SLK2012M
    SCREEN LTJ320HN07-V
    T-CON BN41-01797A
    CNM803 VOLTAGES
    B5 ---------- 5 .2V
    B13---------13V
    PS_ON ----3.5V
    A5V---------5V
    P_DIM------0.2V
    BLU_ON ---0V
    CNKL802 VOLTAGES
    TOP1+ --------0V
    TOP1- ---------0V
    MA IN CAPACITOR CM 801 802 292V
    CM806 15V
    If i deconnect the main from psu no back light
    If i deconnect leds connector cnlM02 no voltages in
    So any ideas
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: Samsung ue324h5000w no backlight
    You have the power on signal PS_ON but not the backlight on BLU_ON signal.
    Disconnect the mainboard and connect a 1K resistor between 5V and BLU_ON and another 1K from 5V to PS_ON and the backlights should come on.
    Edit
    +1 I agree with dskall that the main capacitor voltage does appear to be too low.
    • dskall
      • Oct 2016
      • 2905
      • usa
      Main cap voltage looks about 100v low
      • LE GRAND
        • Jul 2014
        • 34
        • TUNISIA
        i think main cap is norm because there is no PFC
        PS ON LOOK IN NORM THERE IS IMAGE BUT NO BACKLIGHT
        • dick_barton
          • Aug 2015
          • 6642
          • Wales
          Do you have a schematic?
          What DC voltage do you have between pins 1 and 8 of the 2S110
          • LE GRAND
            • Jul 2014
            • 34
            • TUNISIA
            No i havent a schematic for this psu and google too
              How does OP measure the Voltage on the main cap, between the two legs or using chassis as the GND ref. for the meter?
              • dick_barton
                • Aug 2015
                • 6642
                • Wales
                Fair point, should have asked that.
                • LE GRAND
                  • Jul 2014
                  • 34
                  • TUNISIA
                  with unit t multimeter ut-61b
                  vcc 1-->8 ---------------15 V
                  1---7-----------------
                  1---6-----------------
                  1---5-----------------
                  1---4----------------285V
                  1---2----------------1.2 V
                    What is you incoming AC line Voltage?
                      BTW, since the main board is getting correct Voltage then the BL-ON should be present.
                      • LE GRAND
                        • Jul 2014
                        • 34
                        • TUNISIA
                        now 213v 50 hz so 220V line
                          213V x 1.414 = so the DCV between the two legs of the cap should be around 300VDC.
                          If you disconnect the cable from power supply board to the main board, what DCV do you have on those pins of CNM803?
                          • LE GRAND
                            • Jul 2014
                            • 34
                            • TUNISIA
                            B5 ---------- 5 .2V
                            B13---------13V
                            PS_ON ----3.5V
                            A5V---------5V
                            P_DIM------0.2V
                            BLU_ON ---0V
                            CNKL802 VOLTAGES
                            TOP1+ --------0V
                            TOP1- ---------1,4V
                            main cap 284 volts
                            so no changes in voltages only top1- with main connectd or disconnected is above 1v ~1.4 V
                            • dick_barton
                              • Aug 2015
                              • 6642
                              • Wales
                              The 15V for VCC looks OK.
                                B5 ---------- 5 .2V
                                B13---------13V
                                PS_ON ----3.5V
                                A5V---------5V
                                P_DIM------0.2V
                                BLU_ON ---0V
                                CNKL802 VOLTAGES
                                TOP1+ --------0V
                                TOP1- ---------1,4V
                                main cap 284 volts
                                O, I just want to verify if the BL-ON pin has pull-up resistor for self test or not
                                So you need to use 500~1K resistor between A5V and the BL-ON pin then run the board by itself to see if the backlights will come on, you may need another resistor between P-Dim and A5V if the backlights do not come on.
                                Pictures provided by shopjimmy.
                                • MICROTECHSERVICE
                                  • Jun 2016
                                  • 36
                                  • United Kingdom
                                  hi everyone on this model whichi have done over 30 sonce 8 months please check you leds you will find odd 1 short circuit,and led protection coming into force, hope it helps
                                    Shorted LED or the wiring/LED board/connection shorted?
                                    • LE GRAND
                                      • Jul 2014
                                      • 34
                                      • TUNISIA
                                      With resistors in blu-àn and/or pdim there is no backlight
                                      • LE GRAND
                                        • Jul 2014
                                        • 34
                                        • TUNISIA
                                        the 4 led strips are verified and ok
                                          09-07-2024, 05:50 AM
                                        • sansanpartida
                                          Samsung QE82Q70RAT no backlight
                                          by sansanpartida
                                          Hi everyone!
                                          Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
                                          My issue: No backlight.
                                          Model: QE82Q70RAT
                                          Type No: QE82Q70RAT
                                          The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
                                          So hopefully, I can fix this cheaper.
                                          05-22-2024, 06:56 AM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • Warrensmith
                                          Samsung BN44-00807E Low Backlight
                                          by Warrensmith
                                          Symptom is dim backlight - this set came in with almost no backlight.
                                          Samsung UN55JU6500FX2A
                                          1 - Replaced all backlight LED strips (set had lots of hours at level 20 backlight)
                                          2 - Changed out what appeared to be a bad Q9102C on BN44-00807E - not shorted or burned but appeared to be open. I was able to read (with difficulty) the part number - however I may have misread it - Can someone confirm that this is indeed an AOD9N40.
                                          Backlight improved significantly - about like it would be set to a level 3 or 4. Setting all the way to 20 seems to...
                                          10-27-2022, 07:09 AM
                                        • Max514
                                          Samsung UN55H8000 sound but no backlight no video
                                          by Max514
                                          Ok so I have this beautiful un55h8000 samsung tv with sound but no video nor backlight. When turning the set on the red light blinks 5 times.
                                          The screen shows no damage and backlight turns on when I disconnect the power supply from the main board. The tcon board only has 2 out of 3 leds on.
                                          I came across this page and followed the different steps: https://techhometravel.com/samsung-u...ight-no-video/
                                          • Unplugging the main board cable at the power supply >>> backlights came on.
                                          • BLU_ON signal from the
                                          04-14-2022, 10:34 AM
