hello i have a sanyo plasma dp42740 i got for 20 doolars. the problem is it will not power up. the power light does not come on what so ever, not even for a second. the power supply clicks several times when you plug it in, the power button does nothing. the screen does light up with a glow to it very flaintly. there is a small logic board that when i unplug the power cable to it the glows goes away. this is the only cable that kill the glow on the screen. no power light on front, could be burnt out, not sure. can the psu be stuck on that only this logic board gets power? it has an analog and a digital board that feed info to this logic board. if anyone could help me figure this out would be get.. don't know plasma that good, can replace boards all day long on lcd's
sanyo dp42740 plasma wont power on
Tags: None
Re: sanyo dp42740 plasma wont power on
this set doesn't try to start or turn off all it does is the screen glow when pluged inComment
Av board is gone then, try test patterns
https://www.facebook.com/Telford-Tel...7894576335359/Comment
can,t seem to get set to do any kind of test pattern. downloaded the repair manual but it doesnt even show tnpa 3505 board at all. this is the board that connects to the y board and is causing the glow on the screen. i unhook the power to it and no screen glow, but still have nothing else.. led on front never lights up at all still thinking it could be psu (b159-001) causing the problemComment
seems like once post hits second page you don't get anymore ideas help please i'm at my end with this setComment
nvm,wrong postLast edited by martino; 02-19-2017, 07:44 PM.Proud owner of dozens of broken TV's and many,many,many boards.
Our website and passion:http://hollenhundshepherds.com/Comment
Can you post pictures of the back of the set showing the circuit boards and interconnection of the boards (in focus).can,t seem to get set to do any kind of test pattern. downloaded the repair manual but it doesnt even show tnpa 3505 board at all. this is the board that connects to the y board and is causing the glow on the screen. i unhook the power to it and no screen glow, but still have nothing else.. led on front never lights up at all still thinking it could be psu (b159-001) causing the problem
Check the voltages are as shown in the manual attached.
To run the test pattern, do a search on the forum.
There's a lot of information on this forum regarding this model if you search DP42740.Attached Filesif you find these attachements useful please consider making a small donation to the site
Last edited by dick_barton; 02-20-2017, 04:40 AM.Willing to help but I'm no expert.Comment
im not sure you can run test patterns on these sets this is a quote by tom66
Hmm, unfortunately, Panasonic D boards do not have a simple test pattern jumper. It does sound like a main board fault, given the lack of power LED.Comment
Hopefully the manual should be a good starting point to fault finding. Check what voltages are missing or if the Protect is kicking in. As I said above there is a lot of info on this set on the Forum which should help.Willing to help but I'm no expert.Comment
I'll do some more poking around on this set today. ThanksComment
Assuming...7 Photos -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by CooperrI picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board... -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... - Loading...
