sanyo dp42740 plasma wont power on
  • robert phelps
    • Dec 2016
    • 94
    • usa
    hello i have a sanyo plasma dp42740 i got for 20 doolars. the problem is it will not power up. the power light does not come on what so ever, not even for a second. the power supply clicks several times when you plug it in, the power button does nothing. the screen does light up with a glow to it very flaintly. there is a small logic board that when i unplug the power cable to it the glows goes away. this is the only cable that kill the glow on the screen. no power light on front, could be burnt out, not sure. can the psu be stuck on that only this logic board gets power? it has an analog and a digital board that feed info to this logic board. if anyone could help me figure this out would be get.. don't know plasma that good, can replace boards all day long on lcd's
  • mmartell
    • Oct 2013
    • 3189
    Re: sanyo dp42740 plasma wont power on
    If the screen glows the set IS powering on. Try running the test patterns by jumpering the logic board (look it up!) and see if the set comes alive.
    • robert phelps
      • Dec 2016
      • 94
      • usa
      this set doesn't try to start or turn off all it does is the screen glow when pluged in
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Av board is gone then, try test patterns
        • robert phelps
          • Dec 2016
          • 94
          • usa
          can,t seem to get set to do any kind of test pattern. downloaded the repair manual but it doesnt even show tnpa 3505 board at all. this is the board that connects to the y board and is causing the glow on the screen. i unhook the power to it and no screen glow, but still have nothing else.. led on front never lights up at all still thinking it could be psu (b159-001) causing the problem
          • robert phelps
            • Dec 2016
            • 94
            • usa
            seems like once post hits second page you don't get anymore ideas help please i'm at my end with this set
            • martino
              Not so "senior"
              • Aug 2013
              • 997
              • canada
              nvm,wrong post
              Proud owner of dozens of broken TV's and many,many,many boards.
              Our website and passion:http://hollenhundshepherds.com/
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                Can you post pictures of the back of the set showing the circuit boards and interconnection of the boards (in focus).
                Check the voltages are as shown in the manual attached.
                To run the test pattern, do a search on the forum.
                There's a lot of information on this forum regarding this model if you search DP42740.
                • vinceroger69
                  • Mar 2012
                  • 6714
                  im not sure you can run test patterns on these sets this is a quote by tom66
                  Hmm, unfortunately, Panasonic D boards do not have a simple test pattern jumper. It does sound like a main board fault, given the lack of power LED.
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    Hopefully the manual should be a good starting point to fault finding. Check what voltages are missing or if the Protect is kicking in. As I said above there is a lot of info on this set on the Forum which should help.
                    • flocko
                      • Nov 2012
                      • 1121
                      Lots of posts on these sets (do a search) this set has two mains a analog + digital main,bad digital board would be my bet
                      • robert phelps
                        • Dec 2016
                        • 94
                        • usa
                        I'll do some more poking around on this set today. Thanks
                        • PantherDave
                          by PantherDave
                          Hi all!
                          05-29-2024, 02:01 PM
                        • GLISIT
                          by GLISIT
                          01-16-2025, 02:29 PM
                        • Cooperr
                          Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
                          by Cooperr
                          I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
                          The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
                          10-21-2025, 01:11 PM
                          by sam_sam_sam
                          03-31-2024, 02:12 PM
