baird 42 no picture
  • LEEDASH
    • Dec 2012
    • 481
    • Bedfordshire
    Re: baird 42 no picture
    Originally posted by dick_barton
    I assume you mean 11.94 volts and is that on both sides of the fuse?
    Yes
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Cannot find anything under that model number. Can you confirm it's correct?
      • LEEDASH
        • Dec 2012
        • 481
        • Bedfordshire
        Cn42bair
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          Do you have the following voltages:-
          Con4
          Pins 3, 4 = 5V
          Pin 5 = Power _On
          Pin6 = 5Vstb
          Pins 12 & 13 = 12V
          Con3 & Con 5 = 24V
          • LEEDASH
            • Dec 2012
            • 481
            • Bedfordshire
            Sorry bud,Im a amateur,So these have to be tested again with unit on or standby
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              #26
              Test with unit on standby and give the voltages on those pins and then out of standby giving the pin voltages again.
              • LEEDASH
                • Dec 2012
                • 481
                • Bedfordshire
                #27
                con4 only has 4 pins or am i reading it wrong
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  #28
                  Can you post a well focused photo of the edge connectors and any printed labels alongside them.
                  This is MLT668 Rev1.5
                  • LEEDASH
                    • Dec 2012
                    • 481
                    • Bedfordshire
                    #29
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      #30
                      So alongside each connector pin there's a legend.
                      Can you measure the voltage on each wire and compare it to what is written alongside
                      Example
                      Legend Name = Reading
                      GND = 0V
                      +5V = xxxxV
                      5VSBY = xxxxV
                      12V = xxxxV
                      24V = xxxxxV
                      etc
                      • LEEDASH
                        • Dec 2012
                        • 481
                        • Bedfordshire
                        #31
                        yes can do,before i start do i set dc to 200 ? as reading higher than 20v on multi,ground the black and read from the red,placed inside connector with connecting block still connected,if you understnad what im talking about,
                        does the tv set have to be switch on or standby ?
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          #32
                          You can set your meter to 200V dc if you want to. Place the black meter lead on metal panel and the red lead to connector pins.
                          Again do the check in standby and then out of standby.
                          • LEEDASH
                            • Dec 2012
                            • 481
                            • Bedfordshire
                            #33
                            standby
                            +12v zero
                            +12 zero
                            sdnd no reading
                            +5 0.68
                            +5 0.68
                            stb 0.1
                            5vsb 5.04
                            con 4
                            24v 0.07
                            24v 0.07
                            sgnd zero
                            sgnd zero
                            switched on.....
                            con 4
                            24v both 23.6
                            sgnd zero
                            con5
                            +12v 11.8
                            +12v 11.8
                            sgnd all three zero reading
                            5vsb 04.9
                            stb 01.9
                            +5v 04.9
                            +5v 01.9
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              #34
                              Originally posted by LEEDASH
                              standby
                              +12v zero
                              +12 zero
                              sdnd no reading
                              +5 0.68
                              +5 0.68
                              stb 0.1
                              5vsb 5.04
                              con 4
                              24v 0.07
                              24v 0.07
                              sgnd zero
                              sgnd zero
                              switched on.....
                              con 4
                              24v both 23.6
                              sgnd zero
                              con5
                              +12v 11.8
                              +12v 11.8
                              5vsb 04.9
                              stb 01.9
                              +5v 04.9
                              +5v 01.9
                              Those voltages all appear to be fine except for the last one??
                              • LEEDASH
                                • Dec 2012
                                • 481
                                • Bedfordshire
                                #35
                                Yes...where the source
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  #36
                                  I don't know what you mean?
                                  • LEEDASH
                                    • Dec 2012
                                    • 481
                                    • Bedfordshire
                                    #37
                                    me neither,so its dropped voltage,how do i know what powers this pin
                                    • dick_barton
                                      • Aug 2015
                                      • 6643
                                      • Wales
                                      #38
                                      Is there a cable at that location and are you are saying it reads 1.9V and not 5V which is written alongside? Where does the cable go? The power supply provides power to other circuit boards so it's an normally an output not an input.
                                      • LEEDASH
                                        • Dec 2012
                                        • 481
                                        • Bedfordshire
                                        #39
                                        selected 20v on multi,the 5v are reading 5v the 'stb is 2.01,
                                        • dick_barton
                                          • Aug 2015
                                          • 6643
                                          • Wales
                                          #40
                                          So it now looks as though you have all the voltages and power to the backlights and Tcon board.
                                          I don't know what else to suggest. It may be an EEPROM problem which are available from:-
                                          http://www.ohmsupplies.co.uk/BAIRD-C...-PREPROGRAMMED
                                          But perhaps better to wait to see what others on the forum suggest.
                                          Can you hear sound when connected say to a DVD player?
                                          • Tr0ll
                                            by Tr0ll
                                            Original T-con:
                                            First replacement T-con:
                                            10-07-2023, 07:48 PM
                                          • JJAAMM
                                            by JJAAMM
                                            Problem
                                            07-06-2023, 06:01 AM
                                          • TR103
                                            by TR103
                                            - it keeps rebooting
                                            01-22-2025, 04:12 PM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • CyberPhoenix
                                            Issue with picture quality of Sony bravia TV
                                            by CyberPhoenix
                                            Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                                            01-22-2024, 02:08 AM
