17MB95s-1 HDMI prob
  • finntricky
    • Jan 2014
    • 449
    17MB95s-1 HDMI prob
    it's like this,
    this board has 3 HDMI inputs, number 1 is dead, number 2 displays for 5 secs before going blank, and number 3 is fine, no probs,
    so what chip is causing the problem, the one near the HDMI ports ?
    do you think a reflow may help, or is gonna kill the board all together ?
  • rccrasher65
    • Mar 2014
    • 622
    Re: 17MB95s-1 HDMI prob
    Originally posted by finntricky
    it's like this,
    I would try a reflow no oven. I had a successful repair on a Lg main board by replacing the 144pin Switch Ic.The two that are on your board need specialized equipment and skills in reballing to repair. Use hot air station to give it a tr. more than likely gonna have to search for a board replacement. Also check the small surface mounted resistors that are around the HDMI port, compare the results to the one that does work.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Prolly bga solder issue, main cpu literally is responsible for everything. Gets very very hot and with that shitty heatsink wouldn't surprise me. These boards are junk as it is. Also preform factory reset in service menu in diagnostics page.
      • vinceroger69
        • Mar 2012
        • 6714
        maybe worth reflowing the actual hdmi sockets too just incase some ones been heavy handed and broken the solder on the socket pins/legs
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • aliougm
          Marantz SR4003 AVR HDMI board issue, seeking for help
          by aliougm
          I have problem with my AVR(Marantz SR4003) HDMI board issue. I connect to my TV but screen color distorted,see attached picture.
          Connection as below:
          Set-top box HDMI output >AVR 3 HDMI input/one HDMI output>HDTV HDMI port
          If I bypassed AVR then HDTV screen color be good.
          I take out HDMI board from AVR and check services manual the schematic shown the HDMI signals path:
          3 HDMI input port > SIL9185 chip(HDMI switch) > SIL9033 chip(HDMI receiver) > SIL9030 chip(HDMI transmitter) > HDMI output port
          I replaced all...
          04-30-2022, 12:21 PM
        • howardc64
          by howardc64
          07-24-2025, 05:17 PM
        • Hakuu
          by Hakuu
          Hi There,
          More Details
          TV Model - LG OLED77G1PUA
          07-12-2023, 02:37 PM
