Vizio E28H-C1
  • Fisher77
    • Feb 2016
    • 229
    Vizio E28H-C1
    This is the last TV that took a lighting strike from my parents house.
    Power supply has no output voltage. I have replaced a blown diode, blown FET, blown resistor, PWM, and 2 caps.
    I still have 0V on all the outputs of the PS board.
    Power supply board number is PLTVEF201XAF5. I have outlined all the components replaced
    in red boxes on the pics. I also posted a pic of the PWM pinout, and a
    schematic it was used in. The schematic does not belong to this TV.
    I was unable to find a datasheet on this particular PWM. It is a PF6003AHS.
    The FET is a K8A50D. Resistor is a 0.27 ohm 1W. Diodoe is a SR5150.
    Caps are both 10uF 50V.
    If there are any other pictures needed let me know, and I will
    post them. I really don't know what else to check.
    Thanks for any help.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Vizio E28H-C1
    Your fuse is good? What do you have across your main filter cap?
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Re: Vizio E28H-C1
      I would also check that the PF6003AHS has no short circuit to the ground pin (Pin 4)
      • Fisher77
        • Feb 2016
        • 229
        Re: Vizio E28H-C1
        Thanks for the reply Dick_Barton
        Checked all the fuses, they are good. 164V DC across the main filter cap.
        Will do.
        • dskall
          • Oct 2016
          • 2905
          • usa
          Re: Vizio E28H-C1
          Voltage on pin 8 of PF6003AHS? If you have oscilloscope you could check input to fet. Any output from transformer? Resistors and diodes good around PF6003AHS?
          • Fisher77
            • Feb 2016
            • 229
            Re: Vizio E28H-C1
            The resistors and the diodes around the PF6003AHS have all checked good. The voltage to the Drain of the fet is 164V. I will check the transformer output.
            When checking the voltage on pin 8 of the PWM, do I use the negative of the main cap for ground?
            I checked the PWM, and did not find a short to ground.
            • dskall
              • Oct 2016
              • 2905
              • usa
              Re: Vizio E28H-C1
              Everything on hot side of line is neg of main cap or neg of bridge rect. or #4 ground pin on ic
              • Fisher77
                • Feb 2016
                • 229
                Re: Vizio E28H-C1
                Ok, voltage on the PWM pins is as follows
                1 .636V
                2 0V
                3 .687V
                4 0V
                5 0V
                6 4.62V
                7 NC
                8 4.62V
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  Re: Vizio E28H-C1
                  Seems like there should be something on feedback #2
                  • Fisher77
                    • Feb 2016
                    • 229
                    Re: Vizio E28H-C1
                    I agree. The trace for #2 runs trough a couple of 0 ohm resistors to pin 4 of the optocoupler.
                    Possible bad optocoupler?
                    • CapLeaker
                      Leaking Member
                      • 8223
                      Re: Vizio E28H-C1
                      Also check R9112, 13 and 14 (three resistors in series).
                      Can you upload the whole schematic, please?
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        Re: Vizio E28H-C1
                        I would think that the VCC supply for the PWM is low especially when you consider there a 50V capacitor attached to it.
                        Check the resistance of R9111/R9112
                        • CapLeaker
                          Leaking Member
                          • 8223
                          Re: Vizio E28H-C1
                          R9111 and R9102
                          • dskall
                            • Oct 2016
                            • 2905
                            • usa
                            Re: Vizio E28H-C1
                            He says that schematic is not for his tv. Just that the schematic has the same controller. So more like a generic circuit. Also can't find spec. sheet for that controller.
                            • Fisher77
                              • Feb 2016
                              • 229
                              Re: Vizio E28H-C1
                              I checked all those resistors, they all check good with the leads one way, but if I reverse the leads the meter jumps all over the place.
                              I checked R9113 also. Something wierd going on there too. When I check it one way its shows 4.29M, when I reverse the leads it shows 14.53M.
                              WTH is going on here?
                              Something in circuit causing this?
                              I have searched for a datasheet to, no luck. I contacted the seller of the chip to see if he had one, no dice. So wonderful to deal with these "grey market" components.
                              • dick_barton
                                • Aug 2015
                                • 6643
                                • Wales
                                Re: Vizio E28H-C1
                                Check the resistors leading from AC-1 that feed BNO. I have had one resistor go high and stop the set from working, but was on a different set. The only way to tell was to lift them off the board and measure.
                                It looks like BNO may be acting as the AC Detect input.
                                  Re: Vizio E28H-C1
                                  So what is the real P/N of the SMPS IC U9101?
                                  • Fisher77
                                    • Feb 2016
                                    • 229
                                    Re: Vizio E28H-C1
                                    PF6003AHS is the number that was on the original
                                    • Fisher77
                                      • Feb 2016
                                      • 229
                                      Re: Vizio E28H-C1
                                      Ok, I replaced the PS board. The TV will still not power on.
                                      Voltages on the PS board are:
                                      On/Off - 0V
                                      DIM - 0V
                                      PS_ON - 0V
                                      12V_A - 12V
                                      +12V - 12V
                                      +12V - 12V
                                      There are a total of six 12V pins on the PS board. All 6 have 12V.
                                      I checked the voltages on the main board plug that go out to the
                                      on/off button, and the IR sensor board.
                                      They are as follows by wire color:
                                      Gray - 0V
                                      Purp - 5V
                                      Blue - 5V
                                      White - 3V
                                      Green - 0V
                                      Yellow - .8V
                                      Orange - 0V
                                      Brown- fluctuates anywhere from 0V to .8V.
                                      Black and Brown wire go to the on/off switch. The rest go to the IR sensor board.
                                      • dskall
                                        • Oct 2016
                                        • 2905
                                        • usa
                                        Re: Vizio E28H-C1
                                        Do you get anything on pson when you push power button? Backlights? Check around mainboard input connector for fuses, voltages at regulators. Brown wire fluctuates when you push power button?
                                        • x_orange90_x
                                          Sony Bravia KD-50X690E blown resistor
                                          by x_orange90_x
                                          I just picked up this tv yesterday and the previous owner said while watching tv he heard a loud a pop and then the screen went dark. I removed the back cover and found the source rather quickly; resistor R8601. A chunk of the ceramic had blown off exposing the inner wire. Due to the damage I cannot make out the colors of a couple bands. I likewise cannot find a datasheet for the power supply. I tried pulling up pictures of the same board online but the resistors have different colored bands which I half expected as I've had this happen before.
                                          The power supply is 715G8413-P01-001-0H2S...
                                          07-16-2024, 06:53 AM
                                        • redbaron1007
                                          Arcade PSU blown resistor ID
                                          by redbaron1007
                                          I'm working on one of the PSU's in my backlog today that came out of an NBA Jam arcade machine a year or so ago. The PSU is a Pan Yes brand with a model number PY-TV-C. From what I remember the 12v rail wasn't outputting anything. I opened it up and was reminded that the resistor at R28 had blown it's shell off and I have no idea how to ID a replacement for it. (see pictures) The color bands that are still intact a little are brown, black, missing band/bands, and what I'm assuming is silver. When I check it with my DMM it's reading 100ohms exactly but I don't know if that's what it's supposed...
                                          01-06-2023, 04:13 PM
                                        • mikey5791
                                          Need help to replace burned resistor in 350w atx psu
                                          by mikey5791
                                          Hi to all forum members,
                                          Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                                          The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                                          Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                                          Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                                          12-26-2024, 04:55 AM
                                        • labello
                                          Honda XL 600 LM 1985-1989 PD04,Resistor blown up and losted
                                          by labello
                                          Hi guys a friend of mine give me this old counter it's for Honda XL 600 LM 1985-1989 PD04.
                                          He opened it and found a resistor that was blown up. Then he lost it. I knowing it's not easy to fix it, but I just guess (maybe we can) thank you so much...
                                          09-27-2023, 02:46 AM
