westinghouse dwm50f3g1 powers up with no picture
  • engelwood39
    • Mar 2015
    • 93
    I have a westinghouse dwm50f3g1 that powers up and the back-light comes on but the picture never comes on. The screen just has a very dim dark glow.
    Does anyone know what testing should be done or what might be at fault?
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: westinghouse dwm50f3g1 powers up with no picture
    Have you checked with a bright light on the screen if there is a picture. Do you have sound?
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      OK so the backlights are ON and you have no picture....Look at the T-CON Bd and locate the SMD fuse....( I can't see it in the pictures).....see if there is 12Vdc on both sides of the Fuse. If 12Vdc is present on both sides...disconnect one side of the flat white cable going to the Panel and see if there is picture....reconnect and remove the other side....report what you see....of course disconnecting and reconnecting of the cables are done with the power OFF.
      • engelwood39
        • Mar 2015
        • 93
        No there is no picture with a flashlight. The back-light is lit up when the set is on.
        Andrew, I am attaching a pic of what I believe may be the fuse It is green whit a "F102" marking next to it. If it is I have 11.73V on each side of it. Unplugging the ribbon cables and trying it with just one side hooked up still had no picture(I tried it on both sides).
        Does the narrow it down to the just the T-Con Board? Or could it still possibly be the Main Board?
        If you need a better pic up close of the possible fuse let me know.
        • engelwood39
          • Mar 2015
          • 93
          If I need to replace the T-Con Board it would be nice to know soon. I found one for pretty cheap and would like to buy soon if it
          • CapLeaker
            Leaking Member
            • 8352
            The only way to test the main board is to check the LVDS with an oscilloscope. Unless you have one to do so, the cheapest and next logical thing is to try the Tcon first.
            • engelwood39
              • Mar 2015
              • 93
              Sounds good CapLeaker. It has now been purchased and I will update when the part comes in.
              If that doesn't work is the next logical step to replace the Main Board?
                Westinghouse Element Seiki RCA 55.50T03.C05 / 55.50T03.C01 (T500HVN01.0, 50T03-C0A) T-Con Board
                http://www.shopjimmy.com/westinghous...-con-board.htm
                If you look real close at the board, you will see bare copper pad test points with label right next to them.
                For example, there are two test points that I can see close to IC U206.
                V3D3 = 3.3V
                V1D2 = 1.2V
                V????
                You need to look through a bunch of them, I can only see so much using pictures because they are so small.
                • engelwood39
                  • Mar 2015
                  • 93
                  Hey Budm,
                  Here are those voltages:
                  V3D3 = 3.226V
                  V1D2 = 1.209V
                  VGL c220R229 = -5.713V
                  C434 VOTP= 3.201V
                  WP0100=1.639
                  V12IN=0V
                  I am not sure what all you want me to to test? I don't see too many mor whith the (V#D#) format.
                    Are you able to find Vgh?
                    BTW 'V12IN=0V" That cannot be right, that's V input 12VDC feeding the fuse F102. It has to be measurement error.
                    • engelwood39
                      • Mar 2015
                      • 93
                      VGH= I can't find a Vgh. Does it for sure have that?
                      recheck on V12IN=11.28
                      also
                      VSS= -6.064
                      VCOM_A 0.477
                        VGH, VGL, and many other Voltages are needed.
                        https://www.badcaps.net/forum/showth...hlight=vgh+vgl
                        https://cdn.badcaps-static.com/pdfs/...2a9b4bc15d.pdf
                        • engelwood39
                          • Mar 2015
                          • 93
                          Here is the board divided into 5 pictures under a magnifying glass.
                          They are sequential moving left to right on the board(inverted to read easier).
                          If you could let me know what values I need to get to you (and preferable what pic # they are in) that would be great. Thanks!
                          • Stan62
                            • Jun 2016
                            Hello, I'm new here. Please tell me How do you post a 'new' thread?
                              I believe the IC U209 AUO-P301-16 is the one that produces the VGH, VGL Voltages similar to the TI chip. I need find the spec sheet for to verify, so far I cannot locate the VGH point, it should be in that area.
                              http://wenku.baidu.com/view/72d64d2f...950e73832.html
                              • engelwood39
                                • Mar 2015
                                • 93
                                Go to the forum you want to post in and click on the Forum Tools drop down on top right. Then choose start new thread.
                                • engelwood39
                                  • Mar 2015
                                  • 93
                                  Do you think it would be a good start to replace the T-Con board and see what happens since neither side of the screen works when I unplug a ribbon cable off of the T-Con board? Or if I replace both the T-con and Main board do you feel pretty good about it probably fixing the TV?
                                    I would try new T-CON.
                                    • engelwood39
                                      • Mar 2015
                                      • 93
                                      It's ordered. I will get back to you.
                                      • CapLeaker
                                        Leaking Member
                                        • 8352
                                        For me it would be the oscilloscope. Problem is having one, or knowing someone that has one... other than that, it is changing the main board, hoping it isn't a bad panel.
                                        • csmith
                                          Vizio D50u-D1 Powers up no picture
                                          by csmith
                                          I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
                                          Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
                                          supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
                                          issue. Set will power up with remote but not power off....
                                          07-11-2025, 11:52 AM
                                        • sergio_av
                                          Acer Aspire E5-571G-52NH powers on, no picture. PCH_ENVDD goes off and on.
                                          by sergio_av
                                          Hi, I'm unexperienced with troubleshooting and I'm not sure how to proceed with this laptop.
                                          Motherboard is A5WAH LA-B991P I think, i5-5200U and nvidia 820m.
                                          When I received the laptop, CMOS battery had 0V. I took it out and all the testing has been done without a CMOS battery and without the main battery plugged in, I haven't been able to see physical damage, burnt or missing components with a quick visual inspection, and no shorts were found.
                                          Laptop charges the battery, powers on when ON button is pressed when powered from charger and when powered from the battery, but...
                                          01-01-2025, 05:27 PM
                                        • KYBOSH
                                          Trying to Save - LG 60PH6700 60-inch plasma HDTV - Powers ON but no picture
                                          by KYBOSH
                                          Saved this beast from the landfill this weekend.
                                          Manfactured July 2013 in Mexico.
                                          I love working on plasma TVs.
                                          Its been a while but I was lucky enough to find 2 this week.
                                          The TV powers on and stays on but no picture. Havent checked for sound yet.
                                          No bulging caps although the insides are pretty dusty and the boards are discolored from many years of high heat.
                                          Will start troubleshooting tonight.
                                          10-17-2024, 01:17 PM
                                        • Tr0ll
                                          by Tr0ll
                                          Original T-con:
                                          First replacement T-con:
                                          10-07-2023, 07:48 PM
                                        • JJAAMM
                                          by JJAAMM
                                          Problem
                                          07-06-2023, 06:01 AM
