westinghouse dwm50f3g1 powers up with no picture
  • engelwood39
    • Mar 2015
    • 93
    Re: westinghouse dwm50f3g1 powers up with no picture
    Okay, got the new T-Con board and put it in. turned the unit on and the Westinghouse emblem came up... However it was a static hum about 1 second long and then 1 second no hum then the hum again for a second. Every time it made the sound there were horizontal lines through the emblem on the picture. I quickly turned it off and made sure all connections were tight (which they were) and tried it again. Nothing! It is now back to a dark dim lit blank screen? Any ideas?
    • engelwood39
      • Mar 2015
      • 93
      Maybe it would be better described as an electrical hum. It was coming from a component on the T-con board I am pretty sure.
      • engelwood39
        • Mar 2015
        • 93
        Any suggestions at all? Would a main board replacement be worth a try?
        • dskall
          • Oct 2016
          • 2905
          • usa
          I think you have problem on panel side that blew out your t-con
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8352
            A replacement main board wouldn't change that. I think you got a bad panel.
            • dskall
              • Oct 2016
              • 2905
              • usa
              #26
              Originally posted by budm
              I believe the IC U209 AUO-P301-16 is the one that produces the VGH, VGL Voltages similar to the TI chip. I need find the spec sheet for to verify, so far I cannot locate the VGH point, it should be in that area.
              http://wenku.baidu.com/view/72d64d2f...950e73832.html
              budm I think VGH is pin 22, VGL looks to be in lower left corner
              • engelwood39
                • Mar 2015
                • 93
                So, time to call it quits and junk this TV!???
                [TV]
                  At this point it looks like the panel took out your new T-CON board.
                  • CapLeaker
                    Leaking Member
                    • Dec 2014
                    • 8352
                    [TV]
                    unfortunately yes.
                    • csmith
                      Vizio D50u-D1 Powers up no picture
                      by csmith
                      I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
                      Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
                      supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
                      issue. Set will power up with remote but not power off....
                      07-11-2025, 11:52 AM
                    • sergio_av
                      Acer Aspire E5-571G-52NH powers on, no picture. PCH_ENVDD goes off and on.
                      by sergio_av
                      Hi, I'm unexperienced with troubleshooting and I'm not sure how to proceed with this laptop.
                      Motherboard is A5WAH LA-B991P I think, i5-5200U and nvidia 820m.
                      When I received the laptop, CMOS battery had 0V. I took it out and all the testing has been done without a CMOS battery and without the main battery plugged in, I haven't been able to see physical damage, burnt or missing components with a quick visual inspection, and no shorts were found.
                      Laptop charges the battery, powers on when ON button is pressed when powered from charger and when powered from the battery, but...
                      01-01-2025, 05:27 PM
                    • KYBOSH
                      Trying to Save - LG 60PH6700 60-inch plasma HDTV - Powers ON but no picture
                      by KYBOSH
                      Saved this beast from the landfill this weekend.
                      Manfactured July 2013 in Mexico.
                      I love working on plasma TVs.
                      Its been a while but I was lucky enough to find 2 this week.
                      The TV powers on and stays on but no picture. Havent checked for sound yet.
                      No bulging caps although the insides are pretty dusty and the boards are discolored from many years of high heat.
                      Will start troubleshooting tonight.
                      10-17-2024, 01:17 PM
                    • Tr0ll
                      by Tr0ll
                      Original T-con:
                      First replacement T-con:
                      10-07-2023, 07:48 PM
                    • JJAAMM
                      by JJAAMM
                      Problem
                      07-06-2023, 06:01 AM
