Not sure of the resistor value of this
  • R_J
    • 9624
    Re: Not sure of the resistor value of this
    If the picture is tilted, you would need to rotate the deflection yoke, after all this time and heat it will be stuck to the crt neck, loosen the clamp holding it to the neck and try rotating it, if its not out that much don't wory about it. Don't be too concerned about the yellow marks not being lined up, many times that was just a starting point reference, check the rgb convergence in the center of the screen, if its ok then you don't have to change them, The first two tabs closest to the yoke are for purity adjustment
    I dought that c310 is bad.
    If you replace the c310 and you see the lines thats because that cap is in parallel with the yoke and changes the impedence of the yoke circuit and slightly increases the deflection, so I would go after the 2 electrolytics in the output circuit.
    If the lines are just slightly noticable at the botom, it might just need the vertical height adjusted slightly, there should be about 3/8" of overscan aprox.
    If c403 looses value slightly , it can cause the picture to not fill the screen properly. try replaceing it, c304 might also affect the vertical size slightly.
    • petehall347
      • Jan 2015
      • 4450
      • United Kingdom
      i just looked at the pic again and it looks level to me at the lower screen ...upper right looks pulled up so those shift plates might need a nudge like i mentioned earlier ....
      the factory marks are not aligned ...
      just remember where they are before moving them ..
      am thinking its the ones closest to back of tv that will shift the picture .
      its been a long time since i messed with one ..
      also looks like height might need a tweak as well . probably a pot on main pcb for that .
      • R_J
        • 9624
        moving the convergence tabs won't tilt the picture, they are for r.g.b. convergence at the center of the screen (see manual page 7) to turn the picture you need to turn the yoke. To adjust the height you need to go into the service menu, Page 10 in manual (page 6 of service menu) there are no adjustments on the chassis itself.
        There looks like a VCENT (on page 9 of service menu) that could adjust the whole picture down slightly fixing the lines at the bottom an showing more of the top os the screen.
        • ducky29
          • Dec 2015
          • 369
          • Europe
          Originally posted by korotoyo
          How can I do this? When you say "deflection coils block", do you mean the yoke?
          I loosen the screw on the clamp and I tried to rotate the yoke but it won't move. Probably because of the white adhesive between the yoke and the black padding on the tube. I'm not sure how to proceed.
          No don't realign it.Those things never move unless you change the entire screen.I think it can be fixed through the service menu.
          • R_J
            • 9624
            There is NO tilt adjustment in the service menu, That yoke was most likely crooked from day one, (seen it many times) If its that tight to the neck of the tube you could end up either breaking the yoke coils from the plastic or worse break the crt neck.
            Some large crt tv's 32" plus had a tilt adjustment but those tv's had an extra coil seperate but close to the yoke, and a seperate drive circuit. this 14" won't have that
            The amount of movement needed to correct this amount of tilt is very little, it won't even break loose of the silicone on the wedges, Try and turn it a bit by grabing it on the plastic near the front of the yoke, but be carefull not to touch the coil.
            • korotoyo
              • Jan 2017
              • 25
              • Philippines
              #26
              Originally posted by budm
              0.033uF 5% Tolerance, 100V, Polyester film (more likely).
              Does it show as bad? Leakage resistance?
              What is leakage resistance? How do you check for it? I'm assuming I need a special tool for this like an ESR Meter or something?
              What are the tools I need to properly check a bad capacitor?
              Yes I tried the service menu mode and couldn't find any tilt settings. I did not notice or mind the tilt issue when I bought it new maybe 3 years ago because it was just for watching local channels but I'm not surprised if it's tilted like this from the start.
              I did exactly that way even with a rubberized gloves but it's too stuck on the white rubber-like silicon adhesive. I can move it a bit but since it's too stuck it will just go back to its original position when I let go. Can I do it while the TV is on?
              • korotoyo
                • Jan 2017
                • 25
                • Philippines
                #27
                No, the whole picture is tilted. Maybe because of the angle I took the picture. Top and bottom right corners are pulled up while the top & bottom left corners are pulled down.
                • korotoyo
                  • Jan 2017
                  • 25
                  • Philippines
                  #28
                  Under service menu mode I can adjust settings like vertical height, horizontal pos, vertical pos, etc..but I'd like a picture guide for it. Is a 640x480 test image pattern be fine?
                  • R_J
                    • 9624
                    That silicone should come loose quite easily, just make sure the clamp on the neck is loose, and yes you can adjust it when its on just be careful of the bare connections on the yoke, they will bite Like I said it should not have to rotate the yoke very far to make the picture straight, maybe 1/2 a degree. a 640x480 pattern should work, give it a try and see what it looks like
                    • keeney123
                      Lauren
                      • Sep 2014
                      • 2536
                      When working on this type of TV the fly-back transformer should be grounded at all times. This can be done from chassis ground. A jumper with a alligator clip to ground and a wire clipped on the other end of the jumper onto the blade of a insulated handled screwdriver . The screwdriver blade should be a flat tip very small in diameter. The blade is inserted under the rubber circular flap while holding the insulated handle of the screw driver until one hear a snap. Then the wire clip is removed from the blade of the screw driver. This wire clip is then attached under the rubber flap to the metal wire and left there all the time one works on the TV. When you get ready to test the TV you will first remove the jumper. If you are going to work on the TV again you would follow the above procedure.
                      • petehall347
                        • Jan 2015
                        • 4450
                        • United Kingdom
                        #31
                        did you try degaussing it ?
                        also did you try rotating the tv ?
                        • korotoyo
                          • Jan 2017
                          • 25
                          • Philippines
                          #32
                          I did it!
                          My screen looks better now.
                          The only thing I did wrong is that I accidentally set the "INITIAL" service mode setting but all good now. One setting I cannot bring back is when the tv is manually switched on I can just plug in the power cord and it will be on. Now when I plug in the power cord I would need to use the remote control to turn it on. Anyone knows what the service setting code for it?
                          Thank you all guys! Next move is to replace the caps. But I hope someone can suggest a tool or something for testing or detecting bad capacitors.
                          • R_J
                            • 9624
                            If the set is on and you unplug it, and plug it back in does it come on then ? I don't see a setting for that in the service menu
                            So you say you changed the value on page 17 "initial" from 00 to something else?
                            You might try changing Page 15 "HOTEL" from 00 to 01 and see if that does it
                            Also check in the regular tv menu and see if there is a setting
                            • korotoyo
                              • Jan 2017
                              • 25
                              • Philippines
                              #34
                              Yes it does turn on automatically before. And yes I changed the "INITIAL" value maybe to 00 which caused the screen to reset.
                              Changed the "HOTEL" to 01 but it's the same. No setting on regular menu.
                              • R_J
                                • 9624
                                What about the settings (page 15) for Mode0 & Mode1 are they the same as in the manual?
                                This is what a different model has, in op4 (1) is where you would set that option.
                                • korotoyo
                                  • Jan 2017
                                  • 25
                                  • Philippines
                                  #36
                                  I tried some values for the Mode0 & Mode1 but nothing works.
                                  I've gone over all the service menu pages but couldn't find anything related to op4.
                                  • R_J
                                    • 9624
                                    Ah the old, should have writen down the original values, or took screen pictures. I guess you could always shoot off an email to Changhong, other than that I don't know.
                                    One page 1 there is a opt Optional Setting but I have no idea what it does either
                                    • korotoyo
                                      • Jan 2017
                                      • 25
                                      • Philippines
                                      #38
                                      Yeah I know. I only took pictures of page 6 & page 7, the ones I changed values from.
                                      Thank you all guys for the help!
                                      • reessi
                                        ACER BM320 Monitor - Horizonal Flickering Lines After a While
                                        by reessi
                                        The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
                                        They are black on the right and gradually fade to nothing on the far left.
                                        They start either after 5 mins or up to 2 hours after so annoying for testing.
                                        They flicker continuously very fast! With a slight pause milli-second every second.
                                        Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
                                        I tested each half by removing the first the left flex from...
                                        06-03-2025, 09:58 AM
                                      • arctor
                                        LG 55uh661v flickering images and lines
                                        by arctor
                                        Hi, I have this tv a LG 55UH661V that show flickering images and lines. I tried to take off one at time the right and the left ribbon cable and put the tape for ask the pin…but nothing working. Or I stop to have picture or still flickering. Someone can help me to understand what pin I have to mask? What I notice the buffering board, the flat cable becomes very hot, I don’t think it s normal, I’m talking about the orange flat cable soldering on the buffering board, both side are very hot. I give you the photo with both the ribbon cable on and a photo with the right off and with the lefts...
                                        06-16-2025, 11:57 AM
                                      • EffiSon
                                        Lenovo Y50-70 - LA-B111P Rev:1A Flickering laptop screen after shorten the R205 resistor/ backlight restoration ?
                                        by EffiSon
                                        Hi. Could anyone on the forum help me find the cause of the problem?
                                        The board is LA-B111P Rev:1A comes from Lenovo Y50-70.
                                        I have a identified the damaged R205 resistor, and connect a jump wire over it So it restores the backlight but causing strange problems
                                        1. With Battery ONLY plugged in laptop works fine
                                        2 .With Charger ONLY plugged in laptop works fine as well
                                        3. Connecting both battery and charger at the same time shows a strange flickering screen. The flickering is not constant, it is completely random (and I think it depends on the load
                                        01-29-2024, 04:03 PM
                                      • Guybrush
                                        Dell U3419W horizontal lines and flickering
                                        by Guybrush
                                        After watching too many electronics repair videos (but not monitors) I came across a dell monitor with flickering horizontal lines. I haven't purchased it yet so don't have much info, but from the video and pic do you think there is a chance of repair or is just simple panel damage?
                                        Seller claims; "but due to sun damage has some grey lines going through it"
                                        https://i.imgur.com/VpTcZFn.mp4
                                        Chris...
                                        10-23-2023, 06:17 PM
                                      • howardc64
                                        by howardc64
                                        07-24-2025, 05:17 PM
