Re: Not sure of the resistor value of this
If the picture is tilted, you would need to rotate the deflection yoke, after all this time and heat it will be stuck to the crt neck, loosen the clamp holding it to the neck and try rotating it, if its not out that much don't wory about it. Don't be too concerned about the yellow marks not being lined up, many times that was just a starting point reference, check the rgb convergence in the center of the screen, if its ok then you don't have to change them, The first two tabs closest to the yoke are for purity adjustment
I dought that c310 is bad.
If you replace the c310 and you see the lines thats because that cap is in parallel with the yoke and changes the impedence of the yoke circuit and slightly increases the deflection, so I would go after the 2 electrolytics in the output circuit.
If the lines are just slightly noticable at the botom, it might just need the vertical height adjusted slightly, there should be about 3/8" of overscan aprox.
If c403 looses value slightly , it can cause the picture to not fill the screen properly. try replaceing it, c304 might also affect the vertical size slightly.
