70" Sharp display has blinking rectangles
+ More Options
Posts
  • neferkamichael
    • Jan 2017
    • 9
    I have a LC-70LE632U Sharp LCD tv and when you turn it on even without a video signal half the screen to the right has several vertical rectangles of various shades of gray,plus some horizontal flickering and half way from the middle to the left several vertical rectangles similar to the right except lighter shades and 4 inch's from the left side of the screen vertical columns of red, green and blue dots. There is no blinking code indicating a problem and you can see a picture so there may be no problem producing a signal. Any help would be greatly appreciated, thanks
    neferkamichael
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: 70" Sharp display has blinking rectangles
    Prob the lcd panel itself--Sharp 70" suffer a fair bit from buggered panels...
    TELEFIX
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      +1
      • budwich
        • Jul 2015
        • 3097
        search this forum for sharp 70 threads... it is likely saveable back to almost as good as new.
        • neferkamichael
          • Jan 2017
          • 9
          Alastair, I've been reading post and learning. Is there only one lcd panel. Thanks
          • bajdik
            Sharp LC-40LE830E white blinking after wallplug is off
            by bajdik
            Hello, on Sharp LC-40LE830E is everything OK. Working great. If I put the 230 V off and on again, it just blinking white standby LED. I can power on only via VOL- and CH+ and POWER button on TV. After that, I can power off and power on again without problem (by buttons or remote control) until the 230 V is connected. If i put the plug off and on again, just white standby LED blinking. TV needs three button starting again.. On the first look, the backlight looks great, no darker or lighter spots. Any idea what is wrong?
            07-21-2023, 09:05 AM
          • ninja_zx11
            Sharp LC-70LE650U vertical black and red bars
            by ninja_zx11
            70" LED TV is Sharp LC-70LE650U.
            Initial problem was horizontal lines and slow motion lurrs on the bottom left of the screen. So I removed both the left and right ribbon cables from the T-con board and tried to clean it with alcohol and when I put it back, this issue appeared. I tried carefully reinserting the ribbon bon cables but same thing. I checked the traces of the ribbon cables with magnifying glass and everything looks good. I cleaned the small jumper ribbon cable on the left side of the screen which cured the horizontal line and slow motion blurs...
            07-07-2023, 11:27 PM
          • cm0002
            Sharp LC-55N7000U 1 long 5 short blinking, no display
            by cm0002
            I've got a Sharp LC-55N7000U. It has a standbuy LED when plugged in, but powering it on causes it to blink 1 LONG and 5 FAST. Theres no display and no backlight.
            Nothing I checked has that blink pattern for Sharp TVs and there's only one multi-button on the TV itself so that service menu trick involving the input button doesn't work either. Its a post-Hisense buyout TV so that probably makes sense lol
            I've tried disconnecting the panel sides from the TCON alternating sides, but no change in behaviour even when the whole TCON is disconnected,...
            06-19-2023, 06:21 PM
          • valvashon
            Sharp LC19SB24U; red vertical line comes and goes
            by valvashon
            Yes, this is a very old Sharp 19" but I would like to fix it if possible. As you can see from the attached picture there is a single red vertical line.
            Yesterday when I turned the set on, it was there for about 30 minutes then disappeared and did not show up again (set was on for another 3 hours or so).
            Today it was not there when I powered the set on, then appeared after about 15 minutes. Set has been on for about an hour and it's still there.
            From what I have read I'm guessing that this might be the t-con board and not the display itself as it does come and go.
            02-03-2023, 10:02 AM
          • Charrlie
            Sharp Lc-70le734u blinking 2 long 5 short
            by Charrlie
            Just picked up this sharp tv not too long ago and it started not wanting to start the other day, giving me the notorious 2 long-5 short blink pattern indicating a power issue. I was able to force start it a handful of times (once the tv has fired up it has no issue running for 5+ hours). But now as of yesterday, no matter what I try to do button combination wise, I just receive the same blinking code.
            So I busted into it and have done the following:
            -Removed the power board and inspected for any bad caps, burn spots etc. Do not see any instances of such ...
            07-07-2022, 02:02 PM
