thank you very much
Eeprom dump thread!
This is a sticky topic.
Hello.
My TV is a QE65Q800TATXXC Samsung TV.
Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
Any ideas to check would be very appreciated 😊
After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump it.
You can find the dump attached to this message in zip format.
Can you please check this eeprom ? and may be correct it ?
Thank you very much for your help.
Manu
BN41-02752A MAIN AV BOARD BN41-02752A (BN94-00038G) - SAMSUNG
BN44-01068A LED DRIVER BOARD
BN95-06565A T-CON
BN44-01073A Power boardAttached FilesComment
EPROM help me please
television model; QN55Q70RAG
motherboard model; BN41-02695A
IC1502-IC1503-IC801- IC701 EMMCComment
Try this one, it's a dump from Akai though, the remote might not fit...Comment
Hello Lotas,
Thank you for the dump. I test the Akai dump but it doesn't work.
It could possible that the firmware is not the same on board TP.S506.PB801 and TP.S506.PB818.
I will test the 2nd file today. If i will send you the dump of my TV, could you fix it?
Thank a lotComment
Hello Lotas,
Thank a lotAttached FilesComment
Hello Lotas,
Thank a lot for your file, the TV works again. You are the best !!!
Hello Lotas,
ThanksComment
Hello again need firmware via usb because the tv goes to boot loop. It says not enought space and I couldn't make anything. Tv is Toshiba model 32la2063dg/2.1 PhotoComment
Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
Yesterday, 03:24 PM -
by (0)_(0)Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...02-17-2022, 09:09 PM -
by my2k2Good day to every one,
I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
Does anybody have an eeprom dump file? I really appreciate any help.
Thanks in advance.-
07-01-2024, 09:04 PM -
P14s Gen 2
HT4B0/HP4B0/HT5B1/HT4B2
NM-D352 Rev 1.0
sn PF-35P15W
Requesting thunderbolt dump
also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....-
Channel: BIOS Requests ONLY!
by Ancient1Hi
I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
Right distribution board, 2 Flexs, near them:
The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
I... - Loading...
