Eeprom dump thread!
This is a sticky topic.
I think we had a missunderstanding, I had the two files, but something had gone wrong when I edit my post to correct some speeling and the two files somewhat deleted themself, so here you go:
I dont know the difference between mine and yours throughtAttached Filesif you find these attachements useful please consider making a small donation to the site
Try.Attached Filesif you find these attachements useful please consider making a small donation to the site
HI I am looking for the motherboard firmware 17MB97 VES480UNVS -2D-M05 panel thanks in advanceComment
Try
Hello.
My TV is a QE65Q800TATXXC Samsung TV.
Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
Any ideas to check would be very appreciated 😊
After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump it.
You can find the dump attached to this message in zip format.
Can you please check this eeprom ? and may be correct it ?
Thank you very much for your help.
Manu
BN41-02752A MAIN AV BOARD BN41-02752A (BN94-00038G) - SAMSUNG
BN44-01068A LED DRIVER BOARD
BN95-06565A T-CON
BN44-01073A Power boardAttached Filesif you find these attachements useful please consider making a small donation to the site
Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
07-26-2025, 03:24 PM -
by jorpecHi, all
I need the dump/firmware for this tv, it was on a boot loop, i dont have the original corrupted dump because i used a pen drive with a firmware that solved the boot loop, initially it seemed it was ok but the tv has no sound
Thanks -
by my2k2Good day to every one,
I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
Does anybody have an eeprom dump file? I really appreciate any help.
Thanks in advance.-
07-01-2024, 09:04 PM -
by (0)_(0)Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...02-17-2022, 09:09 PM -
P14s Gen 2
HT4B0/HP4B0/HT5B1/HT4B2
NM-D352 Rev 1.0
sn PF-35P15W
Requesting thunderbolt dump
also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....-
Channel: BIOS Requests ONLY!
- Loading...
