Eeprom dump thread!
This is a sticky topic.
  • Gjackson
    • Aug 2021
    • 134
    • Malta
    #1701
    Anyone have a dump for a SHARP lc-55sfe7332e?
    Thank you
    • lotas
      • Jan 2016
      • 4865
      • Russia
      #1702
      Thank you
      Mainboard T.MS6308.711?
      What problem do you have in your firmware?
      • Gjackson
        • Aug 2021
        • 134
        • Malta
        #1703
        Bootloop
        • lotas
          • Jan 2016
          • 4865
          • Russia
          #1704
          Bootloop
          What motherboard do you have (number), what panel?
          Dump what you need, Nand?
          Post your non-working dump here, I'll take a look.​
          • univers73
            • Nov 2020
            • 13
            • france
            #1705
            Originally posted by univers73
            I need to flash the eeprom of this tcon :
            Model : Samsung QE55Q80RAT
            Tcon : BN94-14062G
            Eeprom : 25Q40CLSIP
            Thanks.
            Please ? 😢
            • lotas
              • Jan 2016
              • 4865
              • Russia
              #1706
              Tcon : BN94-14062G
              Eeprom : 25Q40CLSIP
              Thanks.
              Motherboard (textolite) bn41-02695a?
              What's the problem with your dump?​
              • univers73
                • Nov 2020
                • 13
                • france
                #1707
                The tv won't turn on, every voltage are present, checked the screen, backlight... It started with the TV randomly won't turn on, light present, no blinking. I can't check the motherboard's model right now.
                • lotas
                  • Jan 2016
                  • 4865
                  • Russia
                  #1708
                  But this could be a problem with eMMC, post your 24Q40 firmware here and I’ll take a look.
                  • univers73
                    • Nov 2020
                    • 13
                    • france
                    #1709
                    Thank for your help, here the dump. By the way, also a pic of the model.
                    • lotas
                      • Jan 2016
                      • 4865
                      • Russia
                      #1710
                      Your dump is working, try yours, but with a cleared nvm.
                      • univers73
                        • Nov 2020
                        • 13
                        • france
                        #1711
                        I just tried, still no boot, i will continue my research, thank anyway for you help.
                        • univers73
                          • Nov 2020
                          • 13
                          • france
                          #1712
                          I have a last question, I have another eeprom on this tcon witch it contains the firmware (25q80), it is possible that it can be corrupted ?
                          • cccamgeek
                            • May 2009
                            • 13
                            #1713
                            hard to find new come dumped from working set
                            "Haier LET29C800" OR "MGS eled29"
                            same in two brand name :
                            main MSDV3218-ZC01-01
                            Mainboard/chassis: MSDV3218-ZC01-01
                            Painel display LCD: V290BJ1-PE1
                            Dump flash SPI 25Q32
                            • kamaku
                              • Jul 2014
                              • 6
                              • Spain
                              #1714
                              Someone can check , After logo it restart again.
                              model: OK ODL32661HN-DIB
                              Main: TP.MS3663S.PB818
                              Panel HK315LEDM
                              • lotas
                                • Jan 2016
                                • 4865
                                • Russia
                                #1715
                                Panel HK315LEDM
                                Try with a clean NVM.
                                • lotas
                                  • Jan 2016
                                  • 4865
                                  • Russia
                                  #1716
                                  Does not work?
                                  • kamaku
                                    • Jul 2014
                                    • 6
                                    • Spain
                                    #1717
                                    Yes was not working, "power-up, logo and reset" .
                                    Finally loaded the firmware for one "ok odl 32631H-SB EL" from post https://www.badcaps.net/forum/troubl...64#post1683821 , worked only remote control is diferent and used one universal one.
                                    • Ipyong tech
                                      • Jan 2022
                                      • Phillipines
                                      #1718
                                      hello,
                                      I have samsung tv UA65NU7300g no power, no standby light but if i remove the connector of motherboard the backlight is working and 12.8 volts is present. need help for dump file of IC1604 25q40cl.
                                      i have backup of the original file. can please check my dump if its ok. Thank you.
                                      Hello.. Master lotas.. need your help. thank you
                                      • lotas
                                        • Jan 2016
                                        • 4865
                                        • Russia
                                        #1719
                                        Originally posted by Ipyong tech
                                        hello,
                                        Mainboard ?
                                        I don't see a problem with your dump, it's working.
                                        • Ipyong tech
                                          • Jan 2022
                                          • Phillipines
                                          #1720
                                          thank you.. master lotas for checking my dump... now i know that my dump is good. the problem maybe somewhere in motherboard.
