Eeprom dump thread!
This is a sticky topic.
  • MF ELETTRONICA
    • Jun 2024
    • 41
    • italia
    #1801
    ho il programmatore t56 e uso xgprog
    • MF ELETTRONICA
      • Jun 2024
      • 41
      • italia
      #1802
      I have the t56 programmer and I use xgprog
      • lotas
        • Jan 2016
        • 4862
        • Russia
        #1803
        It’s clear, as dump was considered, click on status reg. and you will see in the window where there will be checkmarks, that’s what your spi flash is currently set to.
        • MF ELETTRONICA
          • Jun 2024
          • 41
          • italia
          #1804
          hi lotas i found the problem is in the nand the tv flashes and does not turn on if i send you the dump of my nand can you see if you fix it? thanks
          • MF ELETTRONICA
            • Jun 2024
            • 41
            • italia
            #1805
            http://www.mfelettronicasestri.it/DEADfile/MT29F4G08ABAEAWP@TSOP48.rar
            I attach the link to the nand file if you can take a look thanks
            • MF ELETTRONICA
              • Jun 2024
              • 41
              • italia
              #1806
              i left link above nand can you check it out Lotas? thanks
              • lotas
                • Jan 2016
                • 4862
                • Russia
                #1807
                I don't have access to this resource, please upload it to another file hosting service.​
                • MF ELETTRONICA
                  • Jun 2024
                  • 41
                  • italia
                  #1808
                  yes do it like this copy link and open page and paste link you will see that it works otherwise send me your email
                  • MF ELETTRONICA
                    • Jun 2024
                    • 41
                    • italia
                    #1809
                    if you open a new page and paste the copied link it works
                    • lotas
                      • Jan 2016
                      • 4862
                      • Russia
                      #1810
                      Ok, it worked.
                      • lotas
                        • Jan 2016
                        • 4862
                        • Russia
                        #1811
                        Try it, clear it from bit errors...https://drive.google.com/file/d/1utt...-rVkhZ3E9/view
                        • MF ELETTRONICA
                          • Jun 2024
                          • 41
                          • italia
                          #1812
                          I tried lotas but it doesn't work.... only thing is I didn't clean the bits.... sorry how do I clean it from the bits??? but I think it doesn't work
                          • MF ELETTRONICA
                            • Jun 2024
                            • 41
                            • italia
                            #1813
                            lotas can you give me a hand? please
                            • lotas
                              • Jan 2016
                              • 4862
                              • Russia
                              #1814
                              How can I help, what do I need?​
                              • MF ELETTRONICA
                                • Jun 2024
                                • 41
                                • italia
                                #1815
                                Originariamente pubblicato da MF ELETTRONICA Visualizza post
                                ciao lotas ho scoperto che il problema è nella nand la tv lampeggia e non si accende se ti mando il dump della mia nand puoi vedere se lo risolvi? grazie
                                Provalo, puliscilo dagli errori di bit...
                                ho provato questo file che mi hai inviato credo lo hai modificato? ma non funziona non ricordi?
                                English ???
                                • MF ELETTRONICA
                                  • Jun 2024
                                  • 41
                                  • italia
                                  #1816
                                  https://drive.google.com/file/d/1utt...-rVkhZ3E9/view​
                                  I tried this file you sent me I think you modified it? but it doesn't work, don't you remember?
                                  • lotas
                                    • Jan 2016
                                    • 4862
                                    • Russia
                                    #1817
                                    Yes, I remember everything, I cleared dump nand for bit errors (ECC), it didn't work for you either, now how can I help?
                                    I also have firmware for recovery via usb, but VES315WNDS panel, but you have a different panel.
                                    • MF ELETTRONICA
                                      • Jun 2024
                                      • 41
                                      • italia
                                      #1818
                                      so there is nothing you can do? I thought you could act on the ignition issue... I tried another one with the same card, the TV turns on but it looks bad and upside down
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4539
                                        • Italy - Milan
                                        #1819
                                        Hei.. this is an eprom dump thread.. can.you.open.a.separate thread?
                                        • MF ELETTRONICA
                                          • Jun 2024
                                          • 41
                                          • italia
                                          #1820
                                          sorry and how do I do I don't know how to open it
