Eeprom dump thread!
This is a sticky topic.
  • lotas
    • Jan 2016
    • 4597
    • Russia
    #1321
    Re: Eeprom dump thread!
    25Q40, 25Q80 and 24C512 - they are all on the motherboard, 25Q32 on the panel does not need to be touched.
    25Q40, 25Q80 is spi flash, 24C512 is eeprom.
    • totof
      • Feb 2017
      • 157
      • france
      #1322
      Exactly, I hadn't found the 24C512 but with a magnifying glass it was better.
      On the other hand, I reflashed the 3 components and unfortunately it didn't change anything, the result is the same.
      • lotas
        • Jan 2016
        • 4597
        • Russia
        #1323
        You also asked for 24С512, maybe eMMC is covered with you (they have a certain service life).
        • totof
          • Feb 2017
          • 157
          • france
          #1324
          If eMMC problem in this case I must translate that it is not repairable ?
          • lotas
            • Jan 2016
            • 4597
            • Russia
            #1325
            If you have never encountered eMMC, then it is better to replace the motherboard.
            You can find any BN41-02528A motherboard (they only have different firmware for different panels), you just need to rewrite or replace the 25Q80 (where the panel settings, T-con are located).
            • totof
              • Feb 2017
              • 157
              • france
              #1326
              I found a motherboard of the same reference extracted from a UE55KU6400 TV whose panel was broken but simply by programming the 25Q80 flash with the contents of that of my TV then the TV enters a looping start cycle
              I can try to change the eMMC but the problem will be to find the program. Is the program easy to find and what hardware is needed to program it ? Is it possible to change it and then reprogram it directly on the motherboard ?
              • cheeky2
                • Dec 2012
                • 337
                • uk
                #1327
                Originally posted by tehmatix
                Blaupunkt 32-147I-GB-5B-HBKUP-UK , tv bootloop, led red > blue > red >blue
                Desolder UF11 and use CH341 for reprogram. After , go to menu and Factory reset
                Firmware below
                What's the screen model number for this dump and the main board number?
                • totof
                  • Feb 2017
                  • 157
                  • france
                  #1328
                  I finally changed the motherboard and my TV is working again.
                  Attached are the dumps of the new motherboard
                  • shawnpsx323
                    • Jan 2022
                    • 30
                    Good Day All,
                    Looking for dump for Samsung UN49M5300AFXZA Ver.FA01. Board number BN94-12049D.
                    Assistance in getting this as I believe the original is somehow corrupted.
                    Original dump attached incase it can be fixed.
                    Thanks...
                    • shawnpsx323
                      • Jan 2022
                      • 30
                      Originally posted by shawnpsx323
                      Good Day All,
                      Thanks...
                      Anything guys?
                      Issue is that standby LED will flash 5 times. Power supply is good. I've tried another bios dumped from a similar board and the standby light stopped flashing, TV will turn on for few seconds and then turn off. So this is why I believe bios is corrupted. Any Help??
                      • mo4nis
                        • Dec 2018
                        • 53
                        • maroc
                        #1331
                        Originally posted by cheeky2
                        I have a Blaupunkt 39/210I-GB-5B-F3HBKU-EU that has a corrupted flash ic as it is stuck in standby.
                        Main board TP.MSD309.BP85
                        screen V390HK1-LS6-Rev.C8
                        Does anyone have a working dump for this model or similar?
                        The only one I could find was on the russsian site here (which I cannot register on!)
                        Thanks in advance
                        tp.msd309.bp85 flas dump
                        • muhamad.sh
                          • Apr 2017
                          • 6
                          • turkey
                          #1332
                          Originally posted by omruu9
                          your file
                          thank you so much
                          • Diamondj421
                            • Sep 2022
                            I've spent the last few days scouring the web for a new EEPROM for my Vizio E550i-B2 with no success. Does anyone have a dump for this model?
                            • whitevolf
                              • Feb 2014
                              • 122
                              • TÜRKİYE
                              #1334
                              thanks
                              • totof
                                • Feb 2017
                                • 157
                                • france
                                #1335
                                Thank you very much lotas.
                                In fact I can't fully test the binaries because I don't have the TV at home, I only have the electronic boards and the LED bars.
                                The second binary (ue55mu6105_ic1604_II.bin) doesn't work, I don't even have the standby led.
                                On the other hand, the first binary (ue55mu6105_ic1604.bin) seems to work: I have the standby LED, the tv turns on with the remote control and the backlighting turns on fine. On the other hand, to test the image, I will have to wait to return to my parents and it will only be in several weeks.
                                I will post back to the forum at that time.
                                Hello
                                Two months later I was able to return to my parents home and test the programming of the motherboard.
                                The TV restarted without any problem and the picture is perfect.
                                Thank you lotas
                                • lotas
                                  • Jan 2016
                                  • 4597
                                  • Russia
                                  #1336
                                  Hello
                                  Thank you lotas
                                  Hi, glad it worked out.
                                  • jimbofz
                                    • Apr 2013
                                    • 539
                                    • uk
                                    #1337
                                    here is the corrupted philips bin file
                                    65pus6162/05
                                    sorry i cant seem to upload .bin file
                                    can somebody advise please
                                    • jimbofz
                                      • Apr 2013
                                      • 539
                                      • uk
                                      #1338
                                      hope this is correct
                                      • lotas
                                        • Jan 2016
                                        • 4597
                                        • Russia
                                        #1339
                                        65pus6162/05
                                        And why is this size small, what chip did you read the dump from?
                                        • jimbofz
                                          • Apr 2013
                                          • 539
                                          • uk
                                          #1340
                                          cct ref U409
                                          M24128 BRMN6TP
                                          this is from the cct diagram
                                          the number on the chip is difficult to read
                                          :128br 713t with green paint on pin 1
                                          • AlexGsmMaster
                                            Eizo CS2740 eeprom dump, search.
                                            by AlexGsmMaster
                                            Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
                                            07-26-2025, 03:24 PM
                                          • (0)_(0)
                                            Looking for a HP Photosmart C4280 EEPROM dump
                                            by (0)_(0)
                                            Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
                                            The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...
                                            02-17-2022, 09:09 PM
                                          • my2k2
                                            Harman Kardon AVR 171, Request for IC1504 (24C32) eeprom dump file
                                            by my2k2
                                            Good day to every one,
                                            I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
                                            Does anybody have an eeprom dump file? I really appreciate any help.
                                            Thanks in advance.
                                            07-01-2024, 09:04 PM
                                          • Whale linguini
                                            p14s Gen 2 thunderbolt eeprom dump
                                            by Whale linguini
                                            P14s Gen 2
                                            HT4B0/HP4B0/HT5B1/HT4B2
                                            NM-D352 Rev 1.0
                                            sn PF-35P15W
                                            Requesting thunderbolt dump
                                            also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....
                                            09-03-2024, 01:56 PM
                                          • Ancient1
                                            Before I dump this Panel...
                                            by Ancient1
                                            Hi
                                            I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
                                            As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
                                            Right distribution board, 2 Flexs, near them:
                                            The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
                                            The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
                                            I...
                                            10-23-2022, 11:07 AM
