Eeprom dump thread!
This is a sticky topic.
  • antas
    • Jul 2014
    • 148
    • Ireland
    #841
    Re: Eeprom dump thread!
    Anyone, can help me with EEPROM, please?
    Looking for:
    WALKER WPS3219SM
    Mainboard: 17MB211S
    Chip: Winbond 25Q16JVSIQ
    Panel model: VES315WNDB-2D-N21
    Thank you in advance...
    • yokoono
      • Apr 2010
      • 511
      #842
      Try (Toshiba). Main 17MB211S panel VES315WNDB-2D-N21
      • antas
        • Jul 2014
        • 148
        • Ireland
        #843
        Tryied this just now.
        Unfortunately, it doesn't work on this model... Thanks for trying to help me...
        • yokoono
          • Apr 2010
          • 511
          #844
          Try this too. It is for 17MB211S panel VES315WNDS-2D-N21. If the image is returned I have the profile saved for fixing.
          • antas
            • Jul 2014
            • 148
            • Ireland
            #845
            Not working....
            • yokoono
              • Apr 2010
              • 511
              #846
              I think there is another problem on the motherboard. Most often problems with dc-dc converters or processor. See also if the flash memory is powered by 3.3v.
              What are the symptoms of television?
              • antas
                • Jul 2014
                • 148
                • Ireland
                #847
                Thanks for coming back to me.
                Yes, there are 3.3v on the chip (EEPROM). 12v and 5v are on the board as well.
                The red light is on and blinking 2 short times in intervals.
                Backlight is working OK.
                • yokoono
                  • Apr 2010
                  • 511
                  #848
                  Don't confuse eeprom memory with flash memory !!!. They are different. See what memory you rewrote. The software is for flash memory, spi.
                  • antas
                    • Jul 2014
                    • 148
                    • Ireland
                    #849
                    Sorry. I rewrote Winbond 25Q16JVSIQ (U135)
                    • yokoono
                      • Apr 2010
                      • 511
                      #850
                      How does the defect manifest itself?
                      • antas
                        • Jul 2014
                        • 148
                        • Ireland
                        #851
                        TV not turning ON. When you turn TV ON, RED light up and stay solid. When you push ON button, RED light blinks 2 times and stay solid. Then blinks 2 times again and stay solid. And does this all the time.
                        PS.: Backlight I checked with the mainboard from Panasonic TV. Backlight working, just can't turn ON the TV.
                        • yokoono
                          • Apr 2010
                          • 511
                          #852
                          Heat the processor to 230 degrees for 1 minute and see what it does.
                          I think the motherboard has a hardware issue not a software one.
                          You can replace the memory with another new memory.
                          • antas
                            • Jul 2014
                            • 148
                            • Ireland
                            #853
                            Heated for 1 min at 230 degrees. Nothing. Still the same problem...
                            Do you mean I have to replace Winbond 25Q16JVSIQ with new one?
                            • yokoono
                              • Apr 2010
                              • 511
                              #854
                              Try. Rewritten. I have no other ideas.
                              • antas
                                • Jul 2014
                                • 148
                                • Ireland
                                #855
                                Thank you so much for your time, buddy
                                • jose almeida tavares
                                  • May 2011
                                  • 8
                                  #856
                                  Blaupunkt w40/58j-gb-fhcup-eu memory dump
                                  Hello, i need memory dump for this tv. the mather board t.msd309.8b 10304 and panel lta400hm07. thanks.
                                  • Farasa
                                    • Jul 2016
                                    • 47
                                    • South-Africa
                                    #857
                                    hello everyone i just got this set in...37 inch Telefunken chassis... 40-1MS82D....I dont have the panel number...I need the dump for this board....thanks in advance
                                    • Farasa
                                      • Jul 2016
                                      • 47
                                      • South-Africa
                                      #858
                                      Anyone at home
                                      • Rajnhl
                                        • Oct 2018
                                        • 94
                                        • India
                                        #859
                                        Originally posted by Farasa
                                        Anyone at home
                                        try this one
                                        • Farasa
                                          • Jul 2016
                                          • 47
                                          • South-Africa
                                          #860
                                          Thanks for this firmware...ill try it and report back
