RCA led32c45rqd found to have a bad main board so I bought one off ebay and it works however the picture is now upside down. Nothing in the TV settings to change this. all the connectors fit only 1 way except for the one to the TCON and I tried turning it around but then no picture. Anything I can change? or do I need to send this back?
RCA Upside down
Re: RCA Upside down
You could swap the EEPROM over and hope the old one was not faulty
What's the mainboard number and panel number. Someone may have the software for it.Last edited by dick_barton; 01-25-2017, 12:56 PM.Willing to help but I'm no expert. -
Re: RCA Upside down
Did you order the board by the part number or by the model number? I know those RCA tv's usually have multiple main boards for the same model that go to different panels.
Yep. SJ shows at least 2 mains for that model that use different panels.Comment
I've literally just received in the post a UNI-T UTi260B (it's currently on charge).
After quickly scanning the user manual I see there are all sorts of configurable settings (Measurement settings, Palette settings, Point temperature settings and Image Mode). As this is my first Thermal Imaging Camera I have no idea what all these settings are nor if I need to change/configure any of them.
I intend/hope to use this to help me diagnose issues with laptop motherboards so should I just leave the settings as the default or is there someone out there with a UNI-T thermal...09-02-2025, 08:36 AM -
by garrymc123Looking for some advice changed over the video input board due to bad hdmi ports but now the picture is upside down tried the service menu but can't find anything to do with flip the picture..
Is there anything I can do to flip the picture or do I need to change the board again..
Garry... -
by Tr0llHi guys! I realized you have a lot of knowledge here so i am hoping you could point me in right direction with my odd issue.
Original T-con:
First replacement T-con:
I thought it might be t-con and ordered new t-con from china(supposedly tested)... -
by JJAAMMThis was my main TV for the last 6 years. I'm not inclined to throw out a $2600 TV so quickly so I'm trying to investigate the issue.
Problem
TV was disconnected from power for 6 months during construction. When I plugged it yesterday picture was fine, after 30 seconds it dimmed then started developing horizontal lines, picture then starts to ghost vertically until it degrades into vertical streaks. TV always displays a perfect picture when cold. I can unplug TV for 5 minutes and plug it back in and picture is restored for 20 seconds. I can also keep it in standby mode... -
by TR103Hi, I have a Samsung UE50TU with:
- it keeps rebooting
- without cable between mainboard and lcd panel and with a jumpered... - Loading...
