JVC LT-50A330 Backlights turn off after 2-5 min
  • SHADOW3277
    • Jun 2014
    • 123
    Trying to fix this JVC. It will turn on with backlights but after about 2 minutes the backlights cut off. Sometimes they cut off as soon as 30 seconds and I have timed them staying on until 5 minutes but most of the time is about 2 minutes.
    With the backlights on I have 3.2 volts at BL_ON and 2.8 at DIM. I also have the same voltages with the backlights off. I have 24 volts coming off the power supply to the LED board. Now here is the interesting thing. I have 3 test points on the LED board that have 13 volts but when the backlights cut off, the voltage jumps to 24 volts. I have attached a picture of the LED driver board with the 3 test points circled. The pin out measurements are below. I am leaning towards the LED Driver board being bad but just want to check that I haven't missed anything. Thanks
    CN1 PS to LED driver
    Backlights On OFF
    Pin 1 VBL 24v 24v
    2 VBL 24v 24v
    3 VBL 24v 24v
    4 VBL 24v 24v
    5 VBL 24v 24v
    6 GND 0 0
    7 GND 0 0
    8 GND 0 0
    9 GND 0 0
    10 GND 0 0
    11 ERR 0 0
    12 BLON 3.2 3.2
    13 NC 0 0
    14 E_PWM 2.8 2.8
    CN2 LED driver to led's
    Backlights On OFF
    Pin 1 FB2 0.3v 0v
    2 FB1 0.6v 0v
    3 PT 2.0v 4.7v
    4 CNT 4.8v 4.9v
    5 VCC 5v 0v
    6 SGND 0 0
    7 NC 0 0
    8 VBL- 0 0
    9 VBL- 0 0
    10 NC 0 0
    11 VBL+ 0 0
    12 VBL+ 0 0
    13 NC 0 0
    14 E_PWM 2.8 2.8
  • CapLeaker
    Leaking Member
    • 8325
    Re: JVC LT-50A330 Backlights turn off after 2-5 min
    Turn down your back lights and see if they stay on longer? If it does, you may have a LED going bad. Or a loose / bad connection cold solder joint somewhere.
    Check the DC Voltage of each LED string on and then again when the error occurs.
    Somehow the VCC 5V is gone and the FB's are down to zero.
    • ducky29
      • Dec 2015
      • 369
      • Europe
      Is it a Vestel power supply?
      • SHADOW3277
        • Jun 2014
        • 123
        Capleaker - So you're thinking it's a bad LED and not the driver board? I can't take the panel off today to get to the LED's so I'll have to check them out this weekend.
        ducky29 - No idea.
          There is a slide switch on that LED driver board, did you try to see what it does?
          CMO 27-D063847 (VBT70118.00) LED Driver
          http://www.shopjimmy.com/cmo-27-d063847-led-driver.htm
          Pictures provided by shojimmy.
          The VBL+/- is high frequency AC output.
          To me it looks like there may be another board inside the panel.
          BTW, what is the P/N of that U2 on that LED board? OZ??????/
          • SHADOW3277
            • Jun 2014
            • 123
            budm - my board doesn't have that switch. It's also a different part number but both were used for the same panel. Here is my board
            http://www.tristatemodule.com/VIJ370...ij37001.00.htm
            Only difference between the 2 I see is that slider switch.
              Do you have the LCD panel model number?
              • SHADOW3277
                • Jun 2014
                • 123
                V500HJ1-L01 Rev.C1
                  Something is not right, the more I look at that driver board and the spec of the LCD panel. TV cosumes over 200W, that does not sound right for LED LIGHTS TV.
                  http://www.beyondinfinite.com/innolux/v500hj1-l01/
                  It show as CCFL. that board is supply AC to inside the panel, I believe there is another board (Balancer) inside the panel.
                  It does not use LED backlights.
                  • SHADOW3277
                    • Jun 2014
                    • 123
                    That would make sense. The TV is bulky like an LCD but that LED driver board made me think it had LED's. Never seen an LCD with one before. I'll tear it down to the panel this weekend and check out the balancer board.
                      I do not know why just about every sellers of the called it LED driver board when the output at VL+/- is high (but not in the 1KV) range Voltage AC.
                      • CapLeaker
                        Leaking Member
                        • 8325
                        So I went looking. Indeed that is a LCD TV. I think SJ has an error as it sez it is a LED driver board?
                        • osrex
                          LED DRIVER KEEPS DYING
                          by osrex
                          Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
                          i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
                          i have no datasheet at all for the LED lights, all i have is its length.
                          long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
                          as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
                          05-05-2025, 03:36 PM
                        • u666sa
                          HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
                          by u666sa
                          Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
                          Platform: ipa32 la-m024p rev 1b
                          Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
                          I found a short on the other side:
                          Today, 05:03 PM
                        • Spongebob89
                          LCD Backlights Driver - Unknown Component
                          by Spongebob89
                          I have an "LCD Backlights Driver" and it is not working. After measurments and checking the routes of the PCB I beleive that this component on the red circle is a choke for filtering the supply voltage and block noise from the inverter to go back to the main board. When I measured in ohm and in diode mode with multemeter shows always OL. I shortcircuit this component and it worked. The current that I measured with multemeter is 550mA, so I want rated current 1,5x550mA=825mA~1Α. Am I right that this is a choke and if yes what value do you beleive is (maybe 15uH or the...
                          07-22-2023, 02:59 AM
                        • Superbee_dad
                          Sharp 80” long short flash backlight error - Help
                          by Superbee_dad
                          Hello Sharp TV experts
                          Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                          > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                          > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                          01-24-2025, 11:51 PM
                        • howardc64
                          Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                          by howardc64
                          Problem
                          Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                          Model & Board Pics
                          Conflicting Spec
                          Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                          https://www.shopjimmy.com/vizio-gj-2k1...
                          10-10-2024, 01:16 PM
