Samsung un32h5203 No Power to Backlight
  • realdealthill
    • Nov 2016
    • 53
    I have a BN44-00768A power supply that gets power,but not to both backlight leads
    Checked voltages from Main Board to Power Supply. All Checked Good
    I have a Standby light
    I see no signs of bullgin/swollen Caps
    I see no signs of burnt out components
    I have 2 sets of wires that go directly from the PSU to the led strips
    With Tv on , and led strips unplugged from PSU. I get 145v on right. and 0v on the left.
    I Get the same results with the led strips plugged in also.
  • thoma
    • Sep 2012
    • 268
    Re: Samsung un32h5203 No Power to Backlight
    Wait until Get manual appears!!
    Disconnect cable mainboard power supply!What happens?
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Is the rest of the set working, sound, picture using bright light on screen?
      • CapLeaker
        Leaking Member
        • 8326
        You have 2 LED strings on CNL802.
        You measure 145V on one pair and 0V on the other with the LEDs disconnected? Then there is something wrong with the LED driver circuit.
          Are you measuring the Voltage at the LED connector with the black probe to the chassis GND?
          Pictures provided by shopjimmy.
          http://www.shopjimmy.com/samsung-bn4...led-board.htm#
          • realdealthill
            • Nov 2016
            • 53
            I get an image, no backlight
            Tried with mainboard dissconnect, just the same results
            I used the the chassie as ground when checking voltage
            Where is my led driver?
              https://www.badcaps.net/forum/attach...0&d=1485273273
              Top left is the LED power supply/control circuit.
              The LEDs are connected in series so when you disconnect the LED connector you will only get the Voltage reading on pin 1 only (that is the Anode of the LED string).
              Right now you have open circuit in the LED string.
              • realdealthill
                • Nov 2016
                • 53
                Yep. that's what i was thinking. but the only one side getting voltage threw me off. Because there is no board or wires connecting the strips inside the chassis
                  It will be similar to this panel:
                  https://www.badcaps.net/forum/showthread.php?t=51251
                  • realdealthill
                    • Nov 2016
                    • 53
                    This is my Panel.
                      You have 24 LEDs, if I remember correctly on this model, they 6V LED (DUAL LED in one package).
                      As you can see, you have two wires per strip and they are terminated in series connection at the LED connector on the power supply board.
                      • CapLeaker
                        Leaking Member
                        • 8326
                        Weird setup. Never had seen a termination like that.
                        • tdis
                          • Dec 2017
                          Someone in my building threw out a UHN32H503AF. Outside impression is that it doesn't turn on.
                          Inside logic board seems to have power. LED D+ signal has ~145 volts vs 94 something volts spec. S+ and S- terminals are tied to each other by the power PCB and at ground potential. There's a scorched spot on the power PCB in the LED area, near a diode, but the diode checks good, and I don't think the FET underneath is zapped, though something on the PCB obviously got very hot.
                          Am I right in thinking that this model has two LED strips in series, joined by the S+ and S- traces, and that those are at 0v and the D+ too high because the "top" LED string is open?
                          How exactly does one remove the back raised metal chassis on one of these to get into the LED strip area?
                          (FWIW I design low voltage electronics and write firmware for a living - so I have the tools including scope and surface mount rework capabilities, but have never worked on an LCD TV before).
                          • tdis
                            • Dec 2017
                            Ah well, got the trashed un32 apart to find several singed looking LEDs.
                            Alas a flashlight reveals no a picture, but instead many small cracks in the screen.
                            So whatever the original failure was, it now has at least two and I think my dreams of a "free" monitor are over.
                            Grabbed the speakers, will probably yank out the LED strips since at least some of the pixels are likely still good, debating if I want the circuit boards as well.
                            • C152Heavy
                              by C152Heavy
                              Summary for TL-DR readers:
                              • VCC pin (18) of PFC...
                              01-11-2023, 02:53 PM
                            • PantherDave
                              by PantherDave
                              Hi all!
                              05-29-2024, 02:01 PM
                            • Mgiffune
                              by Mgiffune
                              06-09-2024, 10:28 AM
                            • BoardHoarder
                              XBR-65X850D Backlight/Power On Help
                              by BoardHoarder
                              Currently trying to save a 65” 850D that definitely has a main board issue. Power supply has standby voltage and PS ON pin shows 3.5VDC but main has no signs of life…..no light under Sony logo and no optical port lit up. 12VDC is created by main board but no input triggers from main = no TCON 12V and no BL ON voltage present. I know about the trick of pulling the main to trigger the test pattern from the TCON but I get no backlight. If I jumper the 3.5VDC to TCON ON and BL ON, I can shine a light on the panel and see solid green, red, blue and white cycling. The 4 + backlight pins on the power...
                              02-09-2024, 11:00 PM
                            • GLISIT
                              by GLISIT
                              01-16-2025, 02:29 PM
