Samsung UE32F5300 blank screen, backlight OK (bad t-con?)
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Good day folks, so the title pretty much explains it: got this Samsung UE32F5300 which doesn't display any picture. The backlight comes on just fine (you can see it through the holes in the back), but there's no picture at all, no logo or anything. The TV appears to be working, because I can hear some beeps when using the remote, to which it responds perfectly as well. Entering the service menu made no difference (INFO>MENU>MUTE>PWR). Is it the T-con that's bad or perhaps the panel ? The fuse on the T-con is fine and I get 12v after it. Would it be worth buying a new Tcon for it or is the fault likely somewhere else ? :|
    Wattevah...
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Samsung UE32F5300 blank screen, backlight OK (bad t-con?)
    it you disconnect one at at time the top t con ribbon cables what do you see on each side of the screen
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      • Romania
      Oh yeah, I forgot to mention, already tried that: nothing AT ALL, regardless of which one I pull out. Also, that T-con board is not upside down, so the ribbons going to the panel are at the bottom not the top
      Wattevah...
      • vinceroger69
        • Mar 2012
        • 6714
        ok so have you checked the bottom lcd panel pcb for fluid damage from when people clean the screen
        • Dannyx
          CertifiedAxhole
          • Aug 2016
          • 3912
          • Romania
          No, I haven't yet, though if that were the case, I would've expected to at least see some lines or artefacts or something...
          Wattevah...
          • vinceroger69
            • Mar 2012
            • 6714
            yes true i guess but still might be worth checking just to rule it out as being faulty.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Check my RUNTK5351 thread out, common issue with these tcons.
              • vinceroger69
                • Mar 2012
                • 6714
                https://www.badcaps.net/forum/showth...sung+UE32F5300
                • Dannyx
                  CertifiedAxhole
                  • Aug 2016
                  • 3912
                  • Romania
                  Already found it, thanks anyway. I can access the link much quicker for future reference now
                  Wattevah...
                  • Dannyx
                    CertifiedAxhole
                    • Aug 2016
                    • 3912
                    • Romania
                    Heeeey, you're right....I actually had this issue before and I remember that IC. I actually swapped one and managed to get a set going again....silly me Thanks for the refresher mate
                    Wattevah...
                    • Dannyx
                      CertifiedAxhole
                      • Aug 2016
                      • 3912
                      • Romania
                      Just measured the 3.3v test point and it's dead and so are VGH and VGL, obviously, so I'm pretty sure the ISL9860 is bad - nice and straightforward hopefully
                      Wattevah...
                      • Dannyx
                        CertifiedAxhole
                        • Aug 2016
                        • 3912
                        • Romania
                        Just replaced ISL9860 and same thing unfortunately. Even worse, it blew the fuse this time and I get a short between GND and that VCC1.2v test point, even with the ISL and FET201 removed. Admittedly, my mate didn't do that good a job at soldering the new ISL in place, so it's possible that some of the pins touched each other *gulp*...
                        Wattevah...
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Doh I always check them with a little scope to make sure nothing is shorted.
                          • Dannyx
                            CertifiedAxhole
                            • Aug 2016
                            • 3912
                            • Romania
                            I did the same thing.......right after he tried it on and the screen flashed for a second before going black again. The chip was slightly askew and taking a closer look, I could see a few pins just about touching two pads at once, which might explain the blown fuse.
                            Wattevah...
                            • CapLeaker
                              Leaking Member
                              • 8214
                              If there is no picture on the screen I always check the LVDS with a oscilloscope first. Just like Reecey already said.
                              • Dannyx
                                CertifiedAxhole
                                • Aug 2016
                                • 3912
                                • Romania
                                I think he meant "scope" as in "loupe/magnifier", though an oscilloSCOPE would indeed be handy....don't have one of those yet, sadly
                                Wattevah...
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  Yes man magnifier lol
                                  • CapLeaker
                                    Leaking Member
                                    • 8214
                                    Seems you do quite a bit (so what I gather in this forum), so yes... at a certain point there is no excuse of not having one. It will take you to a different level of troubleshooting things. I certainly have to have one and without it I feel like something is missing. Also a little 'loupe' as or any visual magnifier is getting to be a must. Things are still getting smaller and unfortunately my eye sight isn't anymore that what it used to be either.
                                    • Dannyx
                                      CertifiedAxhole
                                      • Aug 2016
                                      • 3912
                                      • Romania
                                      Sadly, scopes are still VERY expensive (at least where I live) and we're still a small business, so it would take quite some time before such a device would pay for itself...I'm thinking of getting my own scope, but can't really afford to blow so much money on one for the same reasons. That's all beside the point though - our main priority is this T-con board which I believe my buddy fried....will take the whole set downtown to a chap who has an identical T-con board to see if it at least fires up.
                                      Wattevah...
                                      • HTR-Informatique
                                        by HTR-Informatique
                                        02-09-2025, 06:51 AM
                                      • Spoonicks
                                        ASUS VH238T blank screen with backlight
                                        by Spoonicks
                                        I am having a problem with a ASUS VH238T.
                                        The monitor started by just going blank, but the integrated speakers, and the backlight worked. The OSD didn't pop up, neither did the messages of DVI No Signal, nor the Asus logo.
                                        Turning off the monitor, and turning it back on made no difference. But leaving the monitor off for a few hours returned the monitor back to normal. The problem will eventually return after a couple of hours.
                                        Today, it started exhibiting another symptom: the display started showing a white image, that didn't take the whole screen....
                                        07-04-2023, 01:29 PM
                                      • turmix
                                        AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                                        by turmix
                                        Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                                        The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                                        At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                                        During another reassembly, I made a mistake, and...
                                        01-29-2024, 03:48 AM
                                      • Chrissygizmo
                                        by Chrissygizmo
                                        02-10-2025, 12:33 AM
                                      • FallenOne008
                                        Asus G712L No Screen Backlight
                                        by FallenOne008
                                        Hi everyone, hope all is well. I have run into a problem where my backlight screen is no longer working.
                                        The original screen was beginning to show signs of faultiness. I believe it was part of the inverter board that was going bad. The backlight for the screen was still functional at this point. Well one night as I was tinkering with the laptop, my idiot self forgot to disconnect the battery from the motherboard. I attempted to reconnect the EDP cable onto the motherboard, and as you might guess, I saw a nice spark from the cable and the port. Don't worry, I'm still kicking myself...
                                        03-31-2025, 08:27 PM
