Samsung curved UE55H8005 no picture
    Re: Samsung curved UE55H8005 no picture
    I suspect it is T-CON as well, since the backlights are present when you disconnect the small cable from the T-CON but no image on the screen.
      Hmm, shopjimmy does not have the pictures of you power supply board.
      https://www.badcaps.net/forum/attach...7&d=1485189009
      Can you zoom in on the that connector so I can read the pinout chart of the connector?
      I hope you do not have shorted panel.
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        I didn't read the previous properly....BTW Curved TVs will be phased out soon together with 4K....think there is something called HDR on the market now.
          HDR; High Dynamic Range has been around for quite a while and right now the 8K is in the work.
          • Diah
            • Feb 2013
            • 6607
            he turn on the set while the cable out of dimm which are same time protect sync for backlight. LG did the protect with LED indicator on PWB Samsung copy it but they cant put it as LG so they integrated at T-CON , the smell was gone from the switch protector IC ( shorted )as it switch (- )to LEDs and T-CON circuit.
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              #26
              Originally posted by budm
              hdr; high dynamic range has been around for quite a while and right now the 8k is in the work.
              +1
              • PowerAmpFreak
                • 982
                • Sweden
                #27
                Please summarize your diagnosis. You believe the T-CON is not the main failure?
                • Diah
                  • Feb 2013
                  • 6607
                  Now 100% T-CON should be repaired or replaced. take out the black shield and spot good photo to show you the protect circuit.
                  any test you make only the LED cable white and blue out from PWB circuit,
                    Post 22 request.
                    • PowerAmpFreak
                      • 982
                      • Sweden
                      #30
                      Post 22 request.
                      Yes, request noted.
                      I will have access to the set again tomorrow
                      • PowerAmpFreak
                        • 982
                        • Sweden
                        #31
                        I still cannot understand why the tcon will experience a hardware failure if the connector housing PWM1-3 signals is disconnected? Please explain.
                        • thoma
                          • Sep 2012
                          • 268
                          Wait until Get Manual appears!!
                          • PowerAmpFreak
                            • 982
                            • Sweden
                            #33
                            Thoma, Thanks for that link!!
                            • PowerAmpFreak
                              • 982
                              • Sweden
                              #34
                              The training guide mention there should be 3 blue leds lighting if all OK on tcon. I am sure it was only 2 so I still suspect the tcon to be the main problem in this case. A new tcon will arrive soon.
                              • PowerAmpFreak
                                • 982
                                • Sweden
                                #35
                                Close pictures of failed T-CON (no short can be found) and the PSU connector
                                  So the six wires from the T-CON to the power supply board are connected to which pin on the power supply board?
                                  I see 4 PWM pins 2, 3, 4, 6.
                                  Since shopjimmy does not have good clear pictures of this power supply board, can you please provide the straight shot of top and bottom side of the board.
                                  So it looks like the T-CON sends the PWM control signals to the LED DRIVER driver circuit, the LED current return lines are not through the T-CON otherwise you will see POWER MOSFETs on the T-CON and it will be stupid design and the LED will not light up if the LED (-) return is on the T-CON, how can it light up when you disconnect that small connector on the T-CON.
                                  The PWM controlled MOSFET for the LED returns are on the power supply board, T-CON only sending the PWM signal for the active backlights control based on the scene of the images.
                                  That T-CON board is not cheap.
                                  • PowerAmpFreak
                                    • 982
                                    • Sweden
                                    #37
                                    The six wires contolling led pwm is connected to pin 1-6 on the psu connector. it's possible to see a bundle of 6 wires hanging away from the rest of the wires.
                                    Attached picture of top and bottom side of the PSU board.
                                    • Diah
                                      • Feb 2013
                                      • 6607
                                      you have 3 LED on T-CON you said was only 2 ON. i think one was on near the Fuse and which one the other ?
                                      did you see the back side PWB cold area the 2 IC of backlight control got smoke so i can see from the photo !
                                      • PowerAmpFreak
                                        • 982
                                        • Sweden
                                        #39
                                        I can't recall which one of the two close blue leds on t-con was on. At least, the one close to the fuse was on.
                                        There's no smoke from the backlight control IC's, it's PCB coating to help for isolation!
                                        • PowerAmpFreak
                                          • 982
                                          • Sweden
                                          #40
                                          So today new T-CON arrived, but still no change.
                                          I tried to enter T-CON testmode (pattern generation) but does not show anything at all.
                                          Must then be bad panel...
                                          Still 2 leds only on T-CON (should be 3)
                                            09-07-2024, 05:50 AM
                                          • TR103
                                            by TR103
                                            - it keeps rebooting
                                            01-22-2025, 04:12 PM
                                          • JJAAMM
                                            by JJAAMM
                                            Problem
                                            07-06-2023, 06:01 AM
                                          • shelby5041
                                            Samsung LCD TV no picture backlight on no 12v at tcon
                                            by shelby5041
                                            hi
                                            i have a samsung lcd tv
                                            it powers on with sound and backlight but no picture
                                            all voltages from PS are good 12v 3.3v and 5v
                                            whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
                                            i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
                                            no 12v at the tcon fuse
                                            i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
                                            the odds of having 2...
                                            10-08-2021, 08:21 AM
                                          • howardc64
                                            Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
                                            by howardc64
                                            TV was fixed just after removing Samsung's rear snap cover.
                                            This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
                                            Maybe PSU->backlight connector didn't have a good contact?...
                                            07-23-2025, 12:34 AM
