Samsung UN50J6200 purple streaks / double image
  • hiroo
    • May 2015
    • 14
    Posting this for a friend:
    Samsung UN50J6200 recently went to purple streaks and double images. The problem persists on all HDMI inputs and when the TV menu is accessed.
    Almost immediately after turning the TV on:
    About 5 seconds later:
    About 10 seconds later:
    And now:
    Any suggestions on a diagnosis?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Samsung UN50J6200 purple streaks / double image
    Panel fault could be shorted MLCC on driver pcbs.
    • hiroo
      • May 2015
      • 14
      any suggestions on fix possibilities or is panel replacement the only route?
      • fcisolutions
        • Jan 2017
        • 205
        Got the same problem, has anybody had a resolution. Tried a new T-Con, didn't fix. Do you think it could be a panel.
        • dick_barton
          • Aug 2015
          • 6642
          • Wales
          As ReeceyBurger 123 said has all the looks of a panel fault.
          • CapLeaker
            Leaking Member
            • 8146
            I agree with Reecey and dick above.
              +1, Bad panel.
              • Cornito
                Samsung UE55RU8000 reboot and then double image after heating up
                by Cornito
                Hello team,
                I'm back with another tv and another problem.
                I try to improve my knowledge on fixing TV, and all technics used until now are not fixing correctly the problem.
                First, reboot issue, I use tape Method to find out the right side that cases the issue.
                Then using this it's working for quite 1hour30, then at some point of time the image became double on the bottom for half the screen.
                Then double image reduce in height and move to the top.
                The image is like folded on around 1cm and the bottom has been moved to the top by 1cm.
                When I...
                03-31-2024, 01:37 PM
                09-07-2024, 05:50 AM
              • howardc64
                TCL 49S405 double image
                by howardc64
                LCD displays a 2nd image slighty offset vertically. And multiple pairs of black lines along the bottom. Probably common as google "TCL 49S405 double image" pulls up this ifixit post ( link ) with identical ( nearly, but their fault seems to be on the other half of the panel than mine ) problem without solution.
                This one looks to be a more difficult to diagnose because most? of TCON seems integrated ( CSOT BGA on buffer baord) into the left panel edge board ( looking from rear of TV) There are 2 buffer boards for each 1/2 of the screen. Main connects to the left buffer board...
                06-23-2025, 03:20 PM
              • shlomim412
                samsung ua55es6800 - no image
                by shlomim412
                hi
                having problem with samsung ua55es6800
                tv had backlight on, sound working - responds to the remote control but no image.
                check tcon board - had 12v in but no other voltages present.
                when disconnected left ribbon cable - got back voltages and half image with lines and distorsion
                when leaving only left side connected - again no voltages and no image.
                put a tape on all (cd?! lines) on the left ribbon cable and got complete but distorted image (horizontal lines).
                kept trying to block less pins on the left ribbon cable...
                05-15-2024, 05:00 AM
                09-06-2024, 11:40 PM
