Philips 42PF5321D/37 wSamsung S42AX panel Y-Main repair
  • steves7839
    • Nov 2014
    • 200
    Hello, I've got this TV which contains the Y-Main and Buffers reputed to short each other out. [LJ92-01200A, LJ92-01202, and LJ92-01203].
    I've read the Coppell TV blogs and several threads here regarding how to diagnose these three.
    I know the lower buffer is shorted power to common. Too many SMD pins to repair myself. I installed the Y-Main with just the good buffer. The TV still shuts itself off, so I know the Y-Main also has a failure.
    I will attach photos of the Y-Main and the area I'm troubleshooting.
    I understand from reading Coppell's blog that the shorted fet would read a lower resistance Gate to Drain than good FETs, but only lower by 100 or so ohms.
    I put black probe on Common and red probe on each of the low-value resistors in the gate curcuit. Gate to Drain resistance readings on the Y-Main with Y-Buffers disconnected:
    Resistors near the Upper Y- Buffer which appears good:
    R5085 98.4 Kohms
    R5091 98.5
    R5092 98.6
    R5029 99.3 Kohms
    Resistors near the bottom Y-Buffer which is shorted:
    R5100 98.5 Kohms
    R5101 97.6
    R5103 99.7
    R5102 97.1 Kohms
    Coppell writes that the shorted fets will just read 10-100 ohms below the others. So it looks like R5101 and R5102 are connected to the gates of bad fets. I read elsewhere that the 1" by 3" heatsink is a bear to remove.
    I also found two power diodes on heatsinks, D5012 and D5013 read a short between the outer two of three legs. Other diode check readings look like a diode or OL.
    Any concurrence of opinion or suggestions?
  • steves7839
    • Nov 2014
    • 200
    Re: Philips 42PF5321D/37 wSamsung S42AX panel Y-Main repair
    To simplify the question, can anyone tell me this:
    If I install a good Y-Main PCB LJ92-01200A and one good buffer board, leaving the shorted buffer board out of circuit, will the set stay on or go into shutdown?
    • steves7839
      • Nov 2014
      • 200
      I powered up with a new used Y-Main pcb and the one good Y-buffer board. The TV stayed on about a minute without going into shutdown. It showed picture on the half with the good buffer. It looks like I'm on the right track if I can find a good lower Y-buffer board LJ92-01203.
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Yes..You are going in the right direction...
        • steves7839
          • Nov 2014
          • 200
          Thanks, Andrew!
          I got a lower buffer at a good price on Ebay but it also has one shorted buffer IC.
          I've ordered a hot-air station. I plan to try to replace two shorted buffer chips out of the six.
          Does anyone know what part number to order?
          • steves7839
            • Nov 2014
            • 200
            Originally posted by steves7839
            ... if I can find a good lower Y-buffer board LJ92-01203.
            ... that's not shorted!
            • steves7839
              • Nov 2014
              • 200
              Got two from Payless Components on ebay. Good folks! They replaced the shorted board with a good one within days.
              Another dead plasma roars back to life!
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Good job
                • steves7839
                  • Nov 2014
                  • 200
                  I've replaced a few suspect parts on the defective Y-Main board that came with the TV. I've replaced Q5011 and a capacitor that was improperly soldered. (The set works fine with the same Y-buffers and a used Y-Main I bought for it)
                  The TV works with sound and no picture. It doesn't appear to have any backlight.
                  Ohms checks look OK and there is Vsus of 202V on the Y-sustain. The anomaly is that when I probe any of the FETS Q5005-Q5011, the audio cuts out.
                  I've examined the service manual for this panel and can't make head or tail of it. No callouts for Vsus or any other voltage higher than the audio 12 and -12VDC. The heatsink over the 7 FETS on the Y-Main is still removed so I can troubleshoot. What voltages should I expect at the FET drains and sources? What section of a y-main is responsible for the panel picture?
                  • alro7779
                    Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                    by alro7779
                    Hello, guys!
                    The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                    09-14-2025, 12:25 AM
                  • G33RT
                    Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                    by G33RT
                    Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                    It does power up when pressing the power button.
                    I already try the power button while plugin the plug with no result.
                    Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                    Could this be an PSU or eMMC issue ?
                    07-19-2025, 03:43 AM
                  • double_DD
                    Philips curling iron - is this a common AC cable?
                    by double_DD
                    Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
                    As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
                    Not sure if this is something Philips proprietary, or a standard, but the cable plug...
                    08-18-2025, 10:04 AM
                  • janos6662000
                    Philips 47PFS7509/12 LCD TV problem
                    by janos6662000
                    Hi
                    I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                    When i applied cable signal to check image, i had normal picture, but TV was restarting.
                    I downloaded original firmware and applied the update, but the problem remained.
                    From a colleague i received a "factory package software" which is a lot bigger.
                    I made another firmware update, but still did not solve the problem.
                    Somewhere on the way the error got worse, because at the moment the...
                    08-12-2025, 12:54 PM
                  • aidanmo
                    Philips 43PUS7506/12 - Loud blown out sound
                    by aidanmo
                    I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                    I thought maybe the speakers got damaged, so I replaced them - no dice.
                    • Using the internal speakers, it always happens.
                    • Using the headphone jack, it never happens.
                    • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                    02-28-2025, 03:13 PM
