fixed but got grainy/noise picture on my plasma now -LG 50PA6500
  • t333
    • 20
    • US
    last month my LG plasma 50PA6500 display turned black but sound was working,
    so after reading this forum i suspect it was either y-sustain board , or the y-buffer boards so i replaced y-sustain board first, did not worked,
    checked both y-buffer boards and found out lower one had a short IC, and that could have blown the new y-sustain board, so ordered a new y-sustain board and a new lower y-buffer board again, and now i got grainy/ snowy picture, see the pictures in this thread, ? is this panel gone bad now? any way to fix it? is there any other board i need to replace?
    any solutions? please help, I dont want this plasma to die.
    T
  • martino
    Not so "senior"
    • Aug 2013
    • 997
    • canada
    Re: fixed but got grainy/noise picture on my plasma now -LG 50PA6500
    looks to me like the z-sustain board is also faulty.
    Proud owner of dozens of broken TV's and many,many,many boards.
    Our website and passion:http://hollenhundshepherds.com/
    • classtorations
      • Jan 2017
      • 6
      • usa
      I agree. x or z main
      • t333
        • 20
        • US
        Thx..is there anyway to confirm thats its z board for sure before i order one. I do have a multimeter. Also im assuming my panel is fine..correct?
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16956
          Waking up an old thread with the same/similar issue, didn't want to start another....while mine isn't as bad as the OP's, here we go! Alright Plasma experts......I've never worked on a plasma before, I slept through the entire plasma era.... One of this model was given to me the other day. My own forum with the help of THIS THREAD helped me pinpoint the power problem; the C802 fix....
          The original cap was reading 340pF......
          I replaced that and it powers up now.....but we're not out of the woods yet...
          There's a strange pixelization/ghosting image issue now. You can see in this image, the shadow of the 'color bars' in the menu:
          A movie playing, you can still see it:
          This board had a couple puffed lytics, I replaced them and reflowed anything I found even remotely questionable. This board has been miserably hot it seems...
          I did the onboard pattern generator procedure (disconnect P231 andshort the EXT_AUTO_GEN), got the same results. I also cleaned every LVDS cable end in the set with an eraser & isopropyl alcohol. Since the onboard test tells me the panel is likely OK as well as the main board, I connected my own pattern generator for some better revealing images of the issue:
          Color bars:
          White raster:
          The pixelization is visible, as well as the color bars shadowing; but it's not very clear in the pics. The white raster also doesn't seem to be as bright as it should be....
          Now this is what the white should look like... This image actually looks good, the white square is bright, clear, and nothing there that shouldn't be.
          Next one, you can clearly see both the pixelization and the previous patterns showing through (color bars AND the white box).
          Another where it can be seen:
          I know some of you are wondering why I'm wasting my time on this.....but I just want to... It seems to come & go at times, the brighter the scene in a movie, the more noticable it is....but for the most part, it has a darn nice picture....but sometimes its nasty! It's also hard to photograph this thing and keep my ugly face out of the reflective screen!!
          Anyway, of all the threads here on this model, I never could find a definitive answer/cure for this.....so help me out!
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
          • RJARRRPCGP
            • Jul 2004
            • 6304
            We have a plasma TV, too! Despite the brand is Emerson. (I think Funai owns them)
            But it sure has been trucking along! Year on the back, is 2009.
            Who's the real manufacturer? Did Funai even do manufacturing of plasma screens, per se???
            ASRock B550 PG Velocita
            Ryzen 9 "Vermeer" 5900X
            Arc A770 16 GB
            eVGA Supernova G3 750W
            Alienware AW3423DWF OLED
            • Biruslapio
              • Nov 2013
              • 552
              • Brasil
              Could be cracked solder joints on the big inductors on Y and Z SUS boards, or poorly adjusted SET_UP and SET_DN on Y-SUS, there are several trimpots on Y-SUS, Z-SUS and the power supply, they control VS, VA, -VY, VSCAN and Z-BIAS, these voltages should match what the white panel label specifies, you don't need to adjust those unless someone messed with them before.
              There are test points on each board for these voltages.
              Match the voltages first with a white wash signal, then if that does not help remember the original position of SET_UP and SET_DN and adjust those two slowly.
              Y and Z boards screws need to be very tight.
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16956
                I did alter the RAMP_UP and RAMP_DN pots. Prior, I did mark their positions with a felt marker so they could be returned to their original positions. Both altered the view, but neither one eliminated the issue.
                Team : 49813
                Join in!!
                Team Stats
                • Biruslapio
                  • Nov 2013
                  • 552
                  • Brasil
                  What about the other voltages that can be adjusted, are they correct? Low VS can cause this type of image retention.
                  This Y-SUS is absolutely blackened in the middle, so much heat that even a capacitor managed to poof, has this board been repaired before? is Z-SUS fine visually?
                  • tvtimmy
                    • Mar 2015
                    • 1160
                    • usa
                    Does this cap on Topcat's board look bulged to anyone else?
                    • dick_barton
                      • Aug 2015
                      • 6642
                      • Wales
                      It would be worth checking but it may also be the angle.
                      • Topcat
                        The Boss Stooge
                        • Oct 2003
                        • 16956
                        It was, it has been replaced along with all those of that value (100uF 50v). That's why the board was out of the set....recapping and checking for cracked solder under all that heat.
                        Team : 49813
                        Join in!!
                        Team Stats
                        • Topcat
                          The Boss Stooge
                          • Oct 2003
                          • 16956
                          I kicked up the VS, it went away for the most part. I don't have the service manual, so I was doing this blind based on a white raster until it shut down...then backed it off a little. It is significantly better though, seems you're onto something!
                          Team : 49813
                          Join in!!
                          Team Stats
                          • RDC55
                            • Dec 2017
                            • 180
                            Guessing you are aware but just in case - lots of hits over at Elektrotanya for manuals:
                            https://elektrotanya.com/showresult?...a=All&kat2=All
                            I downloaded the top one and it appears to have alignment procedures, although fairly complicated and maybe requiring some special test equipment.
                            • Biruslapio
                              • Nov 2013
                              • 552
                              • Brasil
                              LG plasma service manuals are only good for mainboard schematics/diagrams, there's nothing about the other inner workings of a plasma, you will need a LG training manual - scan troubleshooting to get actual material about Y and Z-SUS boards, there's no training manual of PA series available online that I could find.
                              The set shut down because of excessive VS voltage, this is to protect SUS and power supply boards from erratic operation, something is interfering with VS on this TV, may be a cracked soldering joint or more bad capacitors near the area that clearly overheated on the Y-SUS.
                              I've uploaded pictures and circled test points and trimpots that adjust -VY and ZBIAS, can't find VSCAN trimpot, maybe this model doesn't have one. VS is adjusted on the power supply, should be matching the panel sticker. The main filtering inductors on Z and Y are also circled, these need have their contacts properly resoldered to the board, they often crack and introduce pink sparkling on the screen.
                              The panel sticker is an example, voltage ratings varies from model production date etc, the voltages you adjust must match what your panel specifies.
                              • Topcat
                                The Boss Stooge
                                • Oct 2003
                                • 16956
                                Thanks for all the info. I do think the coils need to be reflowed, I didn't do them on the zsus board, just the Y...and now & then I do get reddish/pink graininess....which seems to come & go, moreso when its cold....but the ghosting is gone now.
                                I definitely want to tweak it some more, but after the 'seat of my pants' adjusting, it's looking pretty good. I'll get behind it and set it correctly tomorrow....
                                Team : 49813
                                Join in!!
                                Team Stats
                                • Topcat
                                  The Boss Stooge
                                  • Oct 2003
                                  • 16956
                                  I got them all dialed in except VS. If I set VS at its prescribed voltage (205v), the ghosting & horrible red graininess comes back. Set around 210~212, that clears up, TV runs without issues. It shuts down around 215. VS feeds the ZSUS board, so my guess is whatever issue there is, is on that board. I guess it could be YSUS as well, there's a harness that goes from ZSUS to YSUS right by the feed from the PSU board.
                                  I reflowed all the coils, transistor, higher watt resistors, and anything else that was even remotely questionable.....
                                  The only mystery seems to be why the VS at normal setting yields a grainy/ghosty image.....makes me wonder if some of these higher voltage lytics have failed as well, as hot as this thing runs.... Heat and lytics aren't friends.
                                  Team : 49813
                                  Join in!!
                                  Team Stats
                                  • R_J
                                    • Jun 2012
                                    • 9535
                                    There is nothing wrong with upping the VS a few volts, The LG tech even recommended it when these were a couple years old. The panel will change over time. It is also possible there is a control board firmware update, I know they had it for certain models, but they were the earlier models.
                                    • Topcat
                                      The Boss Stooge
                                      • Oct 2003
                                      • 16956
                                      I did find a firmware dated 2013 on LG's site, the set was made Jan 2012...and I doubt the owner ever updated it. I'll do the update of course....but I don't think it'll help much unless it kicks up the VS shutdown voltage.... I see the issue potentially being more of a degraded panel perhaps....given the visible sign of heat on both YSUS and ZSUS boards, the set likely has a lot of hours on it....I've probably got it about as good as it's going to get....but overall I'm happy, perfectly watchable and my first ever battle with a plasma.
                                      One thing I couldn't find were the RAMP_UP & RAMP_DN threshold/voltages & testpoints...maybe they're not important....but I was curious.
                                      Team : 49813
                                      Join in!!
                                      Team Stats
                                      • mmartell
                                        • Oct 2013
                                        • 3189
                                        The connection going from Ysus to Zsus is probably the 15v line. It's generated on the Ysus, sometimes routed through the control board. Probably not an issue.
                                        • tofik
                                          LG 50PA6500 Plasma TV damaged after a power spike
                                          by tofik
                                          Hello, I have an LG 50PA6500 Plasma TV, purchased new in 2012.
                                          Unfortunately plasma is not working at all after a power spike.
                                          Qucikly tested the PSU and voltages seems to be okay, when eveything is disconntected from the PSU I got:
                                          VS = 200-206 / actual = 205 V,
                                          VA = 55 / actual = 54.9 V,
                                          M5V = 5.2 / actual = 5.19 V,
                                          17 = 17.24 V,
                                          5.2 = 5.19 V,
                                          STDBY = 5.19 V,
                                          ERROR_DET = 4.8 V - does it mean PSU is damaged? the rest of the voltages seems to be fine.
                                          what's your opinion about the PSU?
                                          Also I just...
                                          12-20-2022, 03:08 PM
                                        • tony359
                                          by tony359
                                          11-28-2023, 05:18 AM
                                        • MegaZAC
                                          Onkyo TX-SR805 noise in one channel
                                          by MegaZAC
                                          Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                                          Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                                          There's some logic behind it. As soon as I select an input I get only left...
                                          04-23-2025, 10:09 PM
                                        • courtcircuit
                                          Philips HTS8000 home cinema noise problem
                                          by courtcircuit
                                          Hello
                                          I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
                                          Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
                                          Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
                                          I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
                                          Removed each of tyhe boards
                                          02-08-2025, 08:22 AM
                                        • starmaxpc
                                          LG 50ps60 Plasma Grainy/Fuzzy Horizontal
                                          by starmaxpc
                                          hi fellas. i picked a freebie locally it is a lg 50 inch plasma with display issue. tv turns on i can navigate thru the side button controls volume is good channel up down etc. looking thru the other postings on this system there seems to be a variance of different issues with this model. any direction as what would cause this display issue. sorry my pics are sideways as i don't have the stand and the darn thing weighs a ton. Thanks....
                                          02-27-2021, 07:10 PM
