Panasonic TX-P42S20E
  • nbdy
    • Aug 2015
    • 162
    • Croatia
    Hi,got this plasma with 6 and 8 red flashes and with a vertical stripe
    6 are when i dissconect the ss board
    8 when all is connected
    the stripe is on left side of TV,I have unpluged the flat cable behind the stipe
    but nothing changed (exept the 6 & 8 blinking codes)
    any advice to go further
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Panasonic TX-P42S20E
    Picture of the fault please ?
    • nbdy
      • Aug 2015
      • 162
      • Croatia
      Don't have picture because of the 6 or 8 red blinking led
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        What is a vertical stripe then ?
        • Moreno83
          • Jun 2014
          • 2008
          • The Netherlands
          Please take some pictures of all the boards and a total picture of the backside of the tv.
          • Hombre
            • Jul 2013
            • 231
            • Croatia
            Well first thing is to check SC board, you can find plenty of info on board, check SC2 for shorts, also Q661.
            • Moreno83
              • Jun 2014
              • 2008
              • The Netherlands
              True but if he wants help then he needs to provide good info with pictures. It's either SS or SC board as Hobre says but even a bad SC20 cable can give 8 blinks.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Hes provided fuck all info for us so can't really help atm. Hopefully OP uses bcn and google to find out how to test voltages etc and find shorted susboards. Im not repeating threads.
                • nbdy
                  • Aug 2015
                  • 162
                  • Croatia
                  Hello,sorry for no reply (was on a field work for a long time) ...
                  Meanwhile my friend give up the fixing of this tv ...
                  Now i'm searching for a screen for a LG,but found a TX-P42S30E with a broken screen ...
                  The question is does this screen match for the TX-P42S20E to change from one to another ...
                  thx
                  • Andre Gilbert
                    by Andre Gilbert
                    11-20-2024, 08:52 PM
                  • glaw
                    panasonic th-50px-50u black vertical stripe
                    by glaw
                    Hoping to figure out if the panel is done. A week or so ago this stripe appeared on right side of display. It is there with all inputs. Pictures attached. the picture and audio are not affected. I tried disconnecting ribbon from buffer to panel and it does not change. Disconnecting the ribbon next to it yields the expected white stripe. There are vertical buffers on top and bottom therefore the 1/2 screen stripe.
                    There are green and yellow lines on top and left side of stripe and multi-color lines on right side.
                    My suspicion is that the panel is the cause because there is...
                    11-21-2020, 01:36 PM
                  • AquaMan Ua
                    Problem with PANASONIC CF53 laptop after changing BIOS settings
                    by AquaMan Ua
                    Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                    05-17-2025, 09:40 AM
                  • stecos
                    Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                    by stecos
                    Hi everyone!
                    I happened several times, in the search for help from the web, to consult this very interesting forum.
                    So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                    Having said that I come to the gist of my post on the forum as the title suggests.
                    For my passion for technology I'm now collecting several...
                    11-28-2022, 11:39 AM
                  • aa10aa10
                    Panasonic Toughbook CF-33 mk1 BIOS repair
                    by aa10aa10
                    Good day,
                    I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
                    I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
                    01-21-2025, 06:13 AM
