Samsung UA40CEH6030 No picture DONT DO THIS
  • Grunder
    • Jan 2016
    • 323
    • south africa
    Hi Guys, I know I have another unresolved thread, but I just had to post this.
    The set was presented to me, and I was informed a family member had used a hand held high voltage fly swatter on a fly that had settled on his LCD screen.
    (looks like a tennis racquet but has HV leads instead of Gut/strings).
    Disconnecting the ribbons from the Tcon one at a time I noticed that disconnecting the right ribbon (Right from the front) that I got half a picture. (see photo)
    I was convinced that the panel was faulty on the right, and that it was causing the Tcon to malfunction, giving no picture. (rnr/ uneconomical)
    However on re-assembly I noted two "pock" marks on the Tcon, that lined up with the holes for the Stand. (see photo).
    The Stand screws are not the originals, are long and obviously damaged the Tcon.
    I don't know what to make of this.
    a) only Tcon damage (Screw damage)
    b) Tcon & Panel Damage.(screw & fly swatter)
    I only see now whilst creating this thread, that a metal plate seems to be missing, (surely the stand cant only be secured by the back cover only.)
    I think the owner is Bull sh1ting me.
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: Samsung UA40CEH6030 No picture DONT DO THIS
    Well you can be lucky and only need to replace the T-con. Its definitely shorted because of the screws. Did you check the fuse on the t-con?
    I have see this before , i think a new t-con might do the trick.
    • CapLeaker
      Leaking Member
      • 8352
      with a blown fuse on the Tcon you wouldn't get a half of a picture on the screen.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Looks as though someone else has been inside and as you say used the wrong screws. The 3rd picture certainly shows that some of the tracks have been shorted to ground.
        • vinceroger69
          • Mar 2012
          • 6714
          is that the correct model number as google finds no match?
          • 102mm
            • Dec 2013
            • 181
            • us
            The plate is missing. How did the TV even stay mounted on the stand?
            Craigslist Picks & Fixes
            2 ea - Samsung 52"
            Samsung 60"
            • Grunder
              • Jan 2016
              • 323
              • south africa
              Sorry it should be UA40EH6030, without the C. How do I correct it?
              • srhofmann
                • Aug 2016
                • 135
                • usa
                Where's the cover for the T-Con, it's usually in a sheet metal can?
                Also, the T-Con should have had a sticker on it, Samsung usually puts it near the panel connectors?
                • Grunder
                  • Jan 2016
                  • 323
                  • south africa
                  I can only guess they picked up the set from the previous repairer (guilty party), and maybe laid it on the back seat of the car, and didn't notice.
                  I slot the tv's on their side face to back on booking in so I didn't notice.
                  • Grunder
                    • Jan 2016
                    • 323
                    • south africa
                    I hope so, I had actually quoted the set as
                    Returned Not Repaired/uneconomical.
                    I have informed the person, but no response so far. Must still get price from agent for T-con.
                    My only concern is that the screen was verily damaged by the fly zapper, then I've wasted money on the T-con?
                    Then again maybe the person knew, and was trying to get a damage report from me so he could screw the insurance for a new set (accidental damage). Not the first time.
                    • Grunder
                      • Jan 2016
                      • 323
                      • south africa
                      That's what I thought, I've never seen an LCD with out a "can" over the T-con.
                      And the Stands always attach to a bracket arrangement that attaches to the main frame.
                      • Grunder
                        • Jan 2016
                        • 323
                        • south africa
                        Hi Dick, yes, I should have included a photo of the screws, galvanised type screws that you would find on a kids play ground swing.
                        A bit dismayed that I had concluded that the panel was faulty, then again I was going on the person's information. Misled unfortunately.
                        • Grunder
                          • Jan 2016
                          • 323
                          • south africa
                          Thanks all the responses, might be awhile before I have a resolution, going to let the repair simmer awhile, and see what response I get from the person.
                          • zomi
                            • Nov 2011
                            • 513
                            I have seen this a few times now.
                            Worng stand screws going into t con
                            Key note
                            If the screws appear too long or not original ones.
                            Go straight to the tcon and look for damage
                            Very evident on some hitachi lcd
                            where there is few mm clearance with the original screws.
                            • CapLeaker
                              Leaking Member
                              • 8352
                              I think the fly zapper crap story is a cover up. I would ask him where he hit the LCD screen with it, without telling him which side doesn't work.
                                09-07-2024, 05:50 AM
                              • TR103
                                by TR103
                                - it keeps rebooting
                                01-22-2025, 04:12 PM
                              • JJAAMM
                                by JJAAMM
                                Problem
                                07-06-2023, 06:01 AM
                              • shelby5041
                                Samsung LCD TV no picture backlight on no 12v at tcon
                                by shelby5041
                                hi
                                i have a samsung lcd tv
                                it powers on with sound and backlight but no picture
                                all voltages from PS are good 12v 3.3v and 5v
                                whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
                                i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
                                no 12v at the tcon fuse
                                i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
                                the odds of having 2...
                                10-08-2021, 08:21 AM
                              • Dodgethis
                                Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                by Dodgethis
                                Hello all,
                                This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                09-11-2024, 07:39 AM
