Samsung LE32R88BD LCD TV – No picture or sound
  • GeoW
    • Jan 2017
    • 23
    The screen on this TV is totally black with no light around the edges, and there is no sound. The red power on light is blinking, but there is no clicking sound. I have changed the power supply board (BN44-00155A) for a tested recon one bought from a TV repair Co, but that has made no difference. I removed the T-Con board (320WTC2LV3.7) and noticed that IC17 and IC15 on it (circled red in the image) look to be leaking around the legs. Can a faulty T-Con board stop the sound as well as the picture? I have uploaded images of all the boards and would be grateful if any of the experts on here could advise me if they notice any other problems.
    Thanks.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Samsung LE32R88BD LCD TV – No picture or sound
    The picture of the Tcon is not well focused so cannot really see what you are referring to but I doubt if that's the problem.
    You need to take some voltage readings at the connectors on the power supply to see what voltages / control signals are missing.
    They are normally labelled so if you could give the label names and associated readings I'm sure help will follow.
    • GeoW
      • Jan 2017
      • 23
      Thanks, Dick. I'll take a look at this when I get some time.
      • GeoW
        • Jan 2017
        • 23
        I have attached the power supply readings for this LCD TV. I would be grateful for any help to identify the problem. Thanks!
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          It looks like your Back light On signal from the main board is missing.
          Do you have a DVD player with SCART that you could plug in. When a SCART plug is in, the TV often automatically connected to the DVD so you should be able to hear sound.
          Also with a bright light shone on the screen look very carefully to see if you have a picture which I suspect you have if only the backlights are not working.
          • GeoW
            • Jan 2017
            • 23
            I'll have to borrow a DVD player with SCART lead tomorrow. I tried it with a laptop with HDMI, but got nothing. Which of the reading indicates it could be the back light on signal is missing? If it is that, is there a fix?
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              One step at a time.
              BL=0.04V backlights off
              BL =>3V Backlights On
              • GeoW
                • Jan 2017
                • 23
                I have tried the DVD player with SCART lead on the faulty TV, but I get no sound and see no picture when I shine a bright light onto the TV. The DVD player does work as you stated when I attach it to a TV that is working.
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  Disconnect the main board from the power supply
                  Connect a 1K resistor from 5V Standby to PS
                  Connect a second 1K resistor from 5V Standby to BL
                  Do your voltages come up and your backlights come on.
                  If not try connecting the second 1K resistor from 5V standby to BLU instead.
                  If your backlights and voltages are there then it looks like a main board fault.
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    press the mute button etc on the remote control just incase someone has already muted the sound im sure this is one of the samsung models that used to suffer corrupt eeproms on them not sure if it would stop just the backlight i remember shorting pins 5 and 6 on theses ics to fix diffrent issues
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      Good point.
                      Or even the volume is turned down. Inputting via the SCART always works for me to check for sound, volume up, down, mute so that you know some of the set functions are working or not.
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        dick have you ever tried a scart lead between two tv sets does this prove anything in a situation like this? ie displaying a good picture on working tv if you have a source input on the faulty tv im sure i have read a thread regarding this in fault finding etc not sure it it works or proves anything though?
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          I have never tried it but like you have seen it in a thread on here.
                          • GeoW
                            • Jan 2017
                            • 23
                            I can see where I need to make the connections, but are there any images on here that show how to clip the resistor to the pins to hold them in place? Also, when the connection is made to BL, does the plug from the PS to the inverter still need to be in place?
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              • uk
                              when you disconnect the connector fron the mainboard end just push the resistor lead in to the connector socket just make sure you use the right holes/pins and yes leave ps to the invertor plug attached.
                              like in this picture
                              • GeoW
                                • Jan 2017
                                • 23
                                Ok, cheers for that, Vince. I'll give it a go when I get some 1k resistors.
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  • uk
                                  if you need some quick pop to your local maplin as they sell them.
                                  • GeoW
                                    • Jan 2017
                                    • 23
                                    I have carried out the steps above. I got no backlights when the 1k resistor was connected to either BL or BLU, and the power readings were as follows:
                                    PS (3.45V); SB (5.15V); BL (1.72V).
                                    BLU (1.72V and the other readings were the same as above).
                                    Thanks.
                                    • dick_barton
                                      • Aug 2015
                                      • 6643
                                      • Wales
                                      I would think you have a backlight problem. You indicate that you have all the supplies 5V, 12V & SB
                                      Can you check you have 24V at both side of the white ceramic fuse on the inverter board just above where it says 125V/7A
                                        We need better pictures of the Inverter board.
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • iglitare
                                          Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
                                          by iglitare
                                          i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
                                          Backlight seems to work, Sound (Setup menu after reset) works.
                                          If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
                                          Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
                                          With my small knowledge i would think at least the cables are good.
                                          Can this happen because of a bad tcon board?
                                          Or is it always a bad/shorted...
                                          09-04-2025, 07:13 AM
                                        • jchang
                                          Samsung UN70NU6900F no picture and no sound
                                          by jchang
                                          Hi all
                                          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                          Symptom:
                                          No picture no sound.
                                          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                          No sound at all.
                                          What I tried:
                                          1. I tried unplugging the left or right ribbon...
                                          01-09-2023, 06:28 PM
                                        • Dodgethis
                                          Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                          by Dodgethis
                                          Hello all,
                                          This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                          09-11-2024, 07:39 AM
