Samsung LE32R88BD LCD TV – No picture or sound
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    #41
    Re: Samsung LE32R88BD LCD TV – No picture or sound
    Yes, unfortunately that indicates a mainboard problem which is failing to provide the backlight On signal.
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      #42
      i wonder if its worth doing a eeprom reset as could be corrupt i guess theres various threads im sure ive read you can short pins 5 and 6 and it re writes back to the ic? (but not sure if a corrupt eeprom will stop just back light?) also what mainbaord is used in this set? and whats the lcd panel number (on a white sticker usually)
      • GeoW
        • Jan 2017
        • 23
        #43
        The label on the main board reads:
        BORDEAUX ID TV 32"
        07030B28 232952
        White Sticker for panel:
        LT A320WT-L07
        0725 7G7F0G678E002
        SSCYT700B6TJ7TJ776K4005 2B
        • dick_barton
          • Aug 2015
          • 6642
          • Wales
          #44
          Well worth a try since there's nothing to lose.
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            #45
            BORDEAUX ID TV 32"
            07030B28 232952
            LT A320WT-L07
            0725 7G7F0G678E002
            any other numbers on the mainboard? a quick google search shows nothing
            this link may help you try a eeprom reset just make sure you choose the right mainboard
            https://wiki.samygo.tv/index.php5/Un...y_EEPROM_Reset
            Try this at your own risk as i have no idea if it will make things better or worse
            • GeoW
              • Jan 2017
              • 23
              #46
              I saw that link. Will give the Eprom reset a try tomorrow.
              The main board ref is BN63-02494A , it's on that large silver cover, and I Googled it and the boards that came up look the same.
              • GeoW
                • Jan 2017
                • 23
                #47
                I tried the Eprom reset by connecting 5&6 of Eprom with a wire and powering up the TV for 20 secs. Then I snipped the wire and unplugged the TV. When I plugged back in, I was getting a solid red standby light, and the light at the bottom of the TV was on. I switched off and powered on again several times, on one occasion getting a brief sound. I also tried a factory reset: (Press "EXIT" button for 12 seconds (15 is better since you cannot see TV), then press "Left" and "Enter") and I also tried accessing the service menu by pressing "Info, Menu, Mute, Power", but neither worked. I'm now getting no light at the bottom of the TV and the red standby light is flashing once again.
                • vinceroger69
                  • Mar 2012
                  • 6714
                  • uk
                  #48
                  as you have tried all possible repairs its best too try to find a replacement mainboard it was a slim chance that a reset was going to work bl on failures usually require a mainboard swap.
                  • dick_barton
                    • Aug 2015
                    • 6642
                    • Wales
                    #49
                    You can try and replace the existing EEPROM with a blank before throwing the main board.
                    24C256 EPROM SMD IC1803 SAMSUNG LE32R88 LE32R87 LE32R86 LE46M87 fixes Main Board
                    https://www.amazon.co.uk/SAMSUNG-LE3.../dp/B00H97PMA0
                    • GeoW
                      • Jan 2017
                      • 23
                      #50
                      Thanks Vince and Dick. If I can get a replacement main board cheaply enough, I'll go for that rather than replacing the Eprom, as I don't trust my soldering skills. I've seen one for £20, but even though they give the say TV number it doesn't look quite the same, so I'll have to do some more searching.
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        #51
                        have you got a picture of your mainboard and the one you have found as some boards you can too work ive looked on shopjimmy but your board dosnt seem to be listed so cant see if theres any alternative boards etc.
                        • GeoW
                          • Jan 2017
                          • 23
                          #52
                          Picture of my main board 1st image in post #1.
                          Picture of board I found here at Ebid On checking it again, I think this is a T-Con board.
                          Found one on Ebay here
                          • dick_barton
                            • Aug 2015
                            • 6642
                            • Wales
                            #53
                            It is a Tcon board and not what you need to replace
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              • uk
                              #54
                              yes that mainboard you have found looks the same but has 4 extra sockets fitted on the top edge and different board number etc although is listed for your tv if it was from the same panel number it may work i guess some of the other member may know if you can use another BORDEAUX board.
                              • GeoW
                                • Jan 2017
                                • 23
                                #55
                                Main board arrived today, and after fitting and retuning, TV is now working. Thanks again Vince and Dick for your help.
                                By the way, the main board and mine were the same, a Bordeaux Plus BN41-00813B MP1.0. The part number I quoted previously was for an item on the main board.
                                • dick_barton
                                  • Aug 2015
                                  • 6642
                                  • Wales
                                  #56
                                  Good new. Glad it worked out.
                                  • TR103
                                    by TR103
                                    - it keeps rebooting
                                    01-22-2025, 04:12 PM
                                  • Ierwin
                                    by Ierwin
                                    05-13-2025, 03:31 PM
                                  • jchang
                                    Samsung UN70NU6900F no picture and no sound
                                    by jchang
                                    Hi all
                                    I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                    Symptom:
                                    No picture no sound.
                                    When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                    No sound at all.
                                    What I tried:
                                    1. I tried unplugging the left or right ribbon...
                                    01-09-2023, 06:28 PM
                                  • Dodgethis
                                    Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                    by Dodgethis
                                    Hello all,
                                    This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                    09-11-2024, 07:39 AM
                                  • marekk
                                    Samsung QE55Q67RAT no sound and bad picture when streaming
                                    by marekk
                                    I got Samsung 55 inch QLED QE55Q67RAT where there is no sound at all and when using youtube for example picture is not clear and noisy.
                                    I have swapped Burr-brown 88002A chip on the mainboard but didn't help, different set of speakers didn't help either
                                    Mainboard is based on pcb BN41-02695A BN94-14007B
                                    I will appreciate any help
                                    Many thanks
                                    Marek...
                                    05-29-2025, 02:23 AM
