Samsung UN60H7150AF Burned IC
  • tvfixer007
    • Feb 2015
    • 86
    TV won't power on. When I unplugged the main board the back lights come on and stay on. Was able to test power supply voltages with main board removed they all looked within margin. I spotted burned (IC206) on the main board but can't find a schematic for this TV.
    Was wondering if I should just order a new IC and cross my fingers? Or that something else is the cause for the IC to fry?
  • petehall347
    • Jan 2015
    • 4427
    • United Kingdom
    Re: Samsung UN60H7150AF Burned IC
    you need to be checking everything connected to it ..without a schematic its not so easy .. only things to short are semi conductors and the occasional capacitor .
    you could take an educated guess and look up the data sheet for the ic . looks like a z3015pi1
    • tvfixer007
      • Feb 2015
      • 86
      Okay thanks. I found the data sheet for it. Will post back when I find anything else wrong.
        http://www.aosmd.com/search?pn=AOZ3015
        • saddle_au
          Waste Warrior
          • 121
          Check the input voltages before replacing it. Anything above 18v-20v frys that chip. Its supposed to be good for 3A. The output voltage for this circuit will be,
          (R2003+R2004+R2005)*0.8/(R2003+R2004)
          If you measure those, you can work out what voltage this circuit is supposed to be generating.
          • CapLeaker
            Leaking Member
            • 8179
            I'd be checking th buck regulator's output to GND. If there is a low resistance, either remove that dc to dc buck converter or the inductor beside it and check for a short to GND again.
            • tvfixer007
              • Feb 2015
              • 86
              I get no reading for buck output to ground. However I found low resistance on D207 and the 4 caps to it's left. I didn't know if it would be safe to power it up and test the voltages?
              • Diah
                • Feb 2013
                • 6376
                any reading and this burn IC still on board are useless. must be out from the board first then test around in general this regulator should it had zinner diode in circuit i cant find it on board.. it may the ZC2009 fly out by heat !!!
                  That does not make sense for you to not see at the output low resistance reading to GND since the CATHODE of D207 (Anode connected to GND) is connected to the VOut pin 8 of the IC. D207 looks to clamping diode to protect the circuit in case the internal MOSFET Q1 of the IC shorted out.
                  • saddle_au
                    Waste Warrior
                    • 121
                    Suck the chip off and measure it separately. This fault may also have been caused by something upstream or a short in the inductor (shorted turn) or shorted fly back diode. measure the output resistance to ground with the chip out to see if the load is also causing a problem.
                    • tvfixer007
                      • Feb 2015
                      • 86
                      Sorry about that I was thinking pin 4 was pin 8.
                      • tvfixer007
                        • Feb 2015
                        • 86
                        Couldn't remove the chip.
                          There is bare pad on the bottom of the IC (see IC spec sheet) to transfer the heat to the copper pad on the board so it will take quite a bit of heat to remove the IC.
                          Cut the legs off the IC first will help.
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            Run solder on all 4 pins on both sides of the IC and move your iron between each side until the solder is molten on both sides then lift the chip off the board.
                            • saddle_au
                              Waste Warrior
                              • 121
                              If the chip is soldered underneath and you snip the legs, unless you have a very sharp zero cut angle pointy pair of snips, you risk lifting the pads during the snipping. Heating the board from the top or underneath also risks lifting pads and tracks.
                              Run a blob of solder down each side of the chip leaving a gap between the plastic and solder. Do this until all four legs of each side is just one mass of solder. Joining all four legs makes the legs and pads more rigid. Use your snips now or better a sharpie (Stanley blade here) and cut the legs off on the edge of the chip, then melt and remove the four legs in one go. You will be left with a legless plastic blob that you can physically attack without hurting the pads. Snip the top off until you see silicon, then cover it in solder, it should lift away.
                              Sometimes its not solder underneath, but glue. Twisting the legless plastic blob also releases it.
                              • petehall347
                                • Jan 2015
                                • 4427
                                • United Kingdom
                                use a heat gun or chip quick might do it .
                                • tvfixer007
                                  • Feb 2015
                                  • 86
                                  I tried soldering iron first no success. Lost my heat gun. Tried to cut pins off but scalped a few traces.
                                  • tvfixer007
                                    • Feb 2015
                                    • 86
                                    I looked at this board on a few sites which ZC2009 and ZC2004 are not present on these boards.
                                    • tvfixer007
                                      • Feb 2015
                                      • 86
                                      I tested D207 out of circuit and it's shorted.
                                        Yep, that is why the IC burnt up, Q1 was feeding that shorted out D207, the protection (Vout sense pin) did not act fast enough to turn off Q1.
                                          09-07-2024, 05:50 AM
                                        • Asraf Atb
                                          by Asraf Atb
                                          01-27-2025, 05:02 PM
                                        • JSin21
                                          Compatibility of main boards between different variations of samsung MU6100
                                          by JSin21
                                          Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                                          I have Samsung Smart TV UA65MU6100WXXY version DA01
                                          Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                                          11-27-2023, 04:54 AM
                                        • Yanleb
                                          Compatibility of Samsung Y Main boards LJ92-01732A no rev vs rev AA2
                                          by Yanleb
                                          Hi, I did look everywhere to know if Samsung Y Main boards LJ92-01732A without rev marking is compatible with LJ92-01732A rev AA2.
                                          If they are not compatible why did Samsung give them the same part number to begin with?
                                          08-04-2025, 11:35 PM
                                        • elpatxi_bcn
                                          Samsung HG75EJ690UB Hotel TV, change main?
                                          by elpatxi_bcn
                                          Hello!
                                          I just got a Samsung TV model HG75EJ690UB 75" and 4K. It is a hotel TV, with a slightly different version of the Tizen operating system than the TVs at home.
                                          Being a hotel, it is covered in many functions. With the service menu I can unlock some, but not others. For example, I can't install apps like Netflix etc...
                                          The fact is that it seems that I can replace the main by a, say, "normal". I think the one that corresponds is NU7105, ref BN94-02635. At work, which is a convention center and a hotel, I have many TVs from 55" to 85" that...
                                          05-19-2023, 03:21 AM
