Samsung UN60H7150AF Burned IC
  • tvfixer007
    • Feb 2015
    • 86
    Re: Samsung UN60H7150AF Burned IC
    Originally posted by budm
    Yep, that is why the IC burnt up, Q1 was feeding that shorted out D207, the protection (Vout sense pin) did not act fast enough to turn off Q1.
    Now I can't find a datasheet for D207.
    • tvfixer007
      • Feb 2015
      • 86
      Thought I'd follow up on this thread. I tried to replace the buck regulator. I got a standby light, and a quick flash on the panel when pressing power but no back lights or picture.
      Just decided to replace the main board. TV now works again!
      • Stevenfalc
        • May 2018
        I seem to have the same problem with a burnt IC206 on the main board of a UA75H6400. Did your screen have no standby light when it was dead? I’m trying to decided if I should stop blaming the power supply and replace the main board after reading your thread.
        • sooraj101
          • Nov 2018
          Originally posted by Stevenfalc
          I seem to have the same problem with a burnt IC206 on the main board of a UA75H6400. Did your screen have no standby light when it was dead? I'm trying to decided if I should stop blaming the power supply and replace the main board after reading your thread.
          I'm having the similar issue - burned chip.
          My TV Model is UA48H6400
          I'm keen to know how you sorted out the issue..!
          Did you try replacing the chip?
            09-07-2024, 05:50 AM
          • Asraf Atb
            Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
            by Asraf Atb
            Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
            Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
            I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
            01-27-2025, 05:02 PM
          • JSin21
            Compatibility of main boards between different variations of samsung MU6100
            by JSin21
            Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
            I have Samsung Smart TV UA65MU6100WXXY version DA01
            Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
            11-27-2023, 04:54 AM
          • mrautom8
            Samsung TV UN75H6350AFXZC main board schematics?
            by mrautom8
            Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
            Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
            While relay is on, all voltage rails are present and steady (scoped) on main board.
            I love a good logic puzzle but getting lost without any schematics.
            No shorts on ANY capacitor main board.
            Thermal camera shows 3.3V inductor getting warm instantly but...
            10-19-2025, 06:32 PM
          • Yanleb
            Compatibility of Samsung Y Main boards LJ92-01732A no rev vs rev AA2
            by Yanleb
            Hi, I did look everywhere to know if Samsung Y Main boards LJ92-01732A without rev marking is compatible with LJ92-01732A rev AA2.
            If they are not compatible why did Samsung give them the same part number to begin with?
            08-04-2025, 11:35 PM
