Hitachi (Vestel) 32hxc05u blue/red stand by flashing
  • vitasik
    • Oct 2016
    • 30
    Good evening guys.
    Here is a toy I am playing with today
    Hitachi 32HXC05U
    Main board : 17MB82-2 23118936
    Power supply: 17IPS19-4
    Display: VES315WNEA-01-B
    Will not turn on. It sits comfortably in Stand-by with good 12v supply from PSU.
    When you switch it on LED starts to flash between blue and red. You still have +12v with the addition of +24v. Here comes BUT - on the control pin for backlight ON there is nothing - zero. Obviously voltage on the LEDs is just 24v without ground being switched by its controller.
    To me it sounds as maybe flash problem?
    I can find flash for 32HXC05 ( without U at the end). If I am not mistaken this should mean UK plug????? If that is correct can I use that flash? And what was the procedure with USB flash drive. I have done it before, but it has been a while and cant seems to find the instruction. IMO a sticky thread with some instruction on Vestel junk flashing would be nice as there are so many of these.
  • vitasik
    • Oct 2016
    • 30
    Re: Hitachi (Vestel) 32hxc05u blue/red stand by flashing
    Sorry - a slight mistake and update on the stand by led: when in stand by its red and not blue. Second thing is that when switched on from remote it flashes 7 times red with blue inbetween than all light is off for a half of a second. Afterwards its back to square 1 - 7 red ( with 6 blue in between) flashes again pause and so on.
    • vitasik
      • Oct 2016
      • 30
      Anyone?
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        if a flash issue this may work maybe send them a email
        https://shop.strato.com/epages/62027...roducts/E2P255
        https://shop.strato.com/epages/62027...ts/UPG83-Y4.01
        • vitasik
          • Oct 2016
          • 30
          This evening I will be making programmer for 25qXX flashes to be able to do that myself. I have the dumps from russian site anyway. Just I didnt really want to desolder the flash chips, hence me asking how was it flashing with the firmware on USB drive
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            this thread maybe worth a read does have some information regarding programming etc
            https://www.badcaps.net/forum/showthread.php?t=44389
            have you tried freezing the ics does the set start up?
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Not the best thread, but had over to my channel and watch MB82 flashing led repair.
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                Thanks reece i forgot you had made that video
                https://www.youtube.com/watch?v=kPCisa9BYkk
                • vitasik
                  • Oct 2016
                  • 30
                  Thanks guys, i have seen that video before, but couldnt remember what I was looking for ( exact phrase).
                  Anyway I was quite sure it was booting problem as it wouldn't even give a signal for LED backlight. So I reflashed both SPI flashes with dumps gotten from a russian site for a same model, but no U at the back. Now........... where do I start
                  Good news..... it starts, backlight are on it shows picture....in russian......upside down...in a worse quality than it should....
                  Anyone has good dumps for this junk?
                  One thing that I did notice while reflashing is that 25q64 would fail verification after being written. I did it 2 times 2 failures. I was calling it a day and was tidying my tools without and just run it again - presto - it wroti it ok AND verification went ok. Verified it a few times after that, as well as next day( thought maybe when its warm its working). All is good and checks out ok.
                  I do have another 25*64 from identical board from different vestel junk. But I think its Infenion and not Winbond - are these TVs fussy about the specific manufacturer/ part number or any 25*64 should work?
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    that firmware may of not matched the lcd panel used in your tv hence being upside down i wonder if theres aoption in the service menu to flip the picture? and maybe do a factory reset and channel scan you maybe able to change language?
                    • vitasik
                      • Oct 2016
                      • 30
                      Good morning
                      Language is not an issue for me. Russian is one of few I do know. But flipped picture is a problem as well as blurry picture. Its absolutely brilliant when showing hitachi welcome sign, but blurry when you access menu or any writing ( Like volume, signal not present, etc, etc)
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Core update works for all mb82.
                        • vitasik
                          • Oct 2016
                          • 30
                          Hm... so why is the image is rotated 180 degrees and its blurry when text is showing up?
                          Cheers
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            • uk
                            did you try the core update from the link in reece video?
                            • vitasik
                              • Oct 2016
                              • 30
                              Good evening guys
                              Sorry for not writing earlier - been busy with other projects - Recovery truck and a misbehaving car. Today got the tv out of the garage and played a bit. Did a core update exactly like in the video. It did read from the flash drive, booted, but literally nothing have changed. was still in Russian, with flipped and distorted picture.
                              To show you what I mean here you are a few pictures and videos. What do you think?
                              Dropbox link to a folder
                              EDIT: Forgot to add that i dont think there is a sound at all.
                              • ducky29
                                • Dec 2015
                                • 370
                                • Europe
                                I have a source where I can find the firmware for this TV. You need only an usb stick. Unfortunately I cannot provide you the software for free. PM if you are interested.
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  Tight arse why not help others I did gave £40 worth free on here lol
                                  • ducky29
                                    • Dec 2015
                                    • 370
                                    • Europe
                                    You know that it is very difficult to find the exact firmware for Vestel.Id be really happy to help everyone that I can, but I do not find these firmwares on my own. I buy them.
                                    • vitasik
                                      • Oct 2016
                                      • 30
                                      I bet you gave way more than that as right advises to countless people.
                                      As for a "right" firmware - I am guessing that it wont be any different to what I can source on my own for free from different sources. Russian sites are for one - plenty of stuff out there.
                                      As I said before I know a few languages and can benefit from using more sources - Russia, Ukraine, Bulgaria.
                                      If I am not mistaken now I will need to remove the flash chips once more and try to find other source for the bin file.
                                      Am I on the right track with my thoughts - 25Q64 is used for core bin - same on all 17mb82 and 25Q16s bin is the culprit of my issues? Or is the core update reflashes both chips.
                                      My idea is to desolder only 25Q16 and play with it for a bit trying different options
                                      • vitasik
                                        • Oct 2016
                                        • 30
                                        EDIT: I am not tight or greedy - I got this tv to have some fun playing with. Its my hobby messing with everything -I have been car electrician, mechanic, Immo manipulations, previously was etching PCBs, repairing motherboards on PCs, etc, etc, etc. I am no expert in any of it but I always get things done in the end.
                                        • massimomax
                                          Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
                                          by massimomax
                                          Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
                                          spero che qualcuno può averlo per riprogrammare eprom. grazie
                                          Post in English !!!
                                          I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
                                          02-28-2025, 07:27 AM
                                        • STKR123
                                          Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
                                          by STKR123
                                          As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
                                          I wonder if re-flashing the BIOS might be of any use here.
                                          As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
                                          There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
                                          11-03-2024, 06:58 AM
                                        • Askic
                                          Hitachi (Vestel) TV is not turning on
                                          by Askic
                                          Hello guys,
                                          I have 32 inch Hitachi TV with Vestel PSU board 17IPS71. Tv was working normally and I shut it down normally via remote control.
                                          The next morning it couldn't turn ON neither with remote controller or via button on the logic board.
                                          There is a red standby LED ON, so it is not dead totally.
                                          I have examined the PSU board and I cannot find find any traces of blown components or bulged caps. Electrolytic caps are manufactured by Elite.
                                          I also check diodes and big MOSFET (with cooler/heatsink). It seems OK.
                                          Can you tell me based on...
                                          01-11-2023, 12:34 PM
                                          Microsoft Surface Redbank i5/8/256 Blue Notebook Specification for Upgrade or Repair
                                          This specification for the Microsoft Surface Redbank i5/8/256 Blue Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Redbank i5/8/256 Blue boardview and Surface Redbank i5/8/256 Blue schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-07-2024, 05:50 AM
                                          Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook 300 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I5-1235U 8GB 256GB BLUE boardview and IP3 15 I5-1235U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          09-07-2024, 05:00 AM
