TO-220 job help?
  • ivtec
    • Dec 2008
    • 1967
    TO-220 job help?
    Hi guys i trying to fix a Philips 46pfl5505d/f7 dead ,i found D951 short ,now i red in this thread link bellow, to add a T0-220 with heat sink in place of D950,D951,
    i have this To-220 see link ,is this a good one for this job? thanks
    http://www.mouser.com/Search/Product...4-APT10SCD120K
    https://www.badcaps.net/forum/showthread.php?t=48765
  • CapLeaker
    Leaking Member
    • 8352
    Re: TO-220 job help?
    what original part # is D951 in yours? Do you want to replace the SB260 with that?????
    Maybe read my post number 32 in that thread. Replacing a SB260 (60V, 2A) with a 1200V 10A Schottky isn't a good idea.
    • ivtec
      • Dec 2008
      • 1967
      thanks CapLeaker; I was going to replace D951 and D950 both SB260 with a single T0 220
      You think i should use 8TQ100 (8A/100V) TO-220 with heat sink instead?
      http://uk.rs-online.com/web/p/rectif...iodes/5445767/
      • CapLeaker
        Leaking Member
        • 8352
        that's better... a bit of overkill (now that wont blow anymore), but good. Just be careful with the heat sink as it is connected to cathode of the diode.
        • ivtec
          • Dec 2008
          • 1967
          Thanks CapLeaker; i'll post results.
          • ivtec
            • Dec 2008
            • 1967
            Hi guys; update and great success on the Philips 46pfl5505d/f7 repair and due this great Forum with the great tip on modifying and improving the circuit with the T)-220 to avoid future failure, see pic attach. thanks to all one more TV saved from the landfill.
            • ivtec
              • Dec 2008
              • 1967
              Hi guys: well i spoke to soon,i did not check with video connected in the seller since i did not have signal where i did repair it,i trusted it cause it had the Phillips logo and menu with inputs,so i brought it upstairs, and connected video and nothing ,no video i don't have the remote control,what other stuff should i look for? thanks.
              • Agent24
                I see dead caps
                • Oct 2007
                • 5095
                • New Zealand
                Maybe it needs a reset (corrupt EEPROM settings?) - but you would need the remote for that I suspect.
                Did you try all the inputs or just tuner?
                -David VanHorn
                • ivtec
                  • Dec 2008
                  • 1967
                  Thanks i thing the tv is alive could get the tuner with a couple channels already, but without remote is hard, also i 'm trying to update firmware,i have a fat32 USB stick, i've download from here, see link; but doesn't show the file on the stick,i use zip rar, maybe it's not Rar but some other type of zip,can you help here please, thanks
                  http://www.p4c.philips.com/cgi-bin/c...=46PFL5505D/F7
                  • CapLeaker
                    Leaking Member
                    • 8352
                    At least you got the PSU repaired. It looks about as mean as I had pictured it.
                    Now you have a main board issue? Can we have a straight shot, high resolution picture of it? Was that TV a lightning special or something?
                      • 31289
                      reading the instructions would help.
                      format the stick with FAT(16)
                      and unzip the file onto it.
                      • saddle_au
                        Waste Warrior
                        • 121
                        If you have a smart phone, there are apps that will pulse the correct codes for different TVs.
                        http://www.cnet.com/au/news/turning-...ter-tv-remote/
                        https://play.google.com/store/apps/d...te.phone&hl=en
                        • ivtec
                          • Dec 2008
                          • 1967
                          I was able to do firmware update and rescaned OTA channels and no channels were found and no sgnal in all inputs,it looks like E prom,will i be able to repair this ?,or do i have to get a Main board?
                          You say:Was that TV a lightning special or something? you mean lightning strike ? i don't know, i found the Tv in the dumpster, all i did was repair the Power Sup.
                          • ivtec
                            • Dec 2008
                            • 1967
                            Can you point me to the e prom please;
                            http://www.ebay.com/itm/Philips-46PF...3D262121429081
                            • CapLeaker
                              Leaking Member
                              • 8352
                              So how did you get the TV to display something if it is dead on all inputs?
                              The EEPROM is mostly an 8 legged IC (4 on both sides). It can be a 16 legged one too, but those aren't that common. Look on your board close to the main IC and verify the part number.
                              • ivtec
                                • Dec 2008
                                • 1967
                                Thanks CapLeaker; i found this Main board on Ebay,see link; i think the e-prom is 16 leg, i don't think i can solder these back to the board,also can you please tell me how to remove the connection from the board, the plastic head,i disconnected the flex although same plastics peaces broke,as you see on the Ebay board it doesn't have that plastic end,see my pic attach.
                                I also don't know if i can trust this guy on E bay almost 100bucks for the main board is kinda steep
                                Note;at first i was able to get a few channels on TV mode from the OTA antenna,but after i re-scanned the tuner the tuner did not pic up no more channels therefore could not get any channels anymore,i'm gonna try to heat the BGA and see if hdmi input will show.
                                http://www.ebay.com/itm/Philips-40PF...3D142191856605
                                There are some pics of the whole board,not very good pic cause of my crappy Cam.
                                • CapLeaker
                                  Leaking Member
                                  • 8352
                                  Aaah! Weird why it would work once then not anymore. The EEPROM is 8 legged. I don't see any 16 legged ones there. They look like the 8 legged ones in the middle of the board where the screw hole is. I count about 7 of them on the board. However, all you can do is try to find it and freeze it with a can of air upside down, turn the TV on and see if all is O.k. Could be also BGA. Problem is I couldn't find a replacement EEPROM for it. Did you try a factory reset yet? For some reason if I read the whole thread it doesn't sound like an EEPROM problem to me, because the TV is responding and doesn't do any other weird shit besides not displaying anything.
                                  • dick_barton
                                    • Aug 2015
                                    • 6643
                                    • Wales
                                    Read the part number printed on top of the 8 legged IC and google them to find which one is the eeprom.
                                    What number is on IC3102
                                    • ivtec
                                      • Dec 2008
                                      • 1967
                                      Thank you guys; today i took out main board and used the Heating gun and heated up the CPU and the whole board, then put it back, for now the HDMI inputs are ok, i used my Roku to check,only the Outdoor Antenna,OTA chan won't scan channels,before i did a OTA rescan i had a few channels ,maybe i need to get in the service menu and set Factory default,i have downloaded the service manual from here,see link? .Also this Main board is a pain in the Butt to take out ,and can't check nothing with it in place all the Components are Hidden under the metal casing.
                                      The IC 3102 is AT 24C16BN-SH-T (Memory}
                                      i'm going to buy a original Remote control,hope i get one,and will keep you posted,
                                      if you guys have any idea why i can't get OTA channels when i rescan,please advice what could be,thank you all for your great help and thanks BadCaps for this great Forum.
                                      https://www.manualslib.com/manual/85...l5505d-F7.html
                                      • CapLeaker
                                        Leaking Member
                                        • 8352
                                        thats the eeprom
                                        But you don't have an EEPROM problem anyway.
                                          Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
                                          The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
                                          Securing a good thermal interface between...
                                          10-07-2024, 04:35 AM
                                        • Nevillet
                                          Identifying a TO220 device
                                          by Nevillet
                                          Hi All,
                                          I'm trying to repair a swich mode PSU and have found a shorted TO220 device but cannot track it down.
                                          The markings are:
                                          First
                                          15T43
                                          FIR7N65AF
                                          A picture is attached.
                                          Many thanks....
                                          07-30-2024, 11:48 AM
                                        • ivtec
                                          Philips 46PFL5505D/F7 thin green line?
                                          by ivtec
                                          Hi guys i have this Philips 46PFL5505D/F7 that has a thin green line in the corner almost unnoticeable ,this probably has been here for a long time,and it more noticeable when watching regular tv entertainment,since i mostly watch soccer on this tv because of the green field ,it's probably i never noticed it ,do you guys think this might be the ribon cables , tcon board or main board ?...
                                          12-24-2020, 12:57 PM
                                        • DrDos
                                          kenwood kr-6030 Mosfets?????
                                          by DrDos
                                          Hello everyone, I have decided to try and replace the mosfets in my power amp (the one with relay and left and right sides) on my kenwood kr-6030. I'm trying to get the A side of my speakers working. I have replaced all the caps in the power board and I thought why not change the mosfets. They seem to be working since I have great music coming out of the B side speakers and since I am not an electronic guru (but I am learning) I don't want to make any mistakes. The mosfets I have are listed A913 so I guess 2sa913 and 2sc1913. Can't really find those in mouser or digikey at least with the info...
                                          09-20-2025, 04:42 PM
                                          DELL Latitude E5470 Notebook 5000 Specification for Upgrade or Repair
                                          This specification for the DELL Latitude E5470 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E5470 boardview and E5470 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude...
                                          09-07-2024, 12:40 AM
