Identifying a TO220 device
  • Nevillet
    • Sep 2019
    • 272
    Hi All,
    I'm trying to repair a swich mode PSU and have found a shorted TO220 device but cannot track it down.
    The markings are:
    First
    15T43
    FIR7N65AF
    A picture is attached.
    Many thanks.
  • R_J
    • Jun 2012
    • 9588
    Likely the same as FIR7N65FG
    • Nevillet
      • Sep 2019
      • 272
      Many thanks for that. Best wishes,
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8325
        Google something like 7n65 and you will get tons of results.
        • kjells
          Need help identifying a SOT23 device labeled WAW
          by kjells
          I have problem identifying a SOT23 SMD device. It is labeled WAW. I know this is a diode, possibly a zener. Device is part of the gate driver logic in a switch mode PSU. Anyone that can help me with this issue.. Thanks.
          10-08-2023, 06:28 AM
        • kjells
          Need help identifying a SOT23-5 device labeled as 72 2B 06 in tree different rows
          by kjells
          I have a problem identifying a SMD device. This is likely a SOT23-5 package, and it is labeled as 72 2B 06 in tree different rows. See also attached picture. Device is part of the gate driver logic in a switch mode PSU.
          Anyone that can help me with this issue.. Thanks....
          10-07-2023, 01:38 PM
        • Nevillet
          Identifying a 'FS45' SOT23 device
          by Nevillet
          Hi All,
          I'm trying to repair a PCB that has some surface mount SOT23 devices that apear to be transistors but testing them on the board are giving confusing results.
          Its named FS45 but I can't find a datasheet that seems correct.
          The device is used in 10 places on the PCB. In 4 cases they appear to be controling triacs and the attached picture it shows it connected to a BT136 triac with the FS45 connected to the gate leg of the BT136.
          Can anyone identify the device and suggest an alternative?
          Many thanks.
          PS: I have...
          06-19-2024, 11:42 AM
        • Yolofolkss
          Asus X99-pro/usb 3.1 Usb overcurrent device reoccurring issue
          by Yolofolkss
          Hi this is a really odd case.
          I have removed all of the esd ic for USB 3.0 and 2.0
          I measured all of the data lines and 5v usb voltage lines there are no shorts
          all of the USB ports have no damage
          Clearing the bios using the jumper wont help.
          it is still showing USB overcurrent device
          the only temporary fix I've tried and worked so far is flashing the bios
          and the error is gone
          but when you start the motherboard with a USB device still attached
          the USB over current device error is back. the bios needs to be externally flashed...
          01-09-2023, 04:21 AM
          Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
          The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
          Securing a good thermal interface between...
          10-07-2024, 04:35 AM
