SHARP motherboard version compatabilaty T-con
  • Edward Wong Hau
    • Nov 2016
    • 10
    Hi, I recently replaced my motherboard with one that had the exact same part number QPWBXF733WJN2 but it was version 2.03. The problem is that when I connect the board with the T-con I noticed that the connector is placed differently and the TV (sharp aquos lc-60le635e 60) will light up but not show any picture. The T-con version is 1.00. Does anyone know how to fix this?
  • sordids999
    • May 2013
    • 2161
    Re: SHARP motherboard version compatabilaty T-con
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • Edward Wong Hau
      • Nov 2016
      • 10
      Thanks for the reply but I already have tried everything to adapt the board to the tv. I populated all the components on the other plug but it didn't like it (backlight powered on but after a few seconds the power led started flashing 2 long a and 5 short witch is the error for T-con) I even changed the firmware chip to the one of the old board but then it flashed 3 times and one short. I think this is because the ram and arm chip are different to the old ones so the firmware didn't run correctly. But now I changed everything back, the v2.03 board now works as before and I'll buy the correct board this time.
      The one I bought looked like this:
      And this is the correct one:
      • moltensolderlabs
        Sharp LC-52E77UN TCON activation WITHOUT motherboard. I2C reverse engineering help?
        by moltensolderlabs
        Hi everyone. [Sorry for the long, detailed post in advance].
        I have a Sharp LC-52E77UN which randomly shuts down--could be within 15 minutes, could be 40 minutes, over 1 hour, it's unpredictable. From reading the service manual, I was able to get into service mode (where the K is displayed), and found the following error flag toggled: "04 Initial Communication Error 4 -- Error reason: To the communication setting reception," which, from contacting an eBay TV repair store, I was told is caused NOT by a bad TCON (which was my first guess), but rather the motherboard....
        10-09-2020, 12:01 PM
      • advant
        by advant
        02-03-2020, 12:25 AM
      • sikocan
        Lenovo X1 Carbon 9th Gen Black Screen
        by sikocan
        I believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
        SN: PF3G1REP
        MODEL: 20KW-00J1AU
        PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
        Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
        06-24-2025, 09:01 PM
      • kca
        by kca
        Hello all ~
        08-31-2025, 06:38 AM
      • survivalbloke
        Gigabyte motherboard missing CPU compatibility due to BIOS version being too low - proper way from here?
        by survivalbloke
        This job which came in is a Gigabyte B650M D3HP AX (rev. 1.0). It has BIOS version F1 currently, and the CPU installed is Ryzen 9 9900X, which according to the Gigaybte site, needs at least BIOS version F30. I don't have a supported CPU to install for the purpose of updating the BIOS. I have downloaded the BIOS from Gigabyte's website and unzipped the file "B650MD3HPAX.F32a". Can I just rename it to 'B650MD3HPAX.BIN' and flash it to the motherboard using neoprogrammer and my CH341A?...
        09-16-2024, 04:06 PM
