Hi, I recently replaced my motherboard with one that had the exact same part number QPWBXF733WJN2 but it was version 2.03. The problem is that when I connect the board with the T-con I noticed that the connector is placed differently and the TV (sharp aquos lc-60le635e 60) will light up but not show any picture. The T-con version is 1.00. Does anyone know how to fix this?
SHARP motherboard version compatabilaty T-con
Tags: None
Re: SHARP motherboard version compatabilaty T-con
Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem -
Thanks for the reply but I already have tried everything to adapt the board to the tv. I populated all the components on the other plug but it didn't like it (backlight powered on but after a few seconds the power led started flashing 2 long a and 5 short witch is the error for T-con) I even changed the firmware chip to the one of the old board but then it flashed 3 times and one short.
I think this is because the ram and arm chip are different to the old ones so the firmware didn't run correctly. But now I changed everything back, the v2.03 board now works as before and I'll buy the correct board this time.
The one I bought looked like this:
And this is the correct one:
Hi everyone. [Sorry for the long, detailed post in advance].
I have a Sharp LC-52E77UN which randomly shuts down--could be within 15 minutes, could be 40 minutes, over 1 hour, it's unpredictable. From reading the service manual, I was able to get into service mode (where the K is displayed), and found the following error flag toggled: "04 Initial Communication Error 4 -- Error reason: To the communication setting reception," which, from contacting an eBay TV repair store, I was told is caused NOT by a bad TCON (which was my first guess), but rather the motherboard.... -
by advantThis thread is about trying to get an Universal Main Board to work with a Sharp TCON and panel.
I have a Sharp LC-46D85UN TV that has had a main board issue. Since this model is from 2009, I am not able to find an exact replacement of the main board. Instead, I decided to see if I can future proof this tv by getting a Universal Main Board (T53U21.2) from China to work with the Sharp TCON (CPWBX4291TPZA) and panel. The universal main board supports a 8 bit dual channel LVDS interface whereas the TCON requires a 10 bit dual channel LVDS input. I have modded the LVDS connector to match... -
by sikocanI believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
SN: PF3G1REP
MODEL: 20KW-00J1AU
PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
Channel: BIOS Requests ONLY!
by kcaHello all ~
I got the display to work by taping off several traces of the right-hand side ribbon cable on the TCON that leads from TCON to PANEL. However, despite dozens and dozens of attempts to find the right combination / range of traces taped... -
This job which came in is a Gigabyte B650M D3HP AX (rev. 1.0). It has BIOS version F1 currently, and the CPU installed is Ryzen 9 9900X, which according to the Gigaybte site, needs at least BIOS version F30. I don't have a supported CPU to install for the purpose of updating the BIOS. I have downloaded the BIOS from Gigabyte's website and unzipped the file "B650MD3HPAX.F32a". Can I just rename it to 'B650MD3HPAX.BIN' and flash it to the motherboard using neoprogrammer and my CH341A?...
- Loading...
