Vizio E400I-B2 powering on problem
    Re: Vizio E400I-B2 powering on problem
    OK, that means the 32VDC is normal then,, those caps are the filter caps for the output of the Boost converter circuit that boosts the incoming 24VDC to higher level for running the LED string, and you are getting about 8VDC on the Cathode side of each LED strings so it sounds like the MOSFET for each of the LED current return lines are not being turned on.
      What is the LCD panel model number? There should be a sticker some where on the back of the panel.
      • CapLeaker
        Leaking Member
        • 8226
        May not be just like the other one a while back with the missing BLon signal?
          I believe I saw another thread with similar board that I could find out which pin are for BL-ON, Dimming, etc. I think the BL-ON is present otherwise he will not have that boosted 32VDC.
          • nwcs
            • Dec 2015
            • 311
            • usa
            I have the exact same results with the exact same model tv. I do not think the led's are the problem. I believe the main board is the culprit. I Checked voltages on cn201 both while on and while powering on.
            while on: 1 and 2 are 5v, 3 is 3.3v and all of the 12v are 0v.
            While powering on the 12v all read 12v then go down.
            • nwcs
              • Dec 2015
              • 311
              • usa
              #26
              I forgot to mention pin 4 is 0v while on and 3v when turned on.
                So you do have PS-ON (3 VDC) on pin 4 when TV is turned on but you are not getting the switched 12 Vdc, you have problem with the power supply.
                • nwcs
                  • Dec 2015
                  • 311
                  • usa
                  #28
                  Just tested all of the LED's and all lit up fine. I am leaning on a bad main board.
                  • nwcs
                    • Dec 2015
                    • 311
                    • usa
                    #29
                    I get 12v when turned on but then it goes to 0v.
                      If pin 4 3V is present and stays at 3V or so but the switched 12V drops out then you need to check that 12V section to see if it being loaded down, or bad parts, etc.
                      • nwcs
                        • Dec 2015
                        • 311
                        • usa
                        #31
                        So you are saying power supply. I will check in the morning.
                          We need good clear straight shot pictures of your power supply board top side and the bottom side.
                          • CapLeaker
                            Leaking Member
                            • 8226
                            or something connected to the 12V rail on the PSU loading it down.
                            • TheCockroach
                              • Sep 2015
                              • 34
                              Kind of good to know that I'm not the only one with this problem, but it also kinda sucks. Means there's probably a lot of others as well, as it may just be an inherent flaw with this particular model.
                              Maybe I should leave the picture taking to nwcs, since it'd seem my camera produces really poor quality results. if he can't get back to us with some, then I'll borrow a friends phone to take pics with instead.
                                So did you at least check the resistance of the 12V pin against GND to see if it shows really low resistance?
                                • TheCockroach
                                  • Sep 2015
                                  • 34
                                  Which board is that on again btw, the main board (aka, same one that I took the LED measurements off of, or..) ?
                                  • nwcs
                                    • Dec 2015
                                    • 311
                                    • usa
                                    #37
                                    It has been off my bench for a while but I think it was the power supply.
                                    • nwcs
                                      • Dec 2015
                                      • 311
                                      • usa
                                      #38
                                      OK, I have three of these TV's in same issue. I got a used main board off ebay and still have same problem. I did check to see if there was anything displayed on the screen (hit the menu button and used a flashlight to look) and there is nothing. I have verified all led's are at least lighting and the measurements were taken off of the power supply.
                                      • TheCockroach
                                        • Sep 2015
                                        • 34
                                        Any word from your end, about what the problem with these TV's was/is, by chance..?
                                        • nwcs
                                          • Dec 2015
                                          • 311
                                          • usa
                                          #40
                                          Sorry, I thought I had already posted the repair. On this model it ended up being the power supply had failed, just like budm had thought. I had a E420i-A0 with almost the same problem and it ended up being the main board.
                                          • rajbot
                                            No Power problem with Vizio E60-E3
                                            by rajbot
                                            Hi all:
                                            I have a Vizio E60-E3 I am trying to troubleshoot a no power problem with. Thanks to the help on this board and elsewhere, I was pretty sure I had narrowed it to a power board problem. The board in question is a 09-60CAP0D0-00. Image attached for reference, but not of my board (tv is put away at the moment). FWIW, no obvious looking issues with the board.
                                            I measured voltage at power in and on the fuse and saw 120V, so power is getting to the board.
                                            On the pins out to the main board, I got no voltage at all on any of the pins. I assumed this...
                                            03-22-2023, 08:09 AM
                                          • Zeonalbasta
                                            Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                            by Zeonalbasta
                                            i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                            The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                            09-13-2024, 01:17 PM
                                          • Pinky Deepak
                                            Vizio M60-C3 Left Edge problem
                                            by Pinky Deepak
                                            I have a M60-C3 where the left edge has started showing issues as seen in the picture attached. Along with this, I also noticed some darkening on the left half of the screen which went away after I left the TV unplugged. i initially thought it was the led backlight that was wearing out but looks like something to do w the TCONN board. I searched this forum but couldn't find anyone else seeing this issue. most of them were LH/RH completely gone. any insights or guidance is appreciated.
                                            Here's a video of both the issues: https://youtu.be/hMqc760nB3o
                                            09-27-2024, 05:11 PM
                                          • Gibon378
                                            Problem with stopping audio and video for no reason
                                            by Gibon378
                                            PC Specs:
                                            • CPU: Ryzen 5 1600
                                            • GPU: GTX 1080 Palit JetStream
                                            • MOBO: ASRock ab350 PRO4
                                            • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                                            • PSU: XFX 650W (don't remember what model)
                                            • OS SSD: ADATA SP920
                                            • OS: Windows 10 21H2
                                            Problem description:
                                            Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                                            11-19-2022, 09:41 AM
                                          • perzyk23
                                            Lenovo T580 - LCD Panel problem - error 0288
                                            by perzyk23
                                            Good morning,
                                            I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                                            10-25-2024, 12:42 AM
