Vestel 17MB61-2 No picture
  • SA6BUQ
    • Dec 2016
    • 11
    • Sweden
    Hi all, I have searched and read as much as I can but did not find a suitable similar case, so that is the reason for posting.
    Vestel 17MB61-2 branded as Andersson A424FDC (42 inch LCD) in Sweden.
    Power Supply 17PW26-4 Seems to measure OK PL816:
    Pin 6 : ST_BY = 0V when powered on
    Pin 12: +12V OK
    Pin 14: +5V STBY OK
    Pin 15, 16: +3.3V OK
    Pin 18, 19, 20 : +3.3V when powered up
    Pin 11: +12V =OK
    Pin 13: 33V = components not fitted on PSU
    Pin 17, 19, 21 : +5V OK
    Symptoms:
    Powers up using keypad (top button). No picture no sound.
    PSU board PL802:
    +24.33V to T-CON OK
    +3.33 BL ON to T-CON OK
    After pressing the On button, the front LED blinks about 12 times and then the backlight turns on. No picture or text on the screen but dim light blue glow.
    Measured Voltages on U25 and U26 on the Main board as well:
    U25 : In 5.1V, Out 2.82V, Adj 1.57V (Strange output voltage?)
    U26 : In 5.1V, Out 3.4V, Adj 2.15V Looks OK
    It almost seems as if most is working and that there may be a bootup or firmware problem?
    Any thoughts, advice will be much appreciated. Thanks in advance.
    de SA6BUQ
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Vestel 17MB61-2 No picture
    +24.33V to T-CON OK
    Are you sure it's 24V to the tcon. Have you checked the fuse on the Tcon board. Have you connected to the scart connector to check for sound.
    • SA6BUQ
      • Dec 2016
      • 11
      • Sweden
      Hej Dick, thanks for the reply.
      Well, I am not a specialist and if I understand it correctly the T-CON board is the one on the left (when looking from behind the set) under the blac metal cover. The cable connected from there to the PSU to a header marked PL802 on the PSU board. The right hand 4 pins are connected to red wires and measure +24.33V. Where is the fuse located on the T-CON board?
      I have not connected a SCART source and sorry, but I omitted to say that I can not turn on the set using the remote, so I cannot select a different input source using the remote. When pressing the buttons on the side, they beep with every press, but nothing happens on the screen e.g. volume control slider bar does not even appear.
      Willing to do any more measurements/checks that you may recommend.
      Thanks again. 73 de SA6BUQ
      • vinceroger69
        • Mar 2012
        • 6714
        can you upload a picture showing the whole of the back of the tv so we can see how the boards are connected as its sounds like you maybe testing the invertor board hence the 24v reading.
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          +1
          Inverter boards normally at 24V. Tcon at 12V or less but often 12V.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Agree with Vince if I recall this cmo panel uses an inverter with them crappy AO mosfets on that seem to short out and blow the fuse.
            • SA6BUQ
              • Dec 2016
              • 11
              • Sweden
              Here comes the rear view pics... the +24.33V I measure is on the right hand 4 wires of PSU (maybe the same thing as the inverter board?) board PL802 which then goes to the board with the black cover on the left.
              Regards SA6BUQ Christo
              • SA6BUQ
                • Dec 2016
                • 11
                • Sweden
                ...I removed the cover and measure the 10A fuse...(marked in the red square) there is a label just below it showing 24V. Is this the inverter board or ?
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  Yes, that's your inverter board.
                  There are 2 fuses. F1 & F2. set off and use your meter set to ohms and measure across each in turn. They should both be short circuit (0 ohms).
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    looking at the pictures this set looks like the tcon is built onto the lcd panel pcb (bonded on the lcd?) post 7 picture 2 black lead from mainboard running to top center of tv im not sure how easy it is to get a picture of the area as on that board you will find another fuse to check.
                    • SA6BUQ
                      • Dec 2016
                      • 11
                      • Sweden
                      Hej and thanks again, Dick I measured F1 and F2 and they both measure 0 ohms. When the set is on (with backlighting showing) i measure +24.33V on both. So they seem to be OK.
                      Roger, there are 4 mounting points on the chassis above the PSU board that are not used.. clearly this chassis was used for older versions where the T-CON board was mounted there. So it must be integrated with the panel somehow as you say... maybe high speed serial..because there are not enough wires to address the LCD transistors. Anyhow.. I attach a photo of the connection on the top.
                      To get into that I will have to strip quite a bit... any other thoughts to why there is no text on the screen will be appreciated.
                      Thanks again. 73 de SA6BUQ, Christo
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        So the backlight is working ?
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Mb does 75% of the timing processing for the Lcd hence more ic's on it, but board on Lcd just unpacks it all to the tab drivers.
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            Thanks reece another thing ive learnt about these boards.
                            • SA6BUQ
                              • Dec 2016
                              • 11
                              • Sweden
                              Yes, ReeceyBurger it lights up as mentioned in the 1st post...that is the strange thing.. all voltages seems to be fine. I get no text/image on the screen though.
                              Not sure where to look next... checked the LCD.. no cracks, drops, dents.. and the backlight is evenly spread across the screen.
                              I've worked on a few from Plasma's to LCD, and this one has NO strange noise, caps or symptoms... apart from the LED in front not blinking when I press any button on the remote....
                              Any thoughts will be helpful.. I am willing to share/post any measurements, pictures that may help...
                              (in Sweden where things are tossed instead of repaired..Hi)
                              • SA6BUQ
                                • Dec 2016
                                • 11
                                • Sweden
                                Hej again,
                                So my thread on the Vestel here went a bit quiet. I hope I did not annoy anyone.
                                My mistake in the original post:
                                PSU board PL802:
                                +24.33V to T-CON OK
                                The cable from the PSU runs to the backlight inverter board (not T-CON as written). There is no seperate T-CON (see post from vinceroger).
                                Any more tips or thoughts on what could be wrong with this Vestel?
                                Regards
                                SA6BUQ
                                • Fly_Among_Stars
                                  VIZIO E70-E3 Half picture with half TCON
                                  by Fly_Among_Stars
                                  I have a VIZIO E70-E3.
                                  Symptoms: Black screen, no picture, but LED backlights are working.
                                  I probed the power board and voltages are as listed on the board.
                                  Main board appears fine, too.
                                  I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
                                  There are two separate ribbon cables feeding the LCD.
                                  If both are connected, the screen is black.
                                  If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
                                  04-24-2023, 08:20 PM
                                • shelby5041
                                  Samsung LCD TV no picture backlight on no 12v at tcon
                                  by shelby5041
                                  hi
                                  i have a samsung lcd tv
                                  it powers on with sound and backlight but no picture
                                  all voltages from PS are good 12v 3.3v and 5v
                                  whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
                                  i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
                                  no 12v at the tcon fuse
                                  i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
                                  the odds of having 2...
                                  10-08-2021, 08:21 AM
                                • x_orange90_x
                                  TCL 50S535 bad tcon or panel issue?
                                  by x_orange90_x
                                  Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                  03-29-2025, 11:02 PM
                                • Tr0ll
                                  by Tr0ll
                                  Original T-con:
                                  First replacement T-con:
                                  10-07-2023, 07:48 PM
                                • nick4275
                                  Vestel Based JVC no picture, leds on
                                  by nick4275
                                  Hoping someone has troden this path before !
                                  I'm looking at a JVC LT-39c790 - a vestel based unit.
                                  So, the remote turns it on, led's light up but no picture at all.
                                  I have a spare mainboard, so I know its not that. The PSU seems ok too.
                                  On the AUO T-Con I've got 16v on HAVDD_H but nothing on HAVDD_L - which I'm assuming should also be 16v ?
                                  So, Ive resorted to testing eveything I can on the board as I can't find any schemas for it (AUO 39T15 C04 Ctrl Bd) and I think I've found a diode gone short. it marked D005 on the board and E1 on the package...
                                  11-21-2023, 04:43 AM
