LG 50PK550 clicking - plasma newbie
    Re: LG 50PK550 clicking - plasma newbie
    No need to do anything now just make sure the female end is seated properly and then do the resistance test, use 200 Ohms scale.
    • jason424
      • Dec 2015
      • 187
      Originally posted by budm
      Check the resistance between the LINE (HOT) prong of the AC male plug and the red connector with Brown wire, see what you get, then check the resistance between the Neutral prong of the AC plug and the red connector with the blue wire to see what you get.
      That female end of the power cord does not look like it is inserted all the way in.
      I get .4 for resistance on the Hot/Brown. And I get .7 for the Neutral/blue.
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        #83
        when you touch both your multi meter leads together on 200 ohms whats you meter read?
        • jason424
          • Dec 2015
          • 187
          00.3 not sure why it's not at 0.00 any more...meter bad? Is there a way to zero it?
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            #85
            no not bad thats about what mine reads have you tested another item in the wall outlet to make sure its ok and works as i have no idea now why you have no mains voltage to that connector on the pcb hopefully budm can advise further
            also have you got another item you can check your meter works on ac mode and reads 120v or whatever your voltage usually is be carefull though as mains voltage
              So the wiring is good all the way one end of AC male plugs to the connector end of the circuit board, but yet no 120Vac present at the Brown and Blue wire's ends.
              So you are sure that
              1) you do have 120vac at the outlet.
              2) you are making good contact with the two legs of the red incoming AC connector.
              3) operator error.
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                #87
                thanks budm im still learing but was trying to go by step by step how i would trace this fault myself its just explaining things/terms to use i still get stuck with.
                • jason424
                  • Dec 2015
                  • 187
                  It was operator error, more so meter error. I went to test my outlet and my meter wouldn't turn on. I went out and got my better meter (GDT-11) and the red connector tests 125.5 volts at the red connector/brown and blue wires.
                  I apologize for the goose chase with my junk/cheap meter.
                    So all the power cord ends, red connector, and AC male plugged in properly and you do have 120VAC at the AC wall outlet, meter set to 200VAC and you put one of your meter probe at L, another one at N, the meter shows 0 VAC, correct?
                    Notes: we already verified that the resistance between the L on the red connector and AC plug L has < 1 Ohm, same for N on the red connector and the AC plug.
                    • jason424
                      • Dec 2015
                      • 187
                      No now with one on L and the other on N,I have 125.5.
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        #91
                        now you have ac power to the set check what dc voltages you have on the connector in post 66
                          Never mind, test equipment error.
                          • jason424
                            • Dec 2015
                            • 187
                            I've unplugged the connector that leads to the video board and tested the 18 pins (stacked 9+9) of the female connector on the board and don't get any voltage to any of them.
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              • uk
                              #94
                              ti think it was just his faulty meter budm now hes swopped too a new one maybe he will have some dc readings too as he didnt even have 5v stby not sure if you have read the whole thread budm but he fitted a new ic and when i asked him to clean the board one pad was lifted hence the red wire to join the tracks since then board seems dead no lights no clicking etc
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                • uk
                                #95
                                is your neter on dc volts black probe on tv metal chassis?
                                • jason424
                                  • Dec 2015
                                  • 187
                                  Yes set at 200. I get nothing, except when I get to the 4th pin on the bottom instead of just "0.00" I get "-0.00" so the negative symbol (-) comes up. Looks like that pin is marked as "ERROR DET"
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    • uk
                                    #97
                                    when your testing these voltages are all the boards connected if not try measuring again with alll connecting wires etc in place
                                    • jason424
                                      • Dec 2015
                                      • 187
                                      Power cord is plugged in to an outlet and all cables are connected except the one at that connector I'm testing.
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        • uk
                                        #99
                                        thats the one i mean plug it back in and maybe carefully touch the pins on the connector itself i dont know if the main board needs to be connected to get voltages etc. Hopefully reece or budm may advise us more regarding all the missing dc voltages
                                        • jason424
                                          • Dec 2015
                                          • 187
                                          I plugged that cable in and still get 0.00 across all pins (pic) with black on metal chassis.
                                          And I do still have 125 volts at the red connector
                                          • bffargo
                                            2014 LG 60" Plasma shut down just clicking unless I disconnect 17V line to main CPU
                                            by bffargo
                                            LG 60PB66550 NOV 2014
                                            PSU: EAY63168603
                                            PCB: EAX65359531 2013.11.01 Rev:1.0
                                            Main board: EAX65399305(1.0) 13.11.27 PU42A/PA42A/PD42A
                                            Symptom:
                                            While watching, just went black and started clicking relay every few seconds.
                                            Initial diagnosis:
                                            Removing JUST the main CPU/Input PCB from circuit stops the clicking. No problems with any other boards/drivers. (Removing all other boards and only putting Main back in is all it takes to start clicking again)
                                            Deeper diagnosis:
                                            Pulling pins #1/#2 (Blue/Grey) from the connector housing...
                                            09-09-2022, 07:34 PM
                                          • Sisko
                                            Onkyo-593 No power and now clicking sound
                                            by Sisko
                                            Hi all!!
                                            Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
                                            10-03-2025, 02:18 PM
                                          • B0r1s
                                            Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                                            by B0r1s
                                            PSU - BN44-00878A
                                            Symptoms:
                                            The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                                            A weak clicking sound was coming from the transformer.
                                            Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                                            Progress:
                                            After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                                            01-17-2023, 04:58 PM
                                          • novak2
                                            Panasonic th-42px60en plasma TV takes time to turn on and make clicking noises
                                            by novak2
                                            Hello there,
                                            I recently bought a Panasonic th-42px60en plasma TV second hand. The problem is :
                                            The TV takes time to turn on from cold (being unplugged from the night for example), it tries to turn on with the clicking sound, then shuts off, then retries and so on. The TV is still working, just it takes time to boot.
                                            From what I've read it seems to be bad capacitors on the power board, but I just want to see if anyone had the same problem with this TV.
                                            Thanks in advance.
                                            09-25-2020, 02:34 PM
                                          • slimmy182
                                            [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                                            by slimmy182
                                            Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                                            I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                                            Looking on google I found this:...
                                            01-14-2023, 11:55 AM
