Samsung Un50h6201 no pic , disconnect one ribbon on tcon and half half a picture with
  • kca
    by kca
    Hello all ~
    08-31-2025, 06:38 AM
  • x_orange90_x
    TCL 50S535 bad tcon or panel issue?
    by x_orange90_x
    Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
    03-29-2025, 11:02 PM
  • netgearnetgear
    TCL 43S423 TCON OR PANEL FAULTY???
    by netgearnetgear
    Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
    08-20-2025, 06:04 PM
  • howardc64
    TCL 49S405 double image
    by howardc64
    LCD displays a 2nd image slighty offset vertically. And multiple pairs of black lines along the bottom. Probably common as google "TCL 49S405 double image" pulls up this ifixit post ( link ) with identical ( nearly, but their fault seems to be on the other half of the panel than mine ) problem without solution.
    This one looks to be a more difficult to diagnose because most? of TCON seems integrated ( CSOT BGA on buffer baord) into the left panel edge board ( looking from rear of TV) There are 2 buffer boards for each 1/2 of the screen. Main connects to the left buffer board...
    06-23-2025, 03:20 PM
  • Kikerumbo
    Mi Curved Gaming Monitor 34" - Horizontal lines
    by Kikerumbo
    Thanks in advance for any help you can provide.
    I have a Mi Curved Gaming Monitor 34". A few weeks ago it started to show (or not showing) horizontal lines. Of course, it's outside of the warranty period.
    After some hours of reading and watching videos I disassembled the monitor and checked the ribbons that go from the TCON board to the panel PCB. If I disconnect the ribbon for the right side of the panel, the other half shows a perfect image. I ordered a "new" TCON, installed it and the issue persists so that tells me it must...
    03-14-2024, 02:48 PM
