Service menu for Hitachi LE55*
  • Pioneerx01
    • Apr 2015
    • 241
    • US
    I have Hitachi LE55G508 with bad main board. There do not appear to be any identifiable part numbers for these boards, and there are many versions based on board number.
    I have gotten a replacement board, but the image is inverted, which could be caused by different panel settings for the main board. I am tying to find a way to get to a service menu to see if I can change it, but I can't find a method that works online. All the sites have the same 3, but none work for me.
    Anyone know how to pull up the service menu?
  • fcisolutions
    • Jan 2017
    • 205
    Re: Service menu for Hitachi LE55*
    I'm not sure if you found a solutions but before I order ANY parts I cross reference on a site called "shopjimmy.com". It really saves me time. Just search by your tv model number and it will give you compatible parts. It's not perfect, but it give you more information than you may have had.
    • Pioneerx01
      • Apr 2015
      • 241
      • US
      Yes, I know of shopjimmy. They identify only one compatible board with LE55G508 and they are out of stock. I have already gotten a replacement board from other vendor
      • olegeisler
        • 100
        • Denmark
        Method 1 should be correct
        1.1 HOW TO GET TO ADJUSTMENT MODE
        Chassis adjustment mode can be access by pressing
        the R/C keys MENU + MENU + 8 + SELECT to enter
        adjustment mode. For some parameters the only way
        to see them is by selecting the parameter number than
        pressed SELECT in order to see it; then DATA can be
        change if other parameter needs to change then press
        key then repeat the same procedure.
        • Pioneerx01
          • Apr 2015
          • 241
          • US
          Yes, that is one of the 3 methods that I have mentioned trying. It did not work.
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            is your replacement mainboard used in other sets? im wondering if using a diffrent tv manufactures service menu code will let you access it.
            • Pioneerx01
              • Apr 2015
              • 241
              • US
              As far as I know it is only for once specific model. Hitachi TVs are often difficult to get parts for. No worries, I have already gotten a main ford from another vendor and the TV works just fine. The first replacement was probably listed incorrectly from a different model.
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                yes as you say maybe correct for that tv model number but wrong lcd panel etc main thing is you have got the set repaired so alls good.
                  LCD LED TV Service Menu Codes
                  TCL LED TV Service Menu Code
                  LG LED TV Service Menu Code
                  10-31-2024, 03:58 AM
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
                • sotodefonk
                  Help finding the correct model of a T-Con board on my Hitachi TV
                  by sotodefonk
                  Hi, I have a Hitachi tv model L47V651, there is no image, but sound and backlights turn on, so I believe the issue is the tcon board.
                  I opened the tv to access the board and took the shared pictures of the T-Con board.
                  I saw a video from shopjimmy on how to detect the model number on tcon boards, but this doesn't have a sticker like how that video showed all boards.
                  I searched the P/N number and got results with the same marking name and P/N my board has but they list other specific tv models like Vizio and Philips brand but not Hitachi.
                  Inspecting...
                  06-28-2024, 04:39 PM
                • Hakuu
                  by Hakuu
                  Hi There,
                  More Details
                  TV Model - LG OLED77G1PUA
                  07-12-2023, 02:37 PM
