  • m1ch43lzm
    • Mar 2019
    • 1115
    • Peru
    Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic smoke" escaped from it) next to the RAM slots, and when I removed the blown TPS51486, it left a crater on the board with burnt PCB
    Similar issue as this thread: https://www.badcaps.net/forum/troubl...on-15-eh1815nd
    I tried to rebuild the crater but I gave up, I even ordered some TPS51486 ICs from aliexpress
    Anyways, bought another board from Aliexpress, and this "new" board has some issues, let's call it Board B
    On battery:
    - The board appears to work fine, it boots normally to Windows, but sometimes the CPU would throttle to 0.4GHz depending on load, checking with HWINFO64 reveals that Thermal Throttling (PROCHOT_EXT) and Thermal Throttling (HTC) report a value of "Yes" when that happens
    - Running CPU stress tests (Cinebench R23), it would "thermal throttle" within 30-40 seconds, the CPU temp doesn' get hot enough (max 70 deg. C and the fan woudn't even turn on), and stopping the stress test and it takes around 2 minutes for PROCHOT_EXT to get "no" as a value, something has to "cool down"
    With charger plugged in (doesn't matter if the battery is installed or not)
    - Same thing, boots to Windows (I'm writing this right now from this laptop), but running Cinebench, the screen would go black almost instantly and the power LED stays on, holding the power button works to turn off the laptop, and can start again
    - Measured VCC_CORE and VDDCR_SOC when the screen goes black = 0v
    - Black screen can also happen when watching YouTube but it takes some time, sometimes just "thermal throttling" with the CPU stuck at 0.4GHz for some minutes, simple usage like web browsing doesn't seem to trigger the fault, as i'm still typing this post
    - Battery does charge normally
    I don't have a thermal camera
    CPU VRM controller on this board is uP9531P, but it's on the back of the board, no way to easily test with running system as the board is assembled in the laptop (and power button is on the keyboard), the schematics state RT3662AMGQW, maybe they're pin compatible, i only have RT3662AC from Ali (maybe legit, maybe fake, who knows)
    CPU MOSFETs are AOE6936
    SOC MOSFET is AONY36356
    I don't know what could trigger PROCHOT_EXT when on battery and/or disable VCC_CORE and VDDCR_SOC when under a CPU stress test with the charger plugged in, yet the test would start but "thermal throttle" when working on battery only
    CPU temperatures on this board B don't go high enough to "normally" trigger thermal throtting, the max temp I see is 67-70 deg.C, on the original board A, CPU could go 90 deg. C and not thermal throttle under any circumstance
    Original board (Board A) has CPU: Ryzen 7 4700u (model in BIOS: 15-eh0xxx)
    Replacement board (Board B) cPU: Ryzen 7 5700u (model in BIOS: 15-eh1xxx), same board number DAG7HAMB8F0
    There was almost no price difference so i thought i would get a CPU upgrade at the same time😂
    Board A
    BIOS version (last I remember) was F.29
    EC version: 80 something, i don't remember, board is dead
    Board type: 87C5 (IIRC)
    Board B
    BIOS version: F.25
    EC Version: 78.51
    Board type: 88D0
    The solder joints at the BIOS don't look factory soldered (and that seller on Ali placed a "warranty sticker" over the BIOS), likely the BIOS IC was removed for programming whatever it has right now
    Any suggestions about fixing this board? I have Board A as a donor (or should I try to fix board A?)
    Schematics/boardview: https://www.badcaps.net/forum/troubl...=2#post1810731
    Attached pictore shows PROCHOT_EXT and HTC change to "yes" on HWINFO64
  • m1ch43lzm
    • Mar 2019
    • 1115
    • Peru
    Pictures of the damage on board A (original board from the laptop), if anyone is interested, I already cleaned the soot, second picture is the "before" state
    Also the 2823D IC on the left from the first picture was shorted
    • mon2
      • Dec 2019
      • 14832
      Not sure but PROCHOT_EXT may be an open-drain pin so a pull-up resistor on this line is mandatory. Confirm it is present.
      • m1ch43lzm
        • Mar 2019
        • 1115
        • Peru
        mon2 according to schematics I can't find a pull-up on PROCHOT#
        It only goes to 4 places
        - APU itself, as APU_PROCHOT#, tied to H_PROCHOT#
        - EC, H_PROCHOT#_EC, then goes through Q4702 and becomes H_PROCHOT#
        - Charger ISL9238 PU8200, H_PROCHOT#
        - CPU VRM controller PU8800 as VRHOT, which is tied together to H_PROCHOT# with trace jumpers R625 and R626
        • mon2
          • Dec 2019
          • 14832
          R622
          • m1ch43lzm
            • Mar 2019
            • 1115
            • Peru
            I must have missed it when looking at the schematics from my phone
            Will check it later, when I get back to my other PC
            thanks
            • m1ch43lzm
              • Mar 2019
              • 1115
              • Peru
              mon2 you're right, i took measurements from the Board A (dead), and Board B (the one i got from ali), i wont be able to replace the resistor right now, will update when i get time to do it properly
              Thank you for pointing that out
              Board A
              R622 1.02k
              Diode reading (red probe on GND) at R622 H_PROCHOT# 0.534
              Thinking it was the thermistors, i took measurements anyway (yes, i know they're in parallel to other resistors in the schematic)
              PR8864 15.9k
              PR8816 15k
              PR8823 15.08k
              PR8852 16.52k
              Board B
              R622 440k-460k, varies every time i probe it, so yes, it's faulty
              Diode PROCHOT# 0.440
              PR8864 16.94k
              PR8816 15.07k
              PR8823 15.03k
              PR8852 16.63k​
              R622 is a 0201 resistor near the heatsink, attached picture of the location
              I added some notes about the location of a testpoint of APU-PROCHOT# and the trace jumpers R626 and R625 (they designed them to be difficult to cut on purpose, instead of just addind a narrow section to them)
              So yes, heat in the area will probably make that resistor drift to a higher value, but i still can't find an explanation why it instantly loses VCORE and VDDSOC only when on AC power, while i start cinebench stress test
              Have to try to replace it to check what happens next, whether i grab it from the donor Board A or find it in some other random board i have
              • m1ch43lzm
                • Mar 2019
                • 1115
                • Peru
                I'm back, replaced R622, PROCHOT doesn't trigger anymore when running Cinebench... on battery
                Yes, it looks a bit misaligned as i used the soldering iron, didin't want to use hot air near the CPU, in the process managed to "lose" C602, placed it back with the soldering iron
                But with the charger plugged in, if i start Cinebench, at the "Preparing render test" phase, laptop crashes with black screen, power LED still on (likely VCC_CORE/VDDCR_SOC goes missing again), on light CPU load it doesn't happen
                The charger is 45W, original charger which came with the laptop
                Noticed also that the fan wouldn't turn on at all unless i change the "Fan always on" setting on BIOS, the CPU temp went up to 90 deg. C while running stress tests and the fan woudn't turn on at all, could it be the EC firmware? Noticed that the soldering on the EC doesn't look factory
                Something else is still wrong with this board
                • m1ch43lzm
                  • Mar 2019
                  • 1115
                  • Peru
                  Noticed something else, my keyboard (Latin American Spanish) has a "><" key next to right Alt, but that "><" key currently works as a Right Ctrl, it's not the keyboard language setting in Windows, as all the symbols match, and that key worked before as it's printed on the keycap
                  I checked pictures of the keyboard online, and only the US English keyboard has a Right Ctrl key instead of "><" (or something else, on other languages), maybe some hidden BIOS setting? (feature byte/product id?)
                  The BIOS from this board (88D0) is different than from the dead board, even HP website lists different bios updates for the 15-eh0000 and 15-eh1000, so i can't directly flash it with the dump of the dead board (87C5)
                  My keyboard / US keyboard layout
ID:	3645430 Click image for larger version
                  To sum it up:
                  On battery only:
                  Laptop works fine even on stress tests or heavy usage, doesn't trigger PROCHOT anymore since i replaced R622
                  - Cinebench does complete without thermal throttling
                  - Unigine Heaven does run without issue
                  With charger plugged in:
                  Laptop works for light usage, i'm writing this post from it, but it crashes to a black screen when:
                  - Stress testing with Cinebench, instant crash after starting single core/multi core benchmark
                  - Unigine Heaven doesn't crash, but i made it crash once with black screen/audio stopped after about 3 seconds of rendering
                  - CPUID powerMAX doesn't crash (i only tested for 1 minute), either CPU and GPU tests
                  - Sometimes randomly crashes with black screen depending on load, or a current spike (?)
                  - When it crashes, doesn't respond to Caps Lock, the only way to get it working again is to hold the power button to turn off, then press the power button again​
                  Any help is appreciated
                  • Ludmilaharhordina
                    • Feb 2025
                    • 35
                    • Украина
                    Good afternoon, please tell me what the resistor values ​are next to the uP9531P?
                    • m1ch43lzm
                      • Mar 2019
                      • 1115
                      • Peru
                      Hi, here, measurements from the Ryzen 7 4700u board
                      All measurements done in circuit
                      PR8802 same as sch 4.7
                      PR8817 1.41k
                      PR8822 1.41k
                      PR8826 1k
                      pr8812 close to 0ohm
                      pr8813 15.4k in circiut
                      pr8815 14.2k
                      pr8814 14.8k in circuit
                      Several resistors in that area on the 8F0 board are different values compared to the schematic for the 8E0, unfortunately the proper schematic/boardview doesn't exist
                      I still haven't fixed the "working" 5700u board, already tried flashing a clean BIOS from HP website (older version F.20), which Windows immediately updated to F.31 before even getting to the desktop, still the same, crashing under load when AC adapter is plugged in; of course not all issues are BIOS related
                      Only works "properly" on battery
                      • Ludmilaharhordina
                        • Feb 2025
                        • 35
                        • Украина
                        thank you very much
                        • howardc64
                          by howardc64
                          07-24-2025, 05:17 PM
                        • Hakuu
                          by Hakuu
                          Hi There,
                          More Details
                          TV Model - LG OLED77G1PUA
                          07-12-2023, 02:37 PM
                        • Soulzink
                          Samsug washing machine. Power supply DC41-00189a board issue
                          by Soulzink
                          I am trying to fix a samsung washinmachine power supply main board.
                          I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                          Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                          The power supply board reference is the following: DC41-00189a
                          I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                          04-19-2025, 06:26 AM
                        • jb_Bak
                          by jb_Bak
                          CN6401
                          Pin 01 NC
                          Pin 02 NC
                          Pin 03 "BL_ON": 0V
                          Pin 04 "N/C"
                          Pin 05 "STBY 3.3V": 3.5V
                          Pin 06 "GND": N/C
                          Pin 07 "AC_OFF"...
                          09-27-2021, 04:52 PM
