Toshiba regza 52" sound no picture
  • Dan Surra
    • Dec 2016
    • 36
    Our 52" Model # 52RV520U has sound but no picture. Turns on. Green light is lit at bottom of TV face but screen is black. Which panel of the three major one in back of TV would need to be replaced? Appreciate any help or advice.
    This happened when our Dish service was giving us issues. The picture was freezing (just like you paused it) and was in that mode for a while as the Dish techs were in basement trying to diagnose the problem. When they left the basement flat screen was working but the Regza in upstairs living room ended up black screen with sound. No menu, nothing. You can even change to different channels but only get sound. At first I thought it was just a coincidence. I moved smaller flat screen from down stairs to living room until I could repair the Regza. The Dish issue returned that evening and I had dozed off. When the freeze issue happened in the past I would simple return to previous channel and it would start working again. I never let the screen frozen for a long period. Doubt that 2 sets would have same coincidence. Now I have two newer TV's with sound and no pic. I haven't torn into that one yet. I see the various panels in back of the Regza for sale on line at decent prices. If someone could clue me in as to which one has the issue it would be great. Thanks!
  • mmartell
    • Oct 2013
    • 3189
    Re: Toshiba regza 52" sound no picture
    Get up close to the screen and shine a flashlight on it. It might be helpful to pull up the menu as you know where it should be on the screen.
    Do you see anything?
    • Dan Surra
      • Dec 2016
      • 36
      there is nothing that I can see. Just a black screen.
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Do this test in a dark room....If still nothing remove the back of the TV and see if the Backlight turn ON.....you would see the white light shining through the little holes on the metal internal backing.
        • Dan Surra
          • Dec 2016
          • 36
          I have back off and when I turn it on one of the panels has a little green light that is lit and you can see a red light coming through a piece on another panel. not sure if that is what you are talking about but I can post a pic if you would like. Thanks for you interest
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            OK...so you don't have backlights...
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Please start by doing some research on the forum on your fault and how to diagnose it.
                At 2:14
                https://www.youtube.com/watch?v=xUzCLgoSPGM
                • Dan Surra
                  • Dec 2016
                  • 36
                  thank you BudM. video was very helpful for a novice. I have no back lights for sure. I am going to do flashlight menu test later today.
                    We will also need the pictures of the whole back side of the TV showing all the boards so we can see how all the boards are connected together.
                    • Dan Surra
                      • Dec 2016
                      • 36
                      ok, flash light test with room dark revealed that I can indeed see the menu. I am going to try and post pics of back of tv
                      • Dan Surra
                        • Dec 2016
                        • 36
                        here are pics. center section is actually two boards side by side. one is a tan/brown and other olive green.
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          I would start by checking the 24v and Blon voltages going to the inverters then checking fuses on the inverter.
                            OK, it has two power supply boards: Main and Sub.
                            We need straight shot pictures of each power supply board so we can clearly the label for each pin of the connectors.
                              BTW, please verify the model number of the TV:
                              Toshiba 52RV520U???
                              • Dan Surra
                                • Dec 2016
                                • 36
                                ok, dumb questions. I have volt meter but which board is the inverter and what pins would they be? All the normal vacuum type glass fuses are OK but I suspect you are talking about pieces that are soldered into the circuit. I apologize for being so ignorant as to what is what in this TV. But with you guys helping, I am learning. What I would like to do is try and diagnose the problem and then change that board. They do not seem to be that pricey.
                                • Dan Surra
                                  • Dec 2016
                                  • 36
                                  Toshiba 52RV520U???
                                  Model # is 52RV530U
                                    Originally posted by Dan Surra
                                    Model # is 52RV530U
                                    OK, that is why I could not find the info for it.
                                    Toshiba 52RV530:
                                    http://www.shopjimmy.com/catalogsear...shiba+52RV530U
                                    Service manuals:
                                    http://elektrotanya.com/?q=showresul...oria=&kat2=all
                                      Service manual.
                                      Check those Voltages when TV is off and when the power switch is activated.
                                      • Packard93
                                        • Jul 2016
                                        • 81
                                        What does ur standby light and power light do ? Does tv make any noises like clicking relay and then u get standby light?
                                        • jord4231
                                          Toshiba 37AV500A Regza TV good power supply no sound no picture
                                          by jord4231
                                          Hi Everyone,
                                          I'm working on a Toshiba 37AV500A Regza TV.
                                          The issue:
                                          TV was working picture and sound went out. Green stand by light stayed on, It will respond to the power button being pressed (goes in and out of standby)
                                          The TV will very intermittently work for around 40 mins then stop. This doesn't seem to matter if its hot/cold unplugged for a while etc.
                                          I checked the PSU voltages and everything looked good.
                                          No bulging caps or signs of heat.
                                          24v aud = 24.41v
                                          12v = 11.98v
                                          5v = 5.062
                                          p_o/f = Goes high...
                                          03-29-2022, 09:21 PM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • jchang
                                          Samsung UN70NU6900F no picture and no sound
                                          by jchang
                                          Hi all
                                          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                          Symptom:
                                          No picture no sound.
                                          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                          No sound at all.
                                          What I tried:
                                          1. I tried unplugging the left or right ribbon...
                                          01-09-2023, 06:28 PM
