Sony KDL-40M4000 Stuck on Bravia logo
  • art_dodger
    • Nov 2013
    • 18
    I have a customer's Sony Bravia KDL-40M4000. (Manufactured 2008)
    When powered up, the green power LED lights, backlight comes on, the word "Bravia" appears in white on a black screen, then just stays there forever. No menu, no options to get past the splash screen, chassis buttons (Vol, Chn, etc.) do nothing.
    The only button that appears to function is the power button itself. (And it's a little flaky as well - I believe the power switch may just be dirty - It feels like it "bounces" when depressed and the TV will often power on then immediately off again on removing your finger from the button. Pressing it more firmly seems to allow it to stay on)
    I assume the failure to move past the Bravia boot logo would indicate a Main board issue, as that's where all the logic resides... BUT - Before I go ordering a replacement Main board, anyone else have any experience with this issue? ("Bravia" boot logo splash screen never disappearing). Anything on the power board that could cause that symptom?
    It's not a TCon problem and it *seems* like the power board should be ok because it is powering up, backlights working, logo displayed, etc. It just doesn't want to continue past the logo. As far as I can determine, the only "Factory Reset" available on this model must be done via the remote and on-screen menus - Not an option because I can't get past the Bravia logo to GET to a OSD.
    I've been a qualified electronics technician for 30 years, I have a full commercial shop & all the necessary test equipment. It's the first time I've encountered this particular issue and have had no luck at all Googling the problem.
    Any suggestions/tips/tricks/experience from those more familiar with Sony TVs would be gratefully accepted.
  • Diah
    • Feb 2013
    • 6566
    Re: Sony KDL-40M4000 Stuck on Bravia logo
    why don't take photo for us and you too to know which part no of the chassis and main boards serial No. to help you..
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Possible EEprom problem. If you have a scope then you can check the data line (SD and CLK) to see there's still activity once the logo appears.
      If you don't then you can try freezing it to see if it boots. Also a search the web / forum to see if there is an issue with the EEprom on this set.
      http://electronicshelponline.blogspo...m4000-kdl.html
      • art_dodger
        • Nov 2013
        • 18
        Well, I'm not sure a photo will help much, but here are the part nos:
        Chassis: Sony KDL-40M4000
        BM Board (Main board): A-1547-029-A
        Power board: IP5Z-40A
        I've got the service manual but besides component location, it isn't much help. The troubleshooting table is VERY basic.
        Any additional suggestions gratefully accepted.
        • Packard93
          • Jul 2016
          • 81
          Ive seen this issue when I fixed it .it was fixed without replacing any the techs from a paid forum suggested . But I did this without any parts.After many years of working with electronics . I got it working after I did this .
          • martino
            Not so "senior"
            • Aug 2013
            • 997
            • canada
            What??
            Proud owner of dozens of broken TV's and many,many,many boards.
            Our website and passion:http://hollenhundshepherds.com/
            • conghuyms
              MacBook Air A2179 stuck logo , pls help me !
              by conghuyms
              Hey everyone,
              I’ve got a MacBook Air A2179 that got some water damage through the keyboard. Now it powers on, shows the Apple logo, but just stays stuck there — no startup chime, no keyboard backlight, and no progress bar under the Apple logo.
              When I try to boot into Internet Recovery (Option + Command + R), the mouse cursor is extremely slow and laggy — like when I lift my finger off the trackpad, the cursor keeps drifting slowly for a second or two.
              I opened it up and found some corrosion around the LED driver IC area on the logic board. I cleaned...
              11-05-2025, 08:30 AM
            • JUCaESAl
              Sony bravia KD-65AF9
              by JUCaESAl
              Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
              Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
              10-20-2025, 04:03 AM
            • x_orange90_x
              Vizio V555-G1 stuck on wallpaper; now stuck on V logo
              by x_orange90_x
              I just got this tv today and it's getting stuck on the wallpaper. When I first power it on it goes to the V logo, then a black screen for about 15 seconds, then a Chromecast error for just a few seconds, and then finally to a wallpaper. It stays frozen on this wallpaper and does not respond to anything on the remote besides power on/off. Likewise the buttons on the tv do nothing either (besides power). I did the "reset" by holding the volume down and input buttons together for 10 seconds. It showed a message at the top of the screen saying it was Wiping Data and would restart soon. After...
              12-28-2023, 06:26 AM
            • G33RT
              Philips 8200 series 65PUS8204/12 stuck at Philips Logo
              by G33RT
              Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
              It does power up when pressing the power button.
              I already try the power button while plugin the plug with no result.
              Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
              Could this be an PSU or eMMC issue ?
              07-19-2025, 03:43 AM
            • mauda
              Sony TV model KD-65XE7005 - only Sony logo for 3 seconds
              by mauda
              I'm currently working on repairing a malfunctioning Sony TV model KD-65XE7005 with the mainboard 1-981-926-21. I would appreciate your assistance with this issue.
              Upon powering on the TV, the Sony logo appears for approximately 3 seconds, after which the backlight remains lit, the screen remains black, and nothing else happens. The TV consumes around 55W initially and then drops to 35W. The indicator LED remains solid white. It doesn't respond to the remote control. When attempting to update the TV using a USB dongle, the dongle briefly flashes but nothing else happens.
              05-21-2023, 11:56 PM
