Samsung LA46S81BDX/XSA - Lines after 5 mins, restart... fine for another 5 mins
  • Geniee33
    • Jun 2015
    • 45
    I have a Samsung LA46S81BDX/XSA that starts up fine, its all great, but after a period of time, can be 5-10 mins, the whole screen is showing horizontal and verticle lines over it.
    I have replaced the Tcon, nothing, also checked all cables put pressure on the rubbons, cant change the output.
    I also put the main board through the oven for 10 mins to re-flow any solder as this has worked for me in the past.
    Once its all garbled up, i can turn the tv off, and back on and it will be fine for another period of time.
    Can anyone please help me?
    I can get readings on output voltages and what not, but the power supply seems ok it never has issue starting nor does it make odd noises.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Samsung LA46S81BDX/XSA - Lines after 5 mins, restart... fine for another 5 mins
    Bad panel IMHO.
    • Geniee33
      • Jun 2015
      • 45
      hmmm, but i dont understand why it is fine for a period of time after a restart?
      I initially thought it might have been part of the heat cycles, and possibly a very fine connection problem on one of the ribbons, and the very micro heat expansion creates a short or a connection loss... but i removed the front panel/cover and while the LCD was in that state touched on all of the connectors and couldnt change the output.
      Is there anything to gain by testing / getting all the PSU output voltages? although i am not hearing any relays or strange noises occuring.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Mainboard fault, what board does it use ?
        • Geniee33
          • Jun 2015
          • 45
          I will have to get the name/numbers tonight.
          • Diah
            • Feb 2013
            • 6562
            neither mainboard.....
            its voltage filter caps on power supply board issue ... only use cool spray to discover with cap make this fault.
            • Geniee33
              • Jun 2015
              • 45
              oh really? I was thinking it might be worth replacing the caps just because of the cost is so low and the job is rather easy...
              If i can get the voltage outputs on the power supply board in the good state and compare against the bad state, i have a theory that it may show up some differences.
              • Diah
                • Feb 2013
                • 6562
                no this we call it noise.. out put voltage may read correct in average.. but it had absolute different Hz. this easy to know with oscilloscope. which if you want to have one will cost on your prise of 10 tv as the one now under your hand. also cool spray will be yours oscilloscope.
                • Geniee33
                  • Jun 2015
                  • 45
                  ok, i will give it a shot.
                  I will update the post when i have more information in the hope it helps other forum users.
                  thank you.
                  • Geniee33
                    • Jun 2015
                    • 45
                    FYI the board is IP-301135A
                      Power supply board should be BN44-?????
                      This one?
                      http://www.shopjimmy.com/samsung-bn4...upply-unit.htm Samsung BN44-00166B
                      I have not seen bad power supply causing horizon lines like that. O have seen bad caps in power supply to cause this symptom as shown in attached pictures, and it will go away when lytics caps are heated up which will cause the ESR to go down and the circuit will function normally again. When lytics caps are cooled, the ESR will go up and cause problem.
                      You can use canned air spray upside down for cooling.
                      • Geniee33
                        • Jun 2015
                        • 45
                        Yes thats correct.
                        I just counted and cross checked against a list of caps from an ebay ad.
                        Will be getting
                        2200uf 10v (i will get a 25v) * 2
                        1000uf 25v *2
                        1000uf 100v *1
                        47uf 50v *7
                        10uf 50v *5
                        They dont look bad at all, but for about $16 and an hour, cant hurt to try it out.
                        I wont be replacing the big 450v caps.
                          There is 1000uF 100VDC cap on that board?
                          • Geniee33
                            • Jun 2015
                            • 45
                            yes, 1
                            located at the lower side with all the other caps "CB850"
                            • Geniee33
                              • Jun 2015
                              • 45
                              This one?
                              Yea, im kinda just *hoping* it helps.... guess for the small price, i can knock one more thing off the list.
                              With the cooling spray, if i spray some parts, like the caps on the main board, do i leave the tv on and see if it starts working again? or whats the procedure?
                                yes, 1
                                Hmm, the schematic for the REV C board shows the cap as 1000uF 10VDC used for the 5.2VDC power supply filter.
                                • Geniee33
                                  • Jun 2015
                                  • 45
                                  yes, sorry my mistake.... it was very small text and i read the cap wrong.
                                  it is a 1000uf 10v.
                                  thanks, you saved me another trip to the store
                                  • Geniee33
                                    • Jun 2015
                                    • 45
                                    replaced all the caps on the power board, (except the big mofo 450v ones) ... started up fine, after 5 mins, back to junk.
                                    Turn off
                                    Turn on
                                    Working for another 2-3 mins, then garbage.
                                    I also tried switching sources to analog TV thinking maybe it was the digital tuner, but nah still junk.
                                    • Geniee33
                                      • Jun 2015
                                      • 45
                                      hmmm, whats interesting is, while i was trying to cool the back with a fan... LOL (no freeze spray on me)
                                      I removed 1 of the 2 tcon board ribbon cables, half the screen went white, but the other half came back to a normal picture.
                                      I put it back in, went junk again, wiggled it, nothing.
                                      Removed the other side, still junk.
                                      So i think it might be that ribbon cable... because even tho putting pressure on it does nothing, i finally got it just plugged in in a way that the picture was fine on both sides for a good 10 mins.
                                      I also have tried replacing the tcon board on that set, so i am sure the board itself is ok.
                                      Are those ribbons replaceable? they are short and i remember connect to the circuits on top of the tv before then going into the panel
                                      see pics.
                                        That is bad panel, more likely the TFT driver ICs (they run hot) that when they get hot and cause the problem you see on the screen.
                                          09-07-2024, 05:50 AM
                                        • fulepost@outlook.com
                                          Samsung "QE" series QE55Q70RATXXC Intermittant restart in "home mode".
                                          by fulepost@outlook.com
                                          Dear all.
                                          I'm a less knowledgable member who would appreciate some guidence.
                                          I have a Samsung QE55Q70RATXXC that works perfectly in "shop mode" but in home mode it restarts, Intermittantly.
                                          With intermittant I mean the TV can work perfectly for a week and suddenly start to restart. Before the restart it may reach different stages. Sometimes it restarts when the "QLED" start screen shows up and some thimes it restarts after hours, and everything in between.
                                          When the restart occurs, the screen blacks out leaving a light area alomng the edges fading...
                                          11-09-2025, 07:10 AM
                                        • Falki
                                          Colorful LCD Vertical Lines on Samsung ue55es8090
                                          by Falki
                                          Hello there, ive recently found an older 55inch Samsung SmartTV.
                                          A similar issue has been posted as well but also with no actual response ...
                                          08-12-2025, 04:19 AM
                                        • Rubenlily
                                          Samsung QE50Q67TAU - horizontal lines
                                          by Rubenlily
                                          First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
                                          I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
                                          I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
                                          I'm no expert but I've done the tape...
                                          08-16-2023, 01:12 PM
                                        • jeyoung12
                                          Samsung QN50Q60t lines on screen
                                          by jeyoung12
                                          Hi all
                                          I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
                                          My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
                                          This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
                                          It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
                                          So....i don't know what end of the C ribbon to work with...
                                          02-26-2024, 10:38 AM
