Re: Vizio VO47L-FHDTV10A turns on and then off (3 seconds)
1.You must measure the inverter input voltage( labeled 24v on the power supply) between 24v and SGND.(DC)
It should be 24v with the TV on and while the main filter caps measure 391volts.
If it measures 24v, you also have an inverter problem.(No backlight)
2. Not being able to turn your TV Off with the power switch indicates a main board problem as well.
