LG 42LW4500-LB Need help with repair of PSU
  • UndeadLuke
    • Nov 2016
    • 25
    • Czech Republic
    Hi guys today my TV stops working (it woudnt turn on only led shine so the power goes into it) so i remove the back panel and unscrewed the PSU I checked the capacitors but all of them seems to bee good psychicaly I dont check their capacity if its good or not because no one of them is leaked after that i check whole board with my multimeter (PAN33D) and i found 2. suspicious components (it was thermistor) when i put + and - of my multimeter on it and multimeter was set to beep when he found short-circuit it beeps so I dissolder this 2 thermistors and do it again i again put + and - of my multimeter on their poles and it against beep so i think my TV wasnt start because this thermistors are in short-circuit (i read thermistor is for protecting whole board from short-circuit) So please can you help me ? I also need buy new but my local store doesnt have this one (I put photo in attach smaller one had DSC10D-9 printed on it and the bigger one had DSC-5D-15 120) if you dont understand me i will record a video on Youtube.Thanks for help
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: LG 42LW4500-LB Need help with repair of PSU
    Thermistors should show short or low ohms, what voltage have you got on the main filter caps ?
    • dick_barton
      • Aug 2015
      • 6642
      • Wales
      They are probably OK. Measure their ohmic value.
      • dick_barton
        • Aug 2015
        • 6642
        • Wales
        There are a number of fuses on the board which you have checked and were OK?
        What dc voltages do you have across the 2 legs of each of the 3 long capacitors.
        • UndeadLuke
          • Nov 2016
          • 25
          • Czech Republic
          Okey so thermistors are good if they signal short ? I dont know what is main filter cap on this board but I think it is the gray one (photo in attach) also how can i find the voltage without put in in my 230v plug ? Iam noob in this hte black thing under the gray capacitor is 230v plug
          • UndeadLuke
            • Nov 2016
            • 25
            • Czech Republic
            Ok I will solder them back
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Check the forum using the search feature on how to test Psu.
              • UndeadLuke
                • Nov 2016
                • 25
                • Czech Republic
                I cant check the voltage of the 3 long capacitors with power on because my multimeter support only 230volts but the capacitors had 450v
                • dick_barton
                  • Aug 2015
                  • 6642
                  • Wales
                  The attached picture looks like your power supply and if from an LG-47LW5700 model.
                  Can you check you have the voltages shown in the table.
                  • UndeadLuke
                    • Nov 2016
                    • 25
                    • Czech Republic
                    Yes I can but before I will return the thermistors also must i plug the 230v in it ? i had the down model of board so i will check it but i think the leds work because my tv turn on for second and then turn of like she found short circuit
                    • dick_barton
                      • Aug 2015
                      • 6642
                      • Wales
                      It's very likely the set has powered down because there is a fault, however that is what you are trying to find. Nothing is blowing up or burning.
                      You really need a meter that has a 600V DC range to test that the mains supply is being rectified and is reaching the higher voltage parts of the circuits. For example to find out if you have 400V on those capacitors.
                      • UndeadLuke
                        • Nov 2016
                        • 25
                        • Czech Republic
                        Okey but I dont understand why they put higher voltage capacitors than it came to board they are dimensed to 470v nothing in my country has 450v maximal range from plug is 380v i will wait 2 days until my school starts and i will ask my teacher for help to find the problem i returned the thermistors do you think it helps when i bought new capacitors and replace them ?
                        • dick_barton
                          • Aug 2015
                          • 6642
                          • Wales
                          The incoming mains of 230v ac is rectified to produce DC and then that DC voltage is increased by the circuit to approximately 380 - 400V DC.
                          There is no point in changing anything until you find that it is faulty!!!
                          • UndeadLuke
                            • Nov 2016
                            • 25
                            • Czech Republic
                            Ah okey thanks I wil try check it with my teacher but also i found something this board has 2 circuit primary and secondary and i cant measure ohms on resistors on second circuit thats weird on first sector of board theres no problem with measure ohms on resistor
                            • UndeadLuke
                              • Nov 2016
                              • 25
                              • Czech Republic
                              I will wait 2 days and try to find the problem with my teacher of electrotechnics
                              • dick_barton
                                • Aug 2015
                                • 6642
                                • Wales
                                To start off, what is the DC voltage across those capacitors. See post #11
                                • UndeadLuke
                                  • Nov 2016
                                  • 25
                                  • Czech Republic
                                  Okey guys So I make big progresws today I check the big capacitors and no voltage on them the voltage stops on part INR or LNR next to main gray CAP so this part is definitly damaged does anyone know which one i need to replace ? it looks like Varistor but i dont know nothing about it
                                    https://www.badcaps.net/forum/attach...7&d=1479570017
                                    So the fuse to left of the line filter cap (grey cap) is good for sure?
                                    Are you getting 230VAC between the two legs of that grey cap?
                                    • UndeadLuke
                                      • Nov 2016
                                      • 25
                                      • Czech Republic
                                      Yes 250VAC on gray cap on right side of it its some type of varistor or part (i dont know what it is and which one i need to replace) this part has voltage on + but if you try + and - no voltage everything after that it has no or bad voltage in miliamperes
                                        We need clear straight shot pictures of the whole board.
                                        There is a bridge rectifier (4-pin black device) mounted on the heatsink, you need to check the ACV between the two inner legs, it should have 230VAC between those two legs.
                                        https://www.badcaps.net/forum/attach...8&d=1479570017
                                        • dj8452000
                                          How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
                                          by dj8452000
                                          I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
                                          02-18-2025, 08:28 AM
                                        • nmbb
                                          Can not find Model/Value of Thermistor.
                                          by nmbb
                                          Machine: Autoclave.
                                          Brand/Model: SANYO MLS-3780
                                          Manual: (Sorry search option not working on this PDF)
                                          Hello guys, this autoclave running with 2 thermistors already connected TH1 and TH3(on CN1,CN2 sockets). One for the water temperture and second one for chamber temperature. But there is another emtpy socket for optional third thermistor CN2 wich is for TH2 for object temperature. I wanna add the third thermistor TH2 to CN2 socket. But i can't figure what model/brand/value i need to use. In manual document, there is no info about TH1 and TH3 model number...
                                          06-02-2022, 05:55 PM
                                        • Use2bavolvo
                                          Magic chef oven - thermistor ref voltage issue
                                          by Use2bavolvo
                                          I am having an issue with my wall oven temperature control is ~180f out of spec. The thermistor is measuring correctly but I noticed the ref voltage appears to be off. With the thermistor wires attached it's reading ~3.4vdc with the thermistor disconnected it's around I9.8vdc. my understanding is the temp is read off the resistance from the thermistor which leads me to believe the issue is with the ref voltage.
                                          Another observation is the temp setting and readout at lower temps is way off meaning the oven thinks room temp is 300f and bake relay doesn't engage unless temp setting...
                                          01-19-2023, 01:32 AM
                                        • trex66
                                          Craftsman 82345 Multimeter broke!
                                          by trex66
                                          My daily carry just stopped working only me. Started last week with the voltage flickering. Found one lead was broken and I ordered new ones. New leads didn't change anything, it displays “-1” on all settings but on continuity will give the tone when touching. Checked battery and found the fuse blown. Replaced fuse but same results. Cleaned the dial and led display and its parts. Board looks nice and clean no burned or broken components. Nothing traumatic happened to this multimeter I put it aside when I found the lead broken and didn't touch it until I got the neAnyone have any ideas what's...
                                          03-04-2025, 04:26 PM
                                        • Ymotaqi
                                          ROG STRIX Z590-A GAMING WIFI has no POST no BEEP no diag LED
                                          by Ymotaqi
                                          The motherboard does not POST and has the following symptoms:
                                          When the power button is pressed, the fans and RGB turns on.
                                          When the power button is pressed, the motherboard voltages 12, 5, and 3 are connected.
                                          The motherboard does not beep.
                                          None of the diagnostic LEDs light up.
                                          USB voltage is off.
                                          VCORE voltage is off.
                                          The BIOS software was downloaded from Asus site and installed using the Q FLASH button, but it made no difference.
                                          I would appreciate it if anyone could guide me on the cause of the problem.
                                          01-12-2025, 04:15 AM
