RCALED42C45RQ inverted pic
  • jakeleg223
    • Jan 2015
    • 6
    Hello guys, Fixing a 42 inch RCA LED TV for a friend, discovered a bad main board and ordered a second hand one off eBay. Installed it and everything works other that the pic and menu is upside down.
    Would this be something reloading the proper firmware would fix? I went into the service menu but couldn't find a way to fix.
    I suspect my second hand board is not identical? Also, could it be a bad TCON?
    The old board is a T420HVN01.1 E13010018-1A00629
    I checked for updated firmware on the RCA site and it said up to date so no luck downloading.
    Thanks, Jake
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: RCALED42C45RQ inverted pic
    probably like you say the mainboard does not match the lcd panel in your tv some times they can be altered in the service menu but im not sure which sub menu etc it maybe in.
    is there a setting too say what size tv you have ie 42 inch does that match ok in the service menu.
    • jakeleg223
      • Jan 2015
      • 6
      The model number is RCALED42C45RQ if that helps.
      hope there is a way to change or ill have to eat 50$ and order the proper board! I could only hope the firmware would fix this!
      jake
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Go into the Service Menu and look for a 'Flip Screen' or 'Invert Screen' choice....What is the T-CON Bd No.??...Does it say LG per chance?
        • Nick's Tvs
          • Jan 2014
          • 621
          The model of the tv you provided we have worked with many times. This model uses I believe 6 different panels dependent on the version. If your image is flipped it is because you probably ordered this board based on its board number and not by part number/panel. Most retailers on ebay and smaller websites have no idea what they have and what panel number the board was taken out of.
          There is no option to flip the screen without major tampering with the eeprom.
          What you need to do is give us your panel number. It will be on a sticker inside the tv.
          Go to shopjimmy.com and type in LED42C45RQ, you will see all the different types of main boards this guy uses. Match up the correct one with your tv and then buy the eeprom chip for it. it will be $15 for the chip and that will take care of your problem.
          They sometimes match the software with the serial number of the tv and sometimes with the panel number. Most instructions will be in described in their listings.
          good luck
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            It looks like an 8 pin IC. Can you just unsolder the original EEPROM and fit it to the replacement board?
            • Nick's Tvs
              • Jan 2014
              • 621
              The original eeprom unfortunately is more than likely the original issue, but definitely worth a try.
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                I had the same problem after changing a faulty motherboard and was lucky that the exchange worked for me. No guarantee but worth a try.
                • jakeleg223
                  • Jan 2015
                  • 6
                  I do still have the old board. Is this EPROM U16 by chance?
                  It might be worth a shot!
                  Jake
                  • Nick's Tvs
                    • Jan 2014
                    • 621
                    Yes U16 should be the eeprom. It will be an 8 legged chip closest to the LVDS cable which is the black connector with all the really small thin wires that come out of it.
                    • jakeleg223
                      • Jan 2015
                      • 6
                      I bit the bullet and purchased another main board with matching numbers! Installed and the pic is still inverted??? WTH??? Could it be the TCON?
                      This tv is driving me to drink! LOL
                      Ill list all part numbers i can below,
                      Big sticker on the inside of tv
                      Model:t420HVN01.1-QYE
                      smaller sticker above T420HVN01.1 B
                      Old Original main board "bad" 42RE010C878LNAo-A1 new board has matching number.
                      there is another sticker on each main board with a bar code and number below. Those numbers dont match. the original bad board number was E13010018-1A00629 below that is T420HVN01.1.
                      The new board is E12100381-3A00095 below that is T420HW09-VO
                      Any ideas?
                      Jake
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        They look like they are for two separate AUO LCD panels.
                        The main board number should match the panel T420HVN01.1
                        Did you try swapping the EEPROM from the original board to it's replacement?
                        Edit
                        Found the following pdf's
                        • Nick's Tvs
                          • Jan 2014
                          • 621
                          Jake,
                          Its all about the software in the U16 chip. I can take your board, and by replacing the software on that chip I can make it work for your TV, and I can make it work for a 32" RCA as well as a 52 inch RCA. All of the main boards for RCA are very similar and are almost all built the same. The biggest difference between them is going to be the software in that u16 chip. If you bought a random main board for a 42" RCA led model, then you would probably have a chance of either getting inverter picture, or heavy discoloration and solarization on screen. If you place software for a slightly large or slightly smaller set, then you will usually get pixilated picture and sometimes inverter as well.
                          Eitherway all of your issues are coming from that u16 chip. That is why we were stating that you may want to place your original back onto one of the boards you purchased. If that doesn't work, it may be because the software was bad in the first place.
                          Take a look at Shopjimmy's listing:
                          http://www.shopjimmy.com/rca-42re010...y-see-note.htm
                          and more specifically at the writing in red under the photo. In this instant, it looks like the part is serial number specific. which means that several of these exact same model TV's used different panels dependent on where they were manufactured which you can tell by the serial number.
                          If we look at the eeprom listing:
                          http://www.shopjimmy.com/rca-led42c4...eprom-only.htm
                          You will see that they go back to using the panel number as a measure for compatibility which can also be determined by the serial number of the set.
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            If you look at the LCD panel interface connection tables given in 3.2 on both panels they have different connections on quite a few of the pins.
                            • jakeleg223
                              • Jan 2015
                              • 6
                              Ok, Thanks for all the help guys. I did swap the original eeprom to the second main board. The pic was still inverted. I gave up and got another 42re010c878lna0-a1 board and its still inverted. But the number "T420HVN01.1" does not match the panel number T420HW09-V0?
                              What eeprom do i need to order on SJ to convert the A1 09V0 board im using now? I wanna start with fresh software on a new U16 eeprom.
                              Thanks again guys!
                              jake
                              The Serial number of the tv is 2503-LE42C45-A100740
                                LCD panel spec.
                                • artstv1
                                  artstv1
                                  • Sep 2014
                                  • 10
                                  • sarasota
                                  Go into the service menu. [Press Menu then 1147] scroll down to Other - Enter. Then scroll down to Mirror control - turn it on. this should flip the picture. Good luck.
                                    LCD LED TV Service Menu Codes
                                    TCL LED TV Service Menu Code
                                    LG LED TV Service Menu Code
                                    10-31-2024, 03:58 AM
                                  • Robby-Gr
                                    TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
                                    by Robby-Gr
                                    I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
                                    However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
                                    The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
                                    Additional issues:...
                                    09-27-2025, 12:02 AM
                                  • zklgfs
                                    Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                                    by zklgfs
                                    I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                                    08-11-2025, 02:14 PM
                                  • TheUser
                                    Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                                    by TheUser
                                    Hello to everyone ,
                                    This is my first post here, and i would like to share with you a small story in case you can help me.
                                    Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                                    All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                                    I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                                    02-10-2024, 02:07 PM
                                  • gurj1979
                                    Ubiquiti firmware help. US-8-150W POE
                                    by gurj1979
                                    Hi guys.
                                    I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
                                    Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
                                    So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
                                    Got New chip and writes good.
                                    THE PROBLEM...
                                    It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
                                    Does anyone have a Good Firmware I can have?...
                                    07-22-2024, 05:13 PM
