Vestel 17PW16-2 troubleshooting
    Re: Vestel 17PW16-2 troubleshooting
    Did you get any further with this repair?
    I bought a kit from Tidman (http://tidmanmailorder.co.uk/index.p...roducts_id=256) and I am currently replacing the last two part which are IC806 and IC807.
    I don't know how to do all the testing you have done but I have replaced most of the parts you are speaking of.
    Here is a list of the parts in the hope it prompts you to a solution.
    Text on accompanying A4 sheet.
    "Vestel 17PW16-2 PSU Board. Replacing all the components should cure most known faults and improve reliability of the PSU. Based on Hitachi L42VP01U, Technika TVLCD40 & Wharfdale LCD42F1080P"
    Kit Contains
    F800 - 2.5A fuse
    IC801 - PC817 Opto
    IC802 - IC FAN7529
    IC806 - IC 01653
    IC807 - SG3525
    C877/8* - Capacitor 15nFd 1000V
    R830 - Resistor 0.22ohm
    Q803 - Transistor P10NK80ZFP
    Q837 - Transistor Yellow (?)
    IC825 - IC STPS5L25B
    D824 - Diode STTH12 +Insulation kit
    D851 - Programmable Zener Diode TL431 (W19)
    D836 - Zener Diode Blue (F2J)
    D866 - Diode UF5402
    C801 - Electrolytic Capacitor 33mFd 50V
    C817 - Electrolytic Capacitor 220mFd
    C892 - Electrolytic Capacitor 10mFd 50V
    *C878 may be 33nFd without C877 in some versions
    March 2009
    Love to hear back if you managed to fix this.
    On a side note, I'd love to know how to test this board - a quick response of whether I can test in-circuit or out of circuit for the parts listed above would be great.
    Last edited by Shotgun25; 01-27-2017, 11:17 AM. Reason: Missed some info in quote section
      Originally posted by dick_barton View Post
      If you lift out your mosfet Q803 and power on
      Does the fuse remain intact
      What voltage do you have across C819 pins
      I replaced all the parts with the kit mentioned above and the fuse blew.
      Having lifted Q803 and the fuse blew again, what would I look for now?
        Check R801 at input
          can you post pictures of the top and bottom of your power supply we may spot something you have missed etc
            I have left Q803 removed as I will need to do some pad repair on the backside of the board to put this back on.
            Having found a schematic and searched for R801 that is a good shout since it's the first thing after the fuse.
            What type of resistor is it and how should it test? I put multimeter in diode/continuity mode and there were no beeps and there was a reading of 513 with probes connected one way and no reading/ rising reading that turns to infinity after 2000 connected the other way.
            IC825 was done around a year ago and it was a pain to get off because I didn't have a decent hot air station to do it (I still don't, cheap eBay rubbish that's 5 years old). As a result pin 1 is not connected but I'm sure from previous research it wasn't connected to anything after the pad or it doubles with the metal back.
            IC806 looks like the PCB is scorched, I think that was from the poor hot air station having the airflow set too high with a required high temperature. That is the new chip though and that was hand soldered.
            As for all other parts where they look soldered, those will be the parts from the kit I listed above.
              Bridge rectifier is good?
                I've just tested D800 following this video https://www.youtube.com/watch?v=11JPy4t36oo and it shows that one leg from -ve(pin 1) to AC (pin 3) has continuity, the rest were around the 500 mark which is supposed to be in tolerance (400 to 600) according to the video.
                I replaced this as part of the kit, so I'm guessing something else after this has fried this part?
                  R801 is a Varistor. Should read quite high ohms. They can break down, but I'm not so sure with the fault you are getting.
                  Some Varistor info:-
                  http://www.electronics-tutorials.ws/.../varistor.html
                    did you fit the insulation kit? as new diode maybe shorting out on the heat sink if you didnt
                    i would also re check all your work ie capacitors and diodes etc fitted the correct way wrong as we have all made the odd mistake
                      So you indicate D800 is bad. You said you replaced it but kit is not showing as part of the kit.
                        is d800 the bridge rectifier?
                          Yes Post 3 has .pdf of psu
                            Yes you are right, I've just been clearing my bench and I found the little tub of parts I removed (kept for reference until fixed) and I don't see one in there, and it looks like you've done due diligence and cross-checked my list, thanks
                            I thought I'd replaced it just looking at the solder joints, seems it was crappy factory soldering.
                            I'll look for a part and give an update when it's replaced.
                            Does it sound like D800 bridge rectifier was the first point of failure or should I replace the varistor (MOV?) as well?
                              The replacement part was provided with a plastic insulating film with some thermal compound, see pic, thanks for the idea though.
                              Also I've checked capacitors which is easy on this board because of the thick line on the -ve side.
                              It's sounding like the bridge rectifier at D800 is to blame.
                                I would guess the Varistor is not the cause of your fault.
                                  Thanks!
                                  The bridge rectifier D800 is labeled KBL10 for reference.
                                    This:-
                                    https://cdn.badcaps-static.com/pdfs/...645b143aa0.pdf
                                      Yeah that's the datasheet I found last night when I searched for it.
                                      I'm going to have to buy this on ebay or amazon as I don't have a list of things to buy from Farnell or RS and I assume I'll incur shipping.
                                      I'll check in when I have the part.
                                      Thanks for keeping an eye out on my thread, it's been sat in my house for around 3-4 years now and I want a victory
                                        rs free shipping no minimum charge at the minute takes a few minutes to register with a credit card i use them a lot lately as good prices even when they do have a minimum order its usually £5.00 .
                                          Ooooh, I was just about to try and make up a £20 order on Farnell, RS it is then, many thanks for that.
